[讨论]我说什么叫不合格的demo呢?
a2225791
[讨论]我说什么叫不合格的demo呢?
Simen.Rhino3D
Simen.Rhino3D
郁闷
2024-2-29 19:16
发表于 2006-7-23 20:36:00
>exec userconfig.cfg</P>
>把你的userconfig.cfg 也列出来</P>
a2225791
a2225791
草地蚱蜢, 积分 112, 距离下一级还需 188 积分
<DIV class=quote><B>以下是引用<I>xjJFs</I>在2006-7-23 18:37:00的发言:</B><BR>还有就是别自带自定义脚本 USERCONFIG 等</DIV>
>就是你说的这个,我用的cs版本在带的这些脚本!</P>
>这些有什么用呢?</P>
<P>我删了不要紧吧!</P>
a2225791
a2225791
发表于 2006-7-23 20:38:00
<DIV class=quote><B>以下是引用<I>Simen.Rhino3D</I>在2006-7-23 20:36:00的发言:</B><BR>
>把你的userconfig.cfg 也列出来</P></DIV>
>这个是cstrike文件夹下的userconfig.cfg
<P>
<P>
<P>//网络通讯质量<BR>ex_interp "0.1"
<P>cl_rate "20000"
<P>fps_max "100"
<P>cl_cmdbackup "40"
<P>//高品质声效 <BR>hisound "1"
<P>voice_enable "1"
<P>voice_forcemicrecord "1"
<P>sv_voiceenable "1"
<P>s_distance "60"
<P>s_automin_distance "2"
<P>s_automax_distance "30"
<P>s_min_distance "8"
<P>s_max_distance "1000"
<P>s_refgain "0.4"
<P>s_refdelay "4"
<P>s_occfactor "0.25"
<P>s_verbwet "0.25"
<P>s_distance "60"
<P>//显示优化<BR>gl_cull "1" <BR>// 只渲染可见目标<BR>gl_keeptjunctions "0" <BR>// 显示纹理的裂纹<BR>gl_clear "0" <BR>// 纹理质量<BR>d_spriteskip "0" <BR>// 不清楚,似乎能提高性能<BR>r_dynamic "1" <BR>// 固定动态光源<BR>r_mirroralpha "0" <BR>// 关闭反射图片<BR>gl_palette_tex "0" <BR>// 使纹理平滑<BR>r_norefresh "0" <BR>// 非必要时不更新hud和console<BR>gl_texturemode "GL_LINEAR_MIPMAP_NEAREST" <BR>// 设置纹理模式<BR>cl_shadows "0" <BR>// 关闭玩家阴影
<P><BR>//跳蹲脚本 <BR>alias +sjump "+jump;+duck;+speed"<BR>alias -sjump "-jump;-duck;-speed"
<P>//开关持久语音通讯项<BR>alias voice_key voice_on<BR>alias voice_on "+voicerecord; alias voice_key voice_off"<BR>alias voice_off "-voicerecord; alias voice_key voice_on"
<P>//开关持久无声步项<BR>alias speed_key speed_on<BR>alias speed_on "+speed; alias speed_key speed_off"<BR>alias speed_off "-speed; alias speed_key speed_on"
<P>//开关持久蹲下<BR>alias duck_key duck_on<BR>alias duck_on "+duck; alias duck_key duck_off"<BR>alias duck_off "-duck; alias duck_key duck_on"
<P>//左右手持枪方式开关<BR>alias hand_left "cl_righthand 0; alias hand_key hand_right"<BR>alias hand_right "cl_righthand 1; alias hand_key hand_left"<BR>alias hand_key hand_left
<P>//调节游戏音量<BR>alias volume0 "volume 0.0; alias volume_up volume1; alias volume_down volume0"<BR>alias volume1 "volume 0.1; alias volume_up volume2; alias volume_down volume0"<BR>alias volume2 "volume 0.2; alias volume_up volume3; alias volume_down volume1"<BR>alias volume3 "volume 0.3; alias volume_up volume4; alias volume_down volume2"<BR>alias volume4 "volume 0.4; alias volume_up volume5; alias volume_down volume3"<BR>alias volume5 "volume 0.5; alias volume_up volume6; alias volume_down volume4"<BR>alias volume6 "volume 0.6; alias volume_up volume7; alias volume_down volume5"<BR>alias volume7 "volume 0.7; alias volume_up volume8; alias volume_down volume6"<BR>alias volume8 "volume 0.8; alias volume_up volume9; alias volume_down volume7"<BR>alias volume9 "volume 0.9; alias volume_up volume10; alias volume_down volume8"<BR>alias volume10 "volume 1.0; alias volume_up volume10; alias volume_down volume9"<BR>alias volume_up "volume8"<BR>alias volume_down "volume6"
