查看: 1531|回复: 20
Simen.newbie 大哥,请进
发表于 2008-12-11 06:46:08 | 显示全部楼层 |阅读模式
怎么不能上传附件啊,只能发源代码
下面是我在国外论坛上找的能显示前100名的插件,
拿过来研究一下,看看怎么用:
/*  AMX Mod X
* csstats Rank to .htm Plugin
* originally developed by Kindzhon from China
* This cs-htm.amx can convert csstats Rank to *.htm per hour, like 1:00,2:00,3:00.......
* And you can set "amx_csstatshtm dir&filename " in server.cfg ,just as:
* amx_csstatshtm  "addons/amxx/custom/csstats27015"
* amx_csstatshtm  "../../bbs/csstats27016"
* default dir&filename is "addons/amxx/custom/csstats27015.htm"
*   Usage: amx_csstatshtm "dir&filename"
* My web: http://61.144.228.61
* http://kindzhon.126.com
* Email:kindzhon@szonline.net
#include <amxmodx>
#include <amxmisc>
#include <csx>
new g_Buffer[2048]
new g_fileToSavehtm[64]
public plugin_init()
register_plugin("CS Stats-html", "0.16", "Kindzhon.126.com")
new szConfig[64]
get_configsdir(szConfig, 63)
add(szConfig, 63, "/csstats")
register_cvar("amx_csstatshtm", szConfig)
set_task(60.0, "htm", _, _, _, "b")
public htm()
new mmins[6]
get_time("%M",mmins,5)
new mins = str_to_num(mmins)
get_cvar_string("amx_csstatshtm",g_fileToSavehtm,63)
format(g_fileToSavehtm, 63, "%s.htm",g_fileToSavehtm)
if (mins == 0) writehtm(g_fileToSavehtm)
return PLUGIN_CONTINUE
writehtm(filename[])
new pos
new stats[8]
new body[8]
new name[32]
new states[4]
if(file_exists(filename))
  delete_file(filename)
pos = copy(g_Buffer,2047,"<html><head><body><table><tr><td bgcolor=#0000FF align=center>Kindzhon.126.com Rank List</td></tr></table></body>")
pos += copy(g_Buffer[pos],2047-pos,"<body><style type=^"text/css^">")
pos += copy(g_Buffer[pos],2047-pos,"body{font-family:Arial,sans-serif;font-size:12px;color:#FFCC99;background-color:#000000;margin-left:8px;margin-top:3px}.header{background-color:#9C0000;}.one{background-color:#310000;}.two{background-color:#630000;}")
pos += copy(g_Buffer[pos],2047-pos,"</style></head><body><table><tr class=^"header^"><td>Rank</td><td>name</td><td>Kills</td><td>Death</td><td>hits</td><td>Shots</td><td>Headshots</td></tr>")
write_file(filename,g_Buffer)
new imax = get_statsnum()
for(new a = 0; a < imax; ++a)
  copy(states, 3, "one")
  if (equal(states,"one"))
   copy(states,3,"two")
  else
      copy(states,3,"one")
  get_stats(a, stats, body, name, 31)
  format(g_Buffer,2047,"<tr class=^"%s^"><td>%d.</td><td>%s</td><td>%d</td><td>%d</td><td>%d</td><td>%d</td><td>%d</td></tr>",states,a+1,name,stats[0],stats[1],stats[5],stats[4],stats[2])
  //client_print(0,print_chat,"rank %d ", a)
new ctime[64]
get_time("%m.%d.%Y- %H:%M:%S", ctime, 63)
format(g_Buffer, 2047, "</table><body><table><tr><td bgcolor=#00007F align=center>Update time: %s</td></tr></table></body></body></html>", ctime)
发表于 2008-12-11 08:03:09 | 显示全部楼层
即便是很简单 ,你这么一搞  视觉效果果然很复杂
    发表于 2008-12-11 08:34:16 | 显示全部楼层
    额~~~不懂任何程序~~
    发表于 2008-12-11 08:34:17 | 显示全部楼层
    吓人
    难过
    2024-3-6 09:56
    发表于 2008-12-11 08:35:23 | 显示全部楼层
    LZ再有问题,你一个帖里提问
    发表于 2008-12-11 10:55:12 | 显示全部楼层
    已经N次了...
     楼主| 发表于 2008-12-11 11:13:05 | 显示全部楼层
    不能传附件,要不就没这么麻烦了,要什么权限才能传附件啊。。。。。
     楼主| 发表于 2008-12-11 11:15:46 | 显示全部楼层
    一个贴里提问,没人帮忙,版主别生气。
    包涵包涵。
    发表于 2008-12-11 12:30:04 | 显示全部楼层
    自己去实验下不得了,谁刚近来也是不知道的
    发表于 2008-12-11 12:30:56 | 显示全部楼层
    在附件的左下脚   只能告诉你这些了   自己琢磨吧
