查看: 1031|回复: 0
编译不出来地图,什么原因啊? 高手进
发表于 2009-1-11 01:46:59 | 显示全部楼层 |阅读模式
hlcsg v2.5.3 rel (May  2 2001)
Based on Valve's version, modified with permission.
Submit detailed bug reports to (zoner@gearboxsoftware.com)
-----  BEGIN  hlcsg -----
Command line: D:\CSMAPT~1\zhlt\hlcsg.exe D:\CSMapToolkit\编译\8
-= Current hlcsg Settings =-
Name                 |  Setting  |  Default
threads               [       1 ] [  Varies ]
verbose               [     off ] [     off ]
log                   [      on ] [      on ]
developer             [       0 ] [       0 ]
chart                 [     off ] [     off ]
estimate              [     off ] [     off ]
max texture memory    [ 4194304 ] [ 4194304 ]
priority              [  Normal ] [  Normal ]
noclip                [     off ] [     off ]
onlyents              [     off ] [     off ]
wadtextures           [      on ] [      on ]
skyclip               [      on ] [      on ]
hullfile              [    None ] [    None ]
min surface area      [   0.500 ] [   0.500 ]
brush union threshold [   0.000 ] [   0.000 ]
Wadinclude list :
[zhlt.wad]
entering D:\CSMapToolkit\编译\8.map
CreateBrush:
Error: Entity 0, Brush 42, Side 2: plane with no normal
Error: plane with no normal
Description: The map has a problem which must be fixed
Howto Fix: Check the file ZHLTProblems.html for a detailed explanation of this problem
Error: Entity 0, Brush 42, Side 4: plane with no normal
Error: Entity 0, Brush 42, Side 4: has a coplanar plane at (-232, 364, -128), texture -1FIFTIES_W06
Error: Entity 0, Brush 42, Side 5: plane with no normal
Error: Entity 0, Brush 42, Side 5: has a coplanar plane at (-232, 260, -128), texture -1FIFTIES_W06
Error: Entity 0, Brush 42: outside world(+/-4096): (-232,-10000,-128)-(9924,10000,1835)
Error: Entity 0, Brush 42: outside world(+/-4096): (-248,-10016,-164)-(9940,10016,1871)
Error: Entity 0, Brush 42: outside world(+/-4096): (-264,-10032,-160)-(9956,10032,1867)
Error: Entity 0, Brush 42: outside world(+/-4096): (-248,-10016,-146)-(9940,10016,1853)
(0.05 seconds)
-----   END   hlcsg -----
hlbsp v2.5.3 rel (May  2 2001)
-----  BEGIN  hlbsp -----
Command line: D:\CSMAPT~1\zhlt\hlbsp.exe D:\CSMapToolkit\编译\8
>> There was a problem compiling the map.
>> Check the file D:\CSMapToolkit\编译\8.log for the cause.
-----   END   hlbsp -----