<P>//调节mp3音量<BR>alias mp3_volume0 "MP3volume 0.0; alias mp3_volume_up mp3_volume1; alias mp3_volume_down mp3_volume0"<BR>alias mp3_volume1 "MP3volume 0.1; alias mp3_volume_up mp3_volume2; alias mp3_volume_down mp3_volume0"<BR>alias mp3_volume2 "MP3volume 0.2; alias mp3_volume_up mp3_volume3; alias mp3_volume_down mp3_volume1"<BR>alias mp3_volume3 "MP3volume 0.3; alias mp3_volume_up mp3_volume4; alias mp3_volume_down mp3_volume2"<BR>alias mp3_volume4 "MP3volume 0.4; alias mp3_volume_up mp3_volume5; alias mp3_volume_down mp3_volume3"<BR>alias mp3_volume5 "MP3volume 0.5; alias mp3_volume_up mp3_volume6; alias mp3_volume_down mp3_volume4"<BR>alias mp3_volume6 "MP3volume 0.6; alias mp3_volume_up mp3_volume7; alias mp3_volume_down mp3_volume5"<BR>alias mp3_volume7 "MP3volume 0.7; alias mp3_volume_up mp3_volume8; alias mp3_volume_down mp3_volume6"<BR>alias mp3_volume8 "MP3volume 0.8; alias mp3_volume_up mp3_volume9; alias mp3_volume_down mp3_volume7"<BR>alias mp3_volume9 "MP3volume 0.9; alias mp3_volume_up mp3_volume10; alias mp3_volume_down mp3_volume8"<BR>alias mp3_volume10 "MP3volume 1.0; alias mp3_volume_up mp3_volume10; alias mp3_volume_down mp3_volume9"<BR>alias mp3_volume_up "mp3_volume9"<BR>alias mp3_volume_down "mp3_volume7"<BR>//MP3选择<BR>alias mp3_play1 "mp3 play mp3/1.mp3; alias mp3_play_next mp3_play2; alias mp3_play_last mp3_play10"<BR>alias mp3_play2 "mp3 play mp3/2.mp3; alias mp3_play_next mp3_play3; alias mp3_play_last mp3_play1"<BR>alias mp3_play3 "mp3 play mp3/3.mp3; alias mp3_play_next mp3_play4; alias mp3_play_last mp3_play2"<BR>alias mp3_play4 "mp3 play mp3/4.mp3; alias mp3_play_next mp3_play5; alias mp3_play_last mp3_play3"<BR>alias mp3_play5 "mp3 play mp3/5.mp3; alias mp3_play_next mp3_play6; alias mp3_play_last mp3_play4"<BR>alias mp3_play6 "mp3 play mp3/6.mp3; alias mp3_play_next mp3_play7; alias mp3_play_last mp3_play5"<BR>alias mp3_play7 "mp3 play mp3/7.mp3; alias mp3_play_next mp3_play8; alias mp3_play_last mp3_play6"<BR>alias mp3_play8 "mp3 play mp3/8.mp3; alias mp3_play_next mp3_play9; alias mp3_play_last mp3_play7"<BR>alias mp3_play9 "mp3 play mp3/9.mp3; alias mp3_play_next mp3_play10; alias mp3_play_last mp3_play8"<BR>alias mp3_play10 "mp3 play mp3/10.mp3;alias mp3_play_next "mp3_play1"
<P>//DEMO播放 <BR> <BR>//4X速播放<BR>alias fw2on "host_framerate 0.05;alias fw2 fw2off;developer 1;echo Extreme Fastforward;developer 0" <BR>alias fw2off "host_framerate 0.0;alias fw2 fw2on;developer 1;echo default playback speed;developer 0" <BR>alias fw2 "fw2on"
<P>//2X速播放<BR>alias fastforwardon "host_framerate 0.015;alias fastforward fastforwardoff;developer 1;echo Fastforward;developer 0" <BR>alias fastforwardoff "host_framerate 0.0;alias fastforward fastforwardon;developer 1;echo default playback speed;developer 0" <BR>alias fastforward "fastforwardon"
<P>//暂停<BR>alias pauseon "host_framerate 0.0000000001;alias pauser pauseoff;developer 1;echo paused;developer 0" <BR>alias pauseoff "host_framerate 0.0;alias pauser pauseon;developer 1;echo unpaused;developer 0" <BR>alias pauser "pauseon"
