- 听众
- 收听
- 积分
- 1490
- 主题
- 回帖
- 0
- 精华
注册时间2008-9-19
最后登录1970-1-1
楼主 |
发表于 2008-12-9 17:04:22
//最优网络通讯质量强制参数
cl_lc "1"
cl_lw "1"
//开启游戏预测
cl_nopred "1"
ex_extrapmax "1.2"
cl_nosmooth "1"
cl_smoothtime "0.1"
cl_vsmoothing "0.05"
//FPS强制
fps_max "100"
fps_moden "0"
//禁用ATI显卡的Truform技术提升FPS
ati_npatch "0"
ati_subdiv "0"
//启用CPUMMX指令提升FPS
r_mmx "1"
//禁用游戏摇杆释放内存
joystick "0"
//关闭颜色抖动
gl_dither "0"
//亮度锁定
brightness "3"
gamma "3"
//高品质声效
hisound "1"
voice_enable "1"
voice_forcemicrecord "1"
sv_voiceenable "1"
s_distance "60"
s_automin_distance "2"
s_automax_distance "30"
s_min_distance "8"
s_max_distance "1000"
s_refgain "0.4"
s_refdelay "4"
s_occfactor "0.25"
s_verbwet "0.25"
s_distance "60"
//显示优化
gl_cull "1"
// 只渲染可见目标
gl_keeptjunctions "0"
// 显示纹理的裂纹
gl_clear "0"
// 纹理质量
d_spriteskip "0"
// 不清楚,似乎能提高性能
r_dynamic "1"
// 固定动态光源
r_mirroralpha "0"
// 关闭反射图片
gl_palette_tex "0"
// 使纹理平滑
r_norefresh "0"
// 非必要时不更新hud和console
gl_texturemode "GL_LINEAR_MIPMAP_NEAREST"
// 设置纹理模式
cl_shadows "0"
// 关闭玩家阴影
gl_wateramp "0"
//设置水纹效果
r_drawviewmodel "0"
//提高FPS并增大视野范围
gl_smoothmodels "0"
//模型平滑关闭
r_mirroralpha "0"
//关闭通道混合
//开关持久语音通讯项
alias voice_key voice_on
alias voice_on "+voicerecord; alias voice_key voice_off"
alias voice_off "-voicerecord; alias voice_key voice_on"
//开关持久无声步项
alias speed_key speed_on
alias speed_on "+speed; alias speed_key speed_off"
alias speed_off "-speed; alias speed_key speed_on"
//开关持久蹲下
alias duck_key duck_on
alias duck_on "+duck; alias duck_key duck_off"
alias duck_off "-duck; alias duck_key duck_on"
//左右手持枪方式开关
alias hand_left "cl_righthand 0; alias hand_key hand_right"
alias hand_right "cl_righthand 1; alias hand_key hand_left"
//调节游戏音量
alias volume0 "volume 0.0; alias volume_up volume1; alias volume_down volume0"
alias volume1 "volume 0.1; alias volume_up volume2; alias volume_down volume0"
alias volume2 "volume 0.2; alias volume_up volume3; alias volume_down volume1"
alias volume3 "volume 0.3; alias volume_up volume4; alias volume_down volume2"
alias volume4 "volume 0.4; alias volume_up volume5; alias volume_down volume3"
alias volume5 "volume 0.5; alias volume_up volume6; alias volume_down volume4"
alias volume6 "volume 0.6; alias volume_up volume7; alias volume_down volume5"
alias volume7 "volume 0.7; alias volume_up volume8; alias volume_down volume6"
alias volume8 "volume 0.8; alias volume_up volume9; alias volume_down volume7"
alias volume9 "volume 0.9; alias volume_up volume10; alias volume_down volume8"
alias volume10 "volume 1.0; alias volume_up volume10; alias volume_down volume9"
alias volume_up "volume8"
alias volume_down "volume6"
//调节mp3音量
alias mp3_volume0 "MP3volume 0.0; alias mp3_volume_up mp3_volume1; alias mp3_volume_down mp3_volume0"
alias mp3_volume1 "MP3volume 0.1; alias mp3_volume_up mp3_volume2; alias mp3_volume_down mp3_volume0"
alias mp3_volume2 "MP3volume 0.2; alias mp3_volume_up mp3_volume3; alias mp3_volume_down mp3_volume1"
alias mp3_volume3 "MP3volume 0.3; alias mp3_volume_up mp3_volume4; alias mp3_volume_down mp3_volume2"
alias mp3_volume4 "MP3volume 0.4; alias mp3_volume_up mp3_volume5; alias mp3_volume_down mp3_volume3"
alias mp3_volume5 "MP3volume 0.5; alias mp3_volume_up mp3_volume6; alias mp3_volume_down mp3_volume4"
alias mp3_volume6 "MP3volume 0.6; alias mp3_volume_up mp3_volume7; alias mp3_volume_down mp3_volume5"
alias mp3_volume7 "MP3volume 0.7; alias mp3_volume_up mp3_volume8; alias mp3_volume_down mp3_volume6"
alias mp3_volume8 "MP3volume 0.8; alias mp3_volume_up mp3_volume9; alias mp3_volume_down mp3_volume7"
alias mp3_volume9 "MP3volume 0.9; alias mp3_volume_up mp3_volume10; alias mp3_volume_down mp3_volume8"
