[讨论]我说什么叫不合格的demo呢?
a2225791
[讨论]我说什么叫不合格的demo呢?
a2225791
a2225791
草地蚱蜢, 积分 112, 距离下一级还需 188 积分
发表于 2006-7-22 13:49:00
<DIV class=quote><B>以下是引用<I>xjJFs</I>在2006-7-21 22:37:00的发言:</B><br>
>禁止用连跳 ,大跳脚本 FPS等于;小于 100 </P>
> 和3个参数 800 , 10 , 320</P>
> 就这6个不改的话就算不违规DEMO</P></DIV>
<P>
<P>禁止用是什么意思?</P>
<P>那它自带的我不启用就算合格吧!</P>
<P>像dcoo的1.6版本那些连跳和大跳的脚本都是自带的,比如在键盘设置里面就有大跳和连跳的选项,还有我根本不知道那些脚本在什么地方,所以不会删除!</P>
<P>晕死了,都刷了XJ的一张图了,可是却不知道和合不合格!郁闷!</P>
Simen.Rhino3D
Simen.Rhino3D
郁闷
2024-2-29 19:16
发表于 2006-7-22 15:41:00
找到 你cs 目录下的 cs1.6中文版/cstrike 和 cstrike_schinese文件夹下的两个config.cfg 用写字板打开 复制里面内容发到论坛,我们帮你看。
a2225791
a2225791
发表于 2006-7-22 20:26:00
>这个名字是config</P>
>// This file is overwritten whenever you change your user settings in the game.<br>// Add custom configurations to the file "userconfig.cfg".</P>
>unbindall<br>bind "TAB" "+showscores"<br>bind "ENTER" "+attack"<br>bind "ESCAPE" "cancelselect"<br>bind "SPACE" "+jump"<br>bind "'" "+moveup"<br>bind "+" "sizeup"<br>bind "," "buyammo1"<br>bind "-" "sizedown"<br>bind "." "buyammo2"<br>bind "/" "+movedown"<br>bind "0" "slot10"<br>bind "1" "slot1"<br>bind "2" "slot2"<br>bind "3" "slot3"<br>bind "4" "slot4"<br>bind "5" "slot5"<br>bind "6" "slot6"<br>bind "7" "slot7"<br>bind "8" "slot8"<br>bind "9" "slot9"<br>bind ";" "+mlook"<br>bind "=" "sizeup"<br>bind "[" "invprev"<br>bind "]" "invnext"<br>bind "`" "toggleconsole"<br>bind "a" "+moveleft"<br>bind "b" "buy"<br>bind "c" "radio3"<br>bind "d" "+moveright"<br>bind "e" "+use"<br>bind "f" "impulse 100"<br>bind "g" "drop"<br>bind "h" "+commandmenu"<br>bind "i" "showbriefing"<br>bind "j" "cheer"<br>bind "k" "+voicerecord"<br>bind "m" "chooseteam"<br>bind "n" "nightvision"<br>bind "o" "buyequip"<br>bind "q" "lastinv"<br>bind "r" "+reload"<br>bind "s" "+back"<br>bind "t" "impulse 201"<br>bind "u" "messagemode2"<br>bind "w" "+forward"<br>bind "x" "radio2"<br>bind "y" "messagemode"<br>bind "z" "radio1"<br>bind "~" "toggleconsole"<br>bind "UPARROW" "+forward"<br>bind "DOWNARROW" "+back"<br>bind "LEFTARROW" "+left"<br>bind "RIGHTARROW" "+right"<br>bind "ALT" "+strafe"<br>bind "CTRL" "+duck"<br>bind "SHIFT" "+speed"<br>bind "F1" "autobuy"<br>bind "F2" "rebuy"<br>bind "F5" "snapshot"<br>bind "F6" "save quick"<br>bind "F7" "load quick"<br>bind "F10" "quit prompt"<br>bind "INS" "+klook"<br>bind "PGDN" "+lookdown"<br>bind "PGUP" "+lookup"<br>bind "END" "centerview"<br>bind "MWHEELDOWN" "invnext"<br>bind "MWHEELUP" "invprev"<br>bind "MOUSE1" "+attack"<br>bind "MOUSE2" "+attack2"<br>bind "PAUSE" "pause"<br>_cl_autowepswitch "1"<br>_snd_mixahead "0.1"<br>ati_npatch "0"<br>ati_subdiv "0"<br>bgmvolume "1.000000"<br>bottomcolor "6"<br>brightness "2"<br>cl_allowdownload "1"<br>cl_allowupload "1"<br>cl_backspeed "400"<br>cl_cmdbackup "40"<br>cl_cmdrate "101"<br>cl_corpsestay "600"<br>cl_crosshair_color "50 250 50"<br>cl_crosshair_size "auto"<br>cl_crosshair_translucent "1"<br>cl_dlmax "128"<br>cl_download_ingame "1"<br>cl_dynamiccrosshair "1"<br>cl_forwardspeed "400"<br>cl_himodels "0"<br>cl_idealpitchscale "0.8"<br>cl_lc "1"<br>cl_logocolor "#Valve_Orange"<br>cl_logofile "lambda"<br>cl_lw "1"<br>cl_minmodels "0"<br>cl_radartype "0"<br>cl_righthand "1"<br>cl_shadows "1"<br>cl_timeout "300"<br>cl_updaterate "101"<br>cl_vsmoothing "0.05"<br>cl_weather "1"<br>con_color "255 180 30"<br>console "1.000000"<br>crosshair "1.000000"<br>fastsprites "0"<br>fps_max "100"<br>fps_modem "0.0"<br>gamma "3"<br>gl_dither "1"<br>gl_flipmatrix "0"<br>gl_fog "1"<br>gl_monolights "0"<br>gl_overbright "0"<br>gl_polyoffset "0.1"<br>hisound "1"<br>hpk_maxsize "4"<br>hud_capturemouse "1"<br>hud_centerid "1"<br>hud_draw "1"<br>hud_fastswitch "1"<br>hud_saytext_internal "1"<br>hud_takesshots "0"<br>joystick "0"<br>lookspring "0.000000"<br>lookstrafe "0.000000"<br>m_filter "0"<br>m_forward "1"<br>m_pitch "0.022"<br>m_side "0.8"<br>m_yaw "0.022"<br>model "vip"<br>MP3FadeTime "2.0"<br>MP3Volume "0.800000"<br>mp_decals "300"<br>name "<a href="http://www.dcoo.com/" target="_blank" >www.DcOo.com</A>"<br>net_graph "3"<br>net_graphpos "0"<br>net_scale "5"<br>r_bmodelhighfrac "5.0"<br>r_detailtextures "0"<br>s_a3d "0"<br>s_automax_distance "30"<br>s_automin_distance "2"<br>s_bloat "2.0"<br>s_distance "60"<br>s_doppler "0.0"<br>s_eax "0"<br>s_leafnum "0"<br>s_max_distance "1000"<br>s_min_distance "8"<br>s_numpolys "200"<br>s_polykeep "1000000000"<br>s_polysize "10000000"<br>s_refdelay "4"<br>s_refgain "0.4"<br>s_rolloff "1.0"<br>s_verbwet "0.25"<br>sensitivity "3.000000"<br>skin ""<br>spec_autodirector_internal "1"<br>spec_drawcone_internal "1"<br>spec_drawnames_internal "1"<br>spec_drawstatus_internal "1"<br>spec_mode_internal "1"<br>spec_pip "0"<br>suitvolume "0.250000"<br>sv_aim "0"<br>sv_voiceenable "1"<br>team ""<br>topcolor "30"<br>viewsize "120.000000"<br>voice_enable "1"<br>voice_forcemicrecord "1"<br>voice_modenable "1"<br>voice_scale "0.750000"<br>volume "0.800000"<br>setinfo "_vgui_menus" "1"<br>setinfo "_ah" "0"<br>+mlook<br>+jlook<br>exec userconfig.cfg<br></P>
a2225791
a2225791
发表于 2006-7-22 20:27:00
>这个是configb</P>
>// This file is overwritten whenever you change your user settings in the game.<BR>// Add custom configurations to the file "userconfig.cfg".</P>