<P>//2/1速
<P>alias slowmotionon "host_framerate 0.0025;alias slowmotion slowmotionoff;developer 1;echo Slowmotion;developer 0" <BR>alias slowmotionoff "host_framerate 0.0;alias slowmotion slowmotionon;developer 1;echo default playback speed;developer 0" <BR>alias slowmotion "slowmotionon"
<P>//1/4速<BR>alias sw2on "host_framerate 0.0005;alias sw2 sw2off;developer 1;echo Extreme Slowmotion;developer 0" <BR>alias sw2off "host_framerate 0.0;alias sw2 sw2on;developer 1;echo default playback speed;developer 0" <BR>alias sw2 "sw2on"
<P>//录象录制<BR>alias demsl demsl1<BR>alias demsl1 "alias demsl demsl2;slowmotion;say_team demospeed 1/2"<BR>alias demsl2 "alias demsl demsl1;sw2;say_team demospeed 1/4"<BR>alias demft demft1<BR>alias demft1 "alias demft demft2;fastforward;say_team demospeed 2x/1x"<BR>alias demft2 "alias demft demft1;fw2;say_team demospeed 4x/1x"
<P>alias savdem savdem1on<BR>alias savdem1on "alias savdem savdem1of;record 001;say_team start to record demo vol.1 - 001.dem"<BR>alias savdem1of "alias savdem savdem2on;stop;say_team finish demo vol.1 - 001.dem"<BR>alias savdem2on "alias savdem savdem2of;record 002;say_team start to record demo vol.2 - 002.dem"<BR>alias savdem2of "alias savdem savdem3on;stop;say_team finish demo vol.2 - 002.dem"<BR>alias savdem3on "alias savdem savdem3of;record 003;say_team start to record demo vol.3 - 003.dem"<BR>alias savdem3of "alias savdem savdem1on;stop;say_team finish demo vol.3 - 003.dem"
<P>//比赛调用的脚本
<P>// Weapon alias<BR>alias go_slot1 "weapon_mp5navy; weapon_m4a1; weapon_m249; weapon_p90; go_slot1b"<BR>alias go_slot1b "weapon_scout; weapon_awp; weapon_g3sg1; weapon_sg550; go_slot1c"<BR>alias go_slot1c "weapon_sg552; weapon_aug; weapon_tmp; weapon_mac10; weapon_ak47; go_slot1d"<BR>alias go_slot1d "weapon_ump45; weapon_xm1014; weapon_m3; weapon_famas; weapon_galil"
<P>alias go_slot2 "weapon_usp; weapon_glock18; weapon_deagle; weapon_p228; weapon_elite; weapon_fiveseven"
<P>alias rze_helm "vesthelm; vest"<BR>alias rze_nvgs "nvgs; nightvision"
<P>alias tg_fn57dual "fn57; elites"<BR>alias tg_tmpmac10 "tmp; mac10"<BR>alias tg_famgal "famas; galil"<BR>alias tg_m4ak "m4a1; ak47"<BR>alias tg_augsg "aug; sg552"<BR>alias tg_sg550g3 "sg550; g3sg1"
<P>// Demo alias<BR>alias demo "demo1"
<P>alias demo1 "record demo1; alias demo stop1"<BR>alias stop1 "stop; alias demo demo2"
<P>alias demo2 "record demo2; alias demo stop2"<BR>alias stop2 "stop; alias demo demo3"
<P>alias demo3 "record demo3; alias demo stop3"<BR>alias stop3 "stop; alias demo demo4"
<P>alias demo4 "record demo4; alias demo stop4"<BR>alias stop4 "stop; alias demo demo1"
<P>// Default config *DONT TOUCH THIS*<BR>max_shells 120<BR>max_smokepuffs 120<BR>mp_decals 300<BR>fastsprites 0<BR>cl_observercrosshair 0<BR>setinfo _ah 0<BR>cl_corpsestay 600<BR>hud_takesshots 0<BR>alias shield ""<BR>rate 25000<BR>cl_updaterate 101<BR>cl_cmdrate 101<BR>ati_subdiv 0<BR>ati_npatch 0<BR>s_eax 0<BR>s_a3d 0<BR>//脚本结束<BR>bind "F12" "exec csmate.cfg"<BR></P>
