查看: 3190|回复: 39
Slowmo detected on iiN ?
发表于 2009-3-29 11:25:47 | 显示全部楼层 |阅读模式
Hey there,
after iiN submitted his last 2 demos, which caused suspicion amongst some of the users (and us admins as well), we performed a special check on his recent demos done by our coder eDark. The goal was, of course, to see if there is any proof that he is using slowmo.
Here is the result:
After some special analyses eDark was abled to confirm that iiN used slowmo in his latest demos: cg_w00tblock_iiN_0711.rar and kz_xj_brickjump_iiN_0241.rar.
As a consequence he will be banned from the page and submitting demos for 6 months. All of his other records will be removed and replaced with the previous records, since it's extremly hard to detect slowmo and there is no way of telling that they are 100% clean.
Best regards,
xj说iin用了slowmo,iin不出来解释下吗?
发表于 2009-3-29 11:29:07 | 显示全部楼层
悲剧了
 楼主| 发表于 2009-3-29 11:33:46 | 显示全部楼层
原来发重复了,
不过我希望iin能站出来
不管你用没用
来说句话
发表于 2009-3-29 11:39:50 | 显示全部楼层
确实很难检测出 SLOWMO  也没有办法知道他们是否百分百的纯净无作弊 !
艹  意思就是  即使没用SLOWMO 但是只要XJ怀疑就可以判定为作弊了 ?
发表于 2009-3-29 11:42:56 | 显示全部楼层
XJ这样做是不是太武断了点?chriiso7.05刷完cg_wootblock的时候,我看过DEMO,里面有一些动作我也觉得太过分了啊,怎么就没人研究他的DEMO?为什么只研究表姐的?XJ的人,不会都是白吃吧
 楼主| 发表于 2009-3-29 11:43:34 | 显示全部楼层
我希望这是个误会
不过事实摆在眼前
等待iin
发表于 2009-3-29 11:45:26 | 显示全部楼层
强烈要求解释。。。。。。。。。。
发表于 2009-3-29 11:47:42 | 显示全部楼层
iin  录个视频 现场给xj看  --   --
发表于 2009-3-29 11:48:34 | 显示全部楼层
等待解释``
发表于 2009-3-29 11:48:56 | 显示全部楼层
艹  意思就是  即使没用SLOWM ...
SiMen.Sunshine 发表于 2009-3-29 11:39
eDark的意思是,检测slowmo太困难了(也许需要长时间的手工分析),所以不能保证没被怀疑的就干净(估计他不会勤劳到每个demo都检查一遍)