>unbindall<BR>bind "TAB" "+showscores"<BR>bind "ENTER" "+attack"<BR>bind "ESCAPE" "cancelselect"<BR>bind "SPACE" "+jump"<BR>bind "'" "+moveup"<BR>bind "+" "sizeup"<BR>bind "," "buyammo1"<BR>bind "-" "sizedown"<BR>bind "." "buyammo2"<BR>bind "/" "+movedown"<BR>bind "0" "slot10"<BR>bind "1" "slot1"<BR>bind "2" "slot2"<BR>bind "3" "slot3"<BR>bind "4" "slot4"<BR>bind "5" "slot5"<BR>bind "6" "slot6"<BR>bind "7" "slot7"<BR>bind "8" "slot8"<BR>bind "9" "slot9"<BR>bind ";" "+mlook"<BR>bind "=" "sizeup"<BR>bind "[" "invprev"<BR>bind "]" "invnext"<BR>bind "`" "toggleconsole"<BR>bind "a" "+moveleft"<BR>bind "b" "buy"<BR>bind "c" "radio3"<BR>bind "d" "+moveright"<BR>bind "e" "+use"<BR>bind "f" "impulse 100"<BR>bind "g" "drop"<BR>bind "h" "+commandmenu"<BR>bind "j" "cheer"<BR>bind "k" "+voicerecord"<BR>bind "l" "showbriefing"<BR>bind "m" "chooseteam"<BR>bind "n" "nightvision"<BR>bind "o" "buyequip"<BR>bind "q" "lastinv"<BR>bind "r" "+reload"<BR>bind "s" "+back"<BR>bind "t" "impulse 201"<BR>bind "u" "messagemode2"<BR>bind "v" "+moveup"<BR>bind "w" "+forward"<BR>bind "x" "radio2"<BR>bind "y" "messagemode"<BR>bind "z" "radio1"<BR>bind "~" "toggleconsole"<BR>bind "UPARROW" "+forward"<BR>bind "DOWNARROW" "+back"<BR>bind "LEFTARROW" "+left"<BR>bind "RIGHTARROW" "+right"<BR>bind "ALT" "+strafe"<BR>bind "CTRL" "+duck"<BR>bind "SHIFT" "+speed"<BR>bind "F1" "autobuy"<BR>bind "F2" "rebuy"<BR>bind "F5" "snapshot"<BR>bind "F6" "save quick"<BR>bind "F7" "load quick"<BR>bind "F10" "quit prompt"<BR>bind "INS" "+klook"<BR>bind "PGDN" "+lookdown"<BR>bind "PGUP" "+lookup"<BR>bind "END" "centerview"<BR>bind "MWHEELDOWN" "invnext"<BR>bind "MWHEELUP" "invprev"<BR>bind "MOUSE1" "+attack"<BR>bind "MOUSE2" "+attack2"<BR>bind "MOUSE4" "+jump"<BR>bind "PAUSE" "pause"<BR>_cl_autowepswitch "0"<BR>_snd_mixahead "0.1"<BR>ati_npatch "0"<BR>ati_subdiv "0"<BR>bgmvolume "1.000000"<BR>bottomcolor "0"<BR>brightness "1.380000"<BR>cl_allowdownload "1"<BR>cl_allowupload "1"<BR>cl_backspeed "400"<BR>cl_cmdbackup "40"<BR>cl_cmdrate "101"<BR>cl_corpsestay "600"<BR>cl_crosshair_color "50 250 50"<BR>cl_crosshair_size "small"<BR>cl_crosshair_translucent "1"<BR>cl_dlmax "128"<BR>cl_download_ingame "1"<BR>cl_dynamiccrosshair "1"<BR>cl_forwardspeed "400"<BR>cl_himodels "0"<BR>cl_idealpitchscale "0.8"<BR>cl_lc "1"<BR>cl_logocolor "#Valve_Red"<BR>cl_logofile "skull"<BR>cl_lw "1"<BR>cl_minmodels "1"<BR>cl_radartype "0"<BR>cl_righthand "1"<BR>cl_shadows "1"<BR>cl_timeout "60"<BR>cl_updaterate "101"<BR>cl_vsmoothing "0.05"<BR>cl_weather "1"<BR>con_color "255 180 30"<BR>console "0.000000"<BR>crosshair "1.000000"<BR>fastsprites "0"<BR>fps_max "100"<BR>fps_modem "0.0"<BR>gamma "2.660000"<BR>gl_dither "1"<BR>gl_flipmatrix "0"<BR>gl_fog "1"<BR>gl_monolights "0"<BR>gl_overbright "0"<BR>gl_polyoffset "4"<BR>hisound "1"<BR>hpk_maxsize "4"<BR>hud_capturemouse "1"<BR>hud_centerid "1"<BR>hud_draw "1"<BR>hud_fastswitch "1"<BR>hud_saytext_internal "1"<BR>hud_takesshots "0"<BR>joystick "0"<BR>lookspring "0.000000"<BR>lookstrafe "0.000000"<BR>m_filter "0"<BR>m_forward "1"<BR>m_pitch "0.022"<BR>m_side "0.8"<BR>m_yaw "0.022"<BR>model "arctic"<BR>MP3FadeTime "2.0"<BR>MP3Volume "1"<BR>mp_decals "300"<BR>name "<a href="http://www.DcOo.com" target="_blank" >www.DcOo.com</A>"<BR>net_graph "3"<BR>net_graphpos "0"<BR>net_scale "5"<BR>r_bmodelhighfrac "5.0"<BR>r_detailtextures "0"<BR>s_a3d "0"<BR>s_automax_distance "30"<BR>s_automin_distance "2"<BR>s_bloat "2.0"<BR>s_distance "60"<BR>s_doppler "0.0"<BR>s_eax "0"<BR>s_leafnum "0"<BR>s_max_distance "1000"<BR>s_min_distance "8"<BR>s_numpolys "200"<BR>s_polykeep "1000000000"<BR>s_polysize "10000000"<BR>s_refdelay "4"<BR>s_refgain "0.4"<BR>s_rolloff "1.0"<BR>s_verbwet "0.25"<BR>sensitivity "3.020000"<BR>skin ""<BR>spec_autodirector_internal "1"<BR>spec_drawcone_internal "1"<BR>spec_drawnames_internal "1"<BR>spec_drawstatus_internal "1"<BR>spec_mode_internal "2"<BR>spec_pip "0"<BR>suitvolume "0.25"<BR>sv_aim "0"<BR>sv_voiceenable "1"<BR>team ""<BR>topcolor "0"<BR>viewsize "120.000000"<BR>voice_enable "1"<BR>voice_forcemicrecord "1"<BR>voice_modenable "1"<BR>voice_scale "1"<BR>volume "2"<BR>setinfo "_vgui_menus" "0"<BR>setinfo "_ah" "0"<BR>+mlook<BR>+jlook<BR>exec userconfig.cfg<BR></P>
a2225791
a2225791
发表于 2006-7-22 20:30:00
>底下是cstrike_schinese里面的</P>
>这个是config</P>
<P>unbindall<BR>bind "TAB" "+showscores"<BR>bind "ENTER" "+attack"<BR>bind "ESCAPE" "cancelselect"<BR>bind "SPACE" "+jump"<BR>bind "'" "+moveup"<BR>bind "+" "sizeup"<BR>bind "," "buyammo1"<BR>bind "-" "bot_kill"<BR>bind "." "buyammo2"<BR>bind "/" "+movedown"<BR>bind "0" "slot10"<BR>bind "1" "slot1"<BR>bind "2" "slot2"<BR>bind "3" "slot3"<BR>bind "4" "slot4"<BR>bind "5" "slot5"<BR>bind "6" "slot6"<BR>bind "7" "slot7"<BR>bind "8" "slot8"<BR>bind "9" "slot9"<BR>bind ";" "+mlook"<BR>bind "=" "bot_add"<BR>bind "[" "+hook"<BR>bind "\" "bot_quota 31"<BR>bind "]" "+grab"<BR>bind "`" "toggleconsole"<BR>bind "a" "+moveleft"<BR>bind "b" "buy"<BR>bind "c" "radio3"<BR>bind "d" "+moveright"<BR>bind "e" "+use"<BR>bind "f" "impulse 100"<BR>bind "g" "drop"<BR>bind "h" "+commandmenu"<BR>bind "i" "showbriefing"<BR>bind "j" "cheer"<BR>bind "k" "+voicerecord"<BR>bind "l" "showbriefing"<BR>bind "m" "chooseteam"<BR>bind "n" "nightvision"<BR>bind "o" "buyequip"<BR>bind "q" "lastinv"<BR>bind "r" "+reload"<BR>bind "s" "+back"<BR>bind "t" "impulse 201"<BR>bind "u" "messagemode2"<BR>bind "v" "say /menu"<BR>bind "w" "+forward"<BR>bind "x" "radio2"<BR>bind "y" "messagemode"<BR>bind "z" "radio1"<BR>bind "~" "toggleconsole"<BR>bind "UPARROW" "+forward"<BR>bind "DOWNARROW" "+back"<BR>bind "LEFTARROW" "+left"<BR>bind "RIGHTARROW" "+right"<BR>bind "ALT" "+strafe"<BR>bind "CTRL" "+speed"<BR>bind "SHIFT" "+duck"<BR>bind "F1" "say /menu"<BR>bind "F2" "say buy_parachute"<BR>bind "F3" "say rockthevote"<BR>bind "F4" "checkpoint"<BR>bind "F5" "gocheck"<BR>bind "F6" "amx_view"<BR>bind "F7" "say /music"<BR>bind "F8" "say /stuck"<BR>bind "F9" "say /keyhelp"<BR>bind "F10" "quit prompt"<BR>bind "F12" "exec csmate.cfg"<BR>bind "INS" "+klook"<BR>bind "DEL" "bot_kick"<BR>bind "PGDN" "+lookdown"<BR>bind "PGUP" "+lookup"<BR>bind "END" "centerview"<BR>bind "MWHEELDOWN" "+jump"<BR>bind "MWHEELUP" "adjust_crosshair"<BR>bind "MOUSE1" "+attack"<BR>bind "MOUSE2" "+attack2"<BR>bind "PAUSE" "pause"<BR>_cl_autowepswitch "1"<BR>_snd_mixahead "0.1"<BR>ati_npatch "0"<BR>ati_subdiv "0"<BR>bgmvolume "1.000000"<BR>bottomcolor "6"<BR>brightness "1"<BR>cl_allowdownload "1"<BR>cl_allowupload "1"<BR>cl_backspeed "400"<BR>cl_cmdbackup "40"<BR>cl_cmdrate "101"<BR>cl_corpsestay "600"<BR>cl_crosshair_color "250 50 50"<BR>cl_crosshair_size "medium"<BR>cl_crosshair_translucent "1"<BR>cl_dlmax "768"<BR>cl_download_ingame "1"<BR>cl_dynamiccrosshair "0"<BR>cl_forwardspeed "400"<BR>cl_himodels "0"<BR>cl_idealpitchscale "0.8"<BR>cl_lc "1"<BR>cl_logocolor "#Valve_Ltblue"<BR>cl_logofile "smiley"<BR>cl_lw "1"<BR>cl_minmodels "0"<BR>cl_radartype "1"<BR>cl_righthand "1"<BR>cl_shadows "0"<BR>cl_timeout "35"<BR>cl_updaterate "101"<BR>cl_vsmoothing "0.05"<BR>cl_weather "1"<BR>con_color "255 180 30"<BR>console "1"<BR>crosshair "1"<BR>fastsprites "0"<BR>fps_max "101"<BR>fps_modem "0"<BR>gamma "3"<BR>gl_dither "1"<BR>gl_flipmatrix "0"<BR>gl_fog "1"<BR>gl_monolights "0"<BR>gl_overbright "0"<BR>gl_polyoffset "0.1"<BR>hisound "1"<BR>hpk_maxsize "4"<BR>hud_capturemouse "1"<BR>hud_centerid "1"<BR>hud_draw "1"<BR>hud_fastswitch "1"<BR>hud_saytext_internal "1"<BR>hud_takesshots "0"<BR>joystick "0"<BR>lookspring "0.000000"<BR>lookstrafe "0.000000"<BR>m_filter "0"<BR>m_forward "1"<BR>m_pitch "0.022"<BR>m_side "0.8"<BR>m_yaw "0.022"<BR>model "vip"<BR>MP3FadeTime "2.0"<BR>MP3Volume "1"<BR>mp_decals "300"<BR>name "NumbeR Zero"<BR>net_graph "3"<BR>net_graphpos "0"<BR>net_scale "5"<BR>r_bmodelhighfrac "5.0"<BR>r_detailtextures "1"<BR>s_a3d "0"<BR>s_automax_distance "30"<BR>s_automin_distance "2"<BR>s_bloat "2.0"<BR>s_distance "60"<BR>s_doppler "0.0"<BR>s_eax "0"<BR>s_leafnum "0"<BR>s_max_distance "1000"<BR>s_min_distance "8"<BR>s_numpolys "200"<BR>s_polykeep "1000000000"<BR>s_polysize "10000000"<BR>s_refdelay "4"<BR>s_refgain "0.4"<BR>s_rolloff "1.0"<BR>s_verbwet "0.25"<BR>sensitivity "2"<BR>skin ""<BR>spec_autodirector_internal "1"<BR>spec_drawcone_internal "1"<BR>spec_drawnames_internal "1"<BR>spec_drawstatus_internal "1"<BR>spec_mode_internal "2"<BR>spec_pip "0"<BR>suitvolume "0.250000"<BR>sv_aim "0"<BR>sv_voiceenable "1"<BR>team ""<BR>topcolor "30"<BR>viewsize "120.000000"<BR>voice_enable "1"<BR>voice_forcemicrecord "1"<BR>voice_modenable "1"<BR>voice_scale "0.750000"<BR>volume "1"<BR>setinfo "_vgui_menus" "0"<BR>setinfo "_ah" "0"<BR>+mlook<BR>exec userconfig.cfg<BR></P>
a2225791
a2225791
>这个是configb</P>
>unbindall<BR>bind "TAB" "+showscores"<BR>bind "ENTER" "+attack"<BR>bind "ESCAPE" "cancelselect"<BR>bind "SPACE" "+jump"<BR>bind "'" "+moveup"<BR>bind "+" "sizeup"<BR>bind "," "buyammo1"<BR>bind "-" "sizedown"<BR>bind "." "buyammo2"<BR>bind "/" "+movedown"<BR>bind "0" "slot10"<BR>bind "1" "slot1"<BR>bind "2" "slot2"<BR>bind "3" "slot3"<BR>bind "4" "slot4"<BR>bind "5" "slot5"<BR>bind "6" "slot6"<BR>bind "7" "slot7"<BR>bind "8" "slot8"<BR>bind "9" "slot9"<BR>bind ";" "+mlook"<BR>bind "=" "sizeup"<BR>bind "[" "invprev"<BR>bind "]" "invnext"<BR>bind "`" "toggleconsole"<BR>bind "a" "+moveleft"<BR>bind "b" "buy"<BR>bind "c" "radio3"<BR>bind "d" "+moveright"<BR>bind "e" "+use"<BR>bind "f" "impulse 100"<BR>bind "g" "drop"<BR>bind "h" "+commandmenu"<BR>bind "j" "cheer"<BR>bind "k" "+voicerecord"<BR>bind "l" "showbriefing"<BR>bind "m" "chooseteam"<BR>bind "n" "nightvision"<BR>bind "o" "buyequip"<BR>bind "q" "lastinv"<BR>bind "r" "+reload"<BR>bind "s" "+back"<BR>bind "t" "impulse 201"<BR>bind "u" "messagemode2"<BR>bind "v" "+moveup"<BR>bind "w" "+forward"<BR>bind "x" "radio2"<BR>bind "y" "messagemode"<BR>bind "z" "radio1"<BR>bind "~" "toggleconsole"<BR>bind "UPARROW" "+forward"<BR>bind "DOWNARROW" "+back"<BR>bind "LEFTARROW" "+left"<BR>bind "RIGHTARROW" "+right"<BR>bind "ALT" "+strafe"<BR>bind "CTRL" "+duck"<BR>bind "SHIFT" "+speed"<BR>bind "F1" "autobuy"<BR>bind "F2" "rebuy"<BR>bind "F5" "snapshot"<BR>bind "F6" "save quick"<BR>bind "F7" "load quick"<BR>bind "F10" "quit prompt"<BR>bind "INS" "+klook"<BR>bind "PGDN" "+lookdown"<BR>bind "PGUP" "+lookup"<BR>bind "END" "centerview"<BR>bind "MWHEELDOWN" "invnext"<BR>bind "MWHEELUP" "invprev"<BR>bind "MOUSE1" "+attack"<BR>bind "MOUSE2" "+attack2"<BR>bind "MOUSE4" "+jump"<BR>bind "PAUSE" "pause"<BR>_cl_autowepswitch "0"<BR>_snd_mixahead "0.1"<BR>ati_npatch "0"<BR>ati_subdiv "0"<BR>bgmvolume "1.000000"<BR>bottomcolor "0"<BR>brightness "1.380000"<BR>cl_allowdownload "1"<BR>cl_allowupload "1"<BR>cl_backspeed "400"<BR>cl_cmdbackup "40"<BR>cl_cmdrate "101"<BR>cl_corpsestay "600"<BR>cl_crosshair_color "50 250 50"<BR>cl_crosshair_size "small"<BR>cl_crosshair_translucent "1"<BR>cl_dlmax "128"<BR>cl_download_ingame "1"<BR>cl_dynamiccrosshair "1"<BR>cl_forwardspeed "400"<BR>cl_himodels "0"<BR>cl_idealpitchscale "0.8"<BR>cl_lc "1"<BR>cl_logocolor "#Valve_Red"<BR>cl_logofile "skull"<BR>cl_lw "1"<BR>cl_minmodels "1"<BR>cl_radartype "0"<BR>cl_righthand "1"<BR>cl_shadows "1"<BR>cl_timeout "60"<BR>cl_updaterate "101"<BR>cl_vsmoothing "0.05"<BR>cl_weather "1"<BR>con_color "255 180 30"<BR>console "0.000000"<BR>crosshair "1.000000"<BR>fastsprites "0"<BR>fps_max "100"<BR>fps_modem "0.0"<BR>gamma "2.660000"<BR>gl_dither "1"<BR>gl_flipmatrix "0"<BR>gl_fog "1"<BR>gl_monolights "0"<BR>gl_overbright "0"<BR>gl_polyoffset "4"<BR>hisound "1"<BR>hpk_maxsize "4"<BR>hud_capturemouse "1"<BR>hud_centerid "1"<BR>hud_draw "1"<BR>hud_fastswitch "1"<BR>hud_saytext_internal "1"<BR>hud_takesshots "0"<BR>joystick "0"<BR>lookspring "0.000000"<BR>lookstrafe "0.000000"<BR>m_filter "0"<BR>m_forward "1"<BR>m_pitch "0.022"<BR>m_side "0.8"<BR>m_yaw "0.022"<BR>model "arctic"<BR>MP3FadeTime "2.0"<BR>MP3Volume "1"<BR>mp_decals "300"<BR>name "<a href="http://www.DcOo.com" target="_blank" >www.DcOo.com</A>"<BR>net_graph "3"<BR>net_graphpos "0"<BR>net_scale "5"<BR>r_bmodelhighfrac "5.0"<BR>r_detailtextures "0"<BR>s_a3d "0"<BR>s_automax_distance "30"<BR>s_automin_distance "2"<BR>s_bloat "2.0"<BR>s_distance "60"<BR>s_doppler "0.0"<BR>s_eax "0"<BR>s_leafnum "0"<BR>s_max_distance "1000"<BR>s_min_distance "8"<BR>s_numpolys "200"<BR>s_polykeep "1000000000"<BR>s_polysize "10000000"<BR>s_refdelay "4"<BR>s_refgain "0.4"<BR>s_rolloff "1.0"<BR>s_verbwet "0.25"<BR>sensitivity "3.020000"<BR>skin ""<BR>spec_autodirector_internal "1"<BR>spec_drawcone_internal "1"<BR>spec_drawnames_internal "1"<BR>spec_drawstatus_internal "1"<BR>spec_mode_internal "2"<BR>spec_pip "0"<BR>suitvolume "0.25"<BR>sv_aim "0"<BR>sv_voiceenable "1"<BR>team ""<BR>topcolor "0"<BR>viewsize "120.000000"<BR>voice_enable "1"<BR>voice_forcemicrecord "1"<BR>voice_modenable "1"<BR>voice_scale "1"<BR>volume "2"<BR>setinfo "_vgui_menus" "0"<BR>setinfo "_ah" "0"<BR>+mlook<BR>exec userconfig.cfg<BR></P>
a2225791
a2225791
发表于 2006-7-22 20:36:00
>我看到XJ上面有demo里面安装了插件,demo一开始就听到“动感光波”!</P>
>只是他计时开始后就没有再用了!</P>
>这样也行吗?它不是安装了插件?那我安装插件只要不用也算合格吗?</P>
JumpeR.sL
JumpeR.sL
草地蚱蜢, 积分 231, 距离下一级还需 69 积分
发表于 2006-7-23 17:28:00
>大跳,连跳脚本。</P>
>FPS。等等,很多。</P>
>默认就好了,准星变色是可以的。</P>
<P>但是跳的时候一定要把config里的大跳脚本和连跳脚本删除,要不然就算你没用也说不清楚。</P>
<P>ni </P>
xjJFs
xjJFs
草地蚱蜢, 积分 63, 距离下一级还需 237 积分
发表于 2006-7-23 18:36:00
>你跳时建议你把 CONFIG 文件删除。删除后打开游戏 游戏会自动生成新的CONFIG文件</P>
> 用系统自己生成的来跳把</P>
> 删除后一些常规参数自己调一边就可以了</P>
xjJFs
xjJFs
发表于 2006-7-23 18:37:00
还有就是别自带自定义脚本 USERCONFIG 等