a2225791
a2225791
发表于 2006-7-23 20:39:00
>这个是userconfigb.cfg</P>
>//网络通讯质量<BR>ex_interp "0.1"</P>
>cl_rate "20000"</P>
<P>fps_max "100"</P>
<P>cl_cmdbackup "40" </P>
<P>//高品质声效 <BR>hisound "1"</P>
<P>voice_enable "1"</P>
<P>voice_forcemicrecord "1" </P>
<P>sv_voiceenable "1"</P>
<P>s_distance "60"</P>
<P>s_automin_distance "2"</P>
<P>s_automax_distance "30"</P>
<P>s_min_distance "8"</P>
<P>s_max_distance "1000" </P>
<P>s_refgain "0.4"</P>
<P>s_refdelay "4"</P>
<P>s_occfactor "0.25"</P>
<P>s_verbwet "0.25"</P>
<P><BR>//跳蹲脚本 <BR>alias +sjump "+jump;+duck;+speed"<BR>alias -sjump "-jump;-duck;-speed"</P>
<P>//开关持久语音通讯项<BR>alias voice_key voice_on<BR>alias voice_on "+voicerecord; alias voice_key voice_off"<BR>alias voice_off "-voicerecord; alias voice_key voice_on"</P>
<P>//开关持久无声步项<BR>alias speed_key speed_on<BR>alias speed_on "+speed; alias speed_key speed_off"<BR>alias speed_off "-speed; alias speed_key speed_on"</P>
<P>//开关持久蹲下<BR>alias duck_key duck_on<BR>alias duck_on "+duck; alias duck_key duck_off"<BR>alias duck_off "-duck; alias duck_key duck_on"</P>
<P>//左右手持枪方式开关<BR>alias hand_left "cl_righthand 0; alias hand_key hand_right"<BR>alias hand_right "cl_righthand 1; alias hand_key hand_left"<BR>alias hand_key hand_left</P>
<P>//调节游戏音量<BR>alias volume0 "volume 0.0; alias volume_up volume1; alias volume_down volume0"<BR>alias volume1 "volume 0.1; alias volume_up volume2; alias volume_down volume0"<BR>alias volume2 "volume 0.2; alias volume_up volume3; alias volume_down volume1"<BR>alias volume3 "volume 0.3; alias volume_up volume4; alias volume_down volume2"<BR>alias volume4 "volume 0.4; alias volume_up volume5; alias volume_down volume3"<BR>alias volume5 "volume 0.5; alias volume_up volume6; alias volume_down volume4"<BR>alias volume6 "volume 0.6; alias volume_up volume7; alias volume_down volume5"<BR>alias volume7 "volume 0.7; alias volume_up volume8; alias volume_down volume6"<BR>alias volume8 "volume 0.8; alias volume_up volume9; alias volume_down volume7"<BR>alias volume9 "volume 0.9; alias volume_up volume10; alias volume_down volume8"<BR>alias volume10 "volume 1.0; alias volume_up volume10; alias volume_down volume9"<BR>alias volume_up "volume8"<BR>alias volume_down "volume6"</P>
<P>//调节mp3音量<BR>alias mp3_volume0 "MP3volume 0.0; alias mp3_volume_up mp3_volume1; alias mp3_volume_down mp3_volume0"<BR>alias mp3_volume1 "MP3volume 0.1; alias mp3_volume_up mp3_volume2; alias mp3_volume_down mp3_volume0"<BR>alias mp3_volume2 "MP3volume 0.2; alias mp3_volume_up mp3_volume3; alias mp3_volume_down mp3_volume1"<BR>alias mp3_volume3 "MP3volume 0.3; alias mp3_volume_up mp3_volume4; alias mp3_volume_down mp3_volume2"<BR>alias mp3_volume4 "MP3volume 0.4; alias mp3_volume_up mp3_volume5; alias mp3_volume_down mp3_volume3"<BR>alias mp3_volume5 "MP3volume 0.5; alias mp3_volume_up mp3_volume6; alias mp3_volume_down mp3_volume4"<BR>alias mp3_volume6 "MP3volume 0.6; alias mp3_volume_up mp3_volume7; alias mp3_volume_down mp3_volume5"<BR>alias mp3_volume7 "MP3volume 0.7; alias mp3_volume_up mp3_volume8; alias mp3_volume_down mp3_volume6"<BR>alias mp3_volume8 "MP3volume 0.8; alias mp3_volume_up mp3_volume9; alias mp3_volume_down mp3_volume7"<BR>alias mp3_volume9 "MP3volume 0.9; alias mp3_volume_up mp3_volume10; alias mp3_volume_down mp3_volume8"<BR>alias mp3_volume10 "MP3volume 1.0; alias mp3_volume_up mp3_volume10; alias mp3_volume_down mp3_volume9"<BR>alias mp3_volume_up "mp3_volume9"<BR>alias mp3_volume_down "mp3_volume7"<BR>//MP3选择<BR>alias mp3_play1 "mp3 play mp3/1.mp3; alias mp3_play_next mp3_play2; alias mp3_play_last mp3_play10"<BR>alias mp3_play2 "mp3 play mp3/2.mp3; alias mp3_play_next mp3_play3; alias mp3_play_last mp3_play1"<BR>alias mp3_play3 "mp3 play mp3/3.mp3; alias mp3_play_next mp3_play4; alias mp3_play_last mp3_play2"<BR>alias mp3_play4 "mp3 play mp3/4.mp3; alias mp3_play_next mp3_play5; alias mp3_play_last mp3_play3"<BR>alias mp3_play5 "mp3 play mp3/5.mp3; alias mp3_play_next mp3_play6; alias mp3_play_last mp3_play4"<BR>alias mp3_play6 "mp3 play mp3/6.mp3; alias mp3_play_next mp3_play7; alias mp3_play_last mp3_play5"<BR>alias mp3_play7 "mp3 play mp3/7.mp3; alias mp3_play_next mp3_play8; alias mp3_play_last mp3_play6"<BR>alias mp3_play8 "mp3 play mp3/8.mp3; alias mp3_play_next mp3_play9; alias mp3_play_last mp3_play7"<BR>alias mp3_play9 "mp3 play mp3/9.mp3; alias mp3_play_next mp3_play10; alias mp3_play_last mp3_play8"<BR>alias mp3_play10 "mp3 play mp3/10.mp3;alias mp3_play_next "mp3_play1" </P>
<P>//DEMO播放 <BR> <BR>//4X速播放<BR>alias fw2on "host_framerate 0.05;alias fw2 fw2off;developer 1;echo Extreme Fastforward;developer 0" <BR>alias fw2off "host_framerate 0.0;alias fw2 fw2on;developer 1;echo default playback speed;developer 0" <BR>alias fw2 "fw2on" </P>
<P>//2X速播放<BR>alias fastforwardon "host_framerate 0.015;alias fastforward fastforwardoff;developer 1;echo Fastforward;developer 0" <BR>alias fastforwardoff "host_framerate 0.0;alias fastforward fastforwardon;developer 1;echo default playback speed;developer 0" <BR>alias fastforward "fastforwardon" </P>
<P>//暂停<BR>alias pauseon "host_framerate 0.0000000001;alias pauser pauseoff;developer 1;echo paused;developer 0" <BR>alias pauseoff "host_framerate 0.0;alias pauser pauseon;developer 1;echo unpaused;developer 0" <BR>alias pauser "pauseon" </P>
<P>//2/1速</P>
<P>alias slowmotionon "host_framerate 0.0025;alias slowmotion slowmotionoff;developer 1;echo Slowmotion;developer 0" <BR>alias slowmotionoff "host_framerate 0.0;alias slowmotion slowmotionon;developer 1;echo default playback speed;developer 0" <BR>alias slowmotion "slowmotionon" </P>
<P>//1/4速<BR>alias sw2on "host_framerate 0.0005;alias sw2 sw2off;developer 1;echo Extreme Slowmotion;developer 0" <BR>alias sw2off "host_framerate 0.0;alias sw2 sw2on;developer 1;echo default playback speed;developer 0" <BR>alias sw2 "sw2on" </P>
<P>//录象录制<BR>alias demsl demsl1<BR>alias demsl1 "alias demsl demsl2;slowmotion;say_team demospeed 1/2"<BR>alias demsl2 "alias demsl demsl1;sw2;say_team demospeed 1/4"<BR>alias demft demft1<BR>alias demft1 "alias demft demft2;fastforward;say_team demospeed 2x/1x"<BR>alias demft2 "alias demft demft1;fw2;say_team demospeed 4x/1x"</P>
<P>alias savdem savdem1on<BR>alias savdem1on "alias savdem savdem1of;record 001;say_team start to record demo vol.1 - 001.dem"<BR>alias savdem1of "alias savdem savdem2on;stop;say_team finish demo vol.1 - 001.dem"<BR>alias savdem2on "alias savdem savdem2of;record 002;say_team start to record demo vol.2 - 002.dem"<BR>alias savdem2of "alias savdem savdem3on;stop;say_team finish demo vol.2 - 002.dem"<BR>alias savdem3on "alias savdem savdem3of;record 003;say_team start to record demo vol.3 - 003.dem"<BR>alias savdem3of "alias savdem savdem1on;stop;say_team finish demo vol.3 - 003.dem"</P>
<P>//比赛调用的脚本</P>
<P>// Weapon alias<BR>alias go_slot1 "weapon_mp5navy; weapon_m4a1; weapon_m249; weapon_p90; go_slot1b"<BR>alias go_slot1b "weapon_scout; weapon_awp; weapon_g3sg1; weapon_sg550; go_slot1c"<BR>alias go_slot1c "weapon_sg552; weapon_aug; weapon_tmp; weapon_mac10; weapon_ak47; go_slot1d"<BR>alias go_slot1d "weapon_ump45; weapon_xm1014; weapon_m3; weapon_famas; weapon_galil"</P>
<P>alias go_slot2 "weapon_usp; weapon_glock18; weapon_deagle; weapon_p228; weapon_elite; weapon_fiveseven"</P>
<P>alias rze_helm "vesthelm; vest"<BR>alias rze_nvgs "nvgs; nightvision"</P>
<P>alias tg_fn57dual "fn57; elites"<BR>alias tg_tmpmac10 "tmp; mac10"<BR>alias tg_famgal "famas; galil"<BR>alias tg_m4ak "m4a1; ak47"<BR>alias tg_augsg "aug; sg552"<BR>alias tg_sg550g3 "sg550; g3sg1"</P>
<P>// Demo alias<BR>alias demo "demo1"</P>
<P>alias demo1 "record demo1; alias demo stop1"<BR>alias stop1 "stop; alias demo demo2"</P>
<P>alias demo2 "record demo2; alias demo stop2"<BR>alias stop2 "stop; alias demo demo3"</P>
<P>alias demo3 "record demo3; alias demo stop3"<BR>alias stop3 "stop; alias demo demo4"</P>
<P>alias demo4 "record demo4; alias demo stop4"<BR>alias stop4 "stop; alias demo demo1"</P>
a2225791
a2225791
>以下这些是cstrike_schinese文件夹下的</P>
>userconfig.cfg</P>
<P>cl_rate "20000"</P>
<P>//显示优化<BR>gl_cull "1" <BR>// 只渲染可见目标<BR>gl_keeptjunctions "0" <BR>// 显示纹理的裂纹<BR>gl_clear "0" <BR>// 纹理质量<BR>d_spriteskip "0" <BR>// 不清楚,似乎能提高性能<BR>r_dynamic "1" <BR>// 固定动态光源<BR>r_mirroralpha "0" <BR>// 关闭反射图片<BR>gl_palette_tex "0" <BR>// 使纹理平滑<BR>r_norefresh "0" <BR>// 非必要时不更新hud和console<BR>gl_texturemode "GL_LINEAR_MIPMAP_NEAREST" <BR>// 设置纹理模式<BR>cl_shadows "0" <BR>// 关闭玩家阴影</P>
<P>//2/1速</P>
<P>//比赛调用的脚本</P>
a2225791
a2225791
发表于 2006-7-23 20:40:00
>cl_rate "20000"</P>
<P>//2/1速</P>
<P>//比赛调用的脚本</P>
Simen.Rhino3D
Simen.Rhino3D
郁闷
2024-2-29 19:16
发表于 2006-7-23 21:37:00
>作弊~~~~~~~~~</P>
xjJFs
xjJFs
草地蚱蜢, 积分 63, 距离下一级还需 237 积分
发表于 2006-7-23 22:06:00
>USERCONFIG 删掉 !~</P>
> 你的就算脚本合格了</P>
xjJFs
xjJFs
发表于 2006-7-23 22:08:00
>跳跃版本推荐 纯净版3266</P>
> ESAI3248 的也可以</P>
> 其他版本由于过多的修改了脚本建议不使用 或者删除 CFG 后建立默认的脚本来进行游戏</P>
a2225791
a2225791
发表于 2006-7-24 11:10:00
<DIV class=quote><B>以下是引用<I>xjJFs</I>在2006-7-23 22:06:00的发言:</B><BR>
>你的就算脚本合格了</P></DIV>
<P>嗯!</P>
<P>我知道了!</P>