alias mp3_volume10 "MP3volume 1.0; alias mp3_volume_up mp3_volume10; alias mp3_volume_down mp3_volume9"
alias mp3_volume_up "mp3_volume9"
alias mp3_volume_down "mp3_volume7"
//MP3选择
alias mp3_play1 "mp3 play mp3/1.mp3; alias mp3_play_next mp3_play2; alias mp3_play_last mp3_play10"
alias mp3_play2 "mp3 play mp3/2.mp3; alias mp3_play_next mp3_play3; alias mp3_play_last mp3_play1"
alias mp3_play3 "mp3 play mp3/3.mp3; alias mp3_play_next mp3_play4; alias mp3_play_last mp3_play2"
alias mp3_play4 "mp3 play mp3/4.mp3; alias mp3_play_next mp3_play5; alias mp3_play_last mp3_play3"
alias mp3_play5 "mp3 play mp3/5.mp3; alias mp3_play_next mp3_play6; alias mp3_play_last mp3_play4"
alias mp3_play6 "mp3 play mp3/6.mp3; alias mp3_play_next mp3_play7; alias mp3_play_last mp3_play5"
alias mp3_play7 "mp3 play mp3/7.mp3; alias mp3_play_next mp3_play8; alias mp3_play_last mp3_play6"
alias mp3_play8 "mp3 play mp3/8.mp3; alias mp3_play_next mp3_play9; alias mp3_play_last mp3_play7"
alias mp3_play9 "mp3 play mp3/9.mp3; alias mp3_play_next mp3_play10; alias mp3_play_last mp3_play8"
alias mp3_play10 "mp3 play mp3/10.mp3;alias mp3_play_next "mp3_play1"
//DEMO播放
//4X速播放
alias fw2on "host_framerate 0.05;alias fw2 fw2off;developer 1;echo Extreme Fastforward;developer 0"
alias fw2off "host_framerate 0.0;alias fw2 fw2on;developer 1;echo default playback speed;developer 0"
alias fw2 "fw2on"
//2X速播放
alias fastforwardon "host_framerate 0.015;alias fastforward fastforwardoff;developer 1;echo Fastforward;developer 0"
alias fastforwardoff "host_framerate 0.0;alias fastforward fastforwardon;developer 1;echo default playback speed;developer 0"
alias fastforward "fastforwardon"
//暂停
alias pauseon "host_framerate 0.0000000001;alias pauser pauseoff;developer 1;echo paused;developer 0"
alias pauseoff "host_framerate 0.0;alias pauser pauseon;developer 1;echo unpaused;developer 0"
alias pauser "pauseon"
//2/1速
alias slowmotionon "host_framerate 0.0025;alias slowmotion slowmotionoff;developer 1;echo Slowmotion;developer 0"
alias slowmotionoff "host_framerate 0.0;alias slowmotion slowmotionon;developer 1;echo default playback speed;developer 0"
alias slowmotion "slowmotionon"
//1/4速
alias sw2on "host_framerate 0.0005;alias sw2 sw2off;developer 1;echo Extreme Slowmotion;developer 0"
alias sw2off "host_framerate 0.0;alias sw2 sw2on;developer 1;echo default playback speed;developer 0"
alias sw2 "sw2on"
//录象录制
alias demsl demsl1
alias demsl1 "alias demsl demsl2;slowmotion;say_team demospeed 1/2"
alias demsl2 "alias demsl demsl1;sw2;say_team demospeed 1/4"
alias demft demft1
alias demft1 "alias demft demft2;fastforward;say_team demospeed 2x/1x"
alias demft2 "alias demft demft1;fw2;say_team demospeed 4x/1x"
// DEMO录制
alias rec_start rec_01
alias rec_01 "alias rec_start rec_02;developer 1;echo Now Recording Demo to demo_01.dem;developer 0;stop; record demo_01";
alias rec_02 "alias rec_start rec_03;developer 1;echo Now Recording Demo to demo_02.dem;developer 0;stop; record demo_02";
alias rec_03 "alias rec_start rec_04;developer 1;echo Now Recording Demo to demo_03.dem;developer 0;stop; record demo_03";
alias rec_04 "alias rec_start rec_05;developer 1;echo Now Recording Demo to demo_04.dem;developer 0;stop; record demo_04";
alias rec_05 "alias rec_start rec_06;developer 1;echo Now Recording Demo to demo_05.dem;developer 0;stop; record demo_05";
alias rec_06 "alias rec_start rec_07;developer 1;echo Now Recording Demo to demo_06.dem;developer 0;stop; record demo_06";
alias rec_07 "alias rec_start rec_08;developer 1;echo Now Recording Demo to demo_07.dem;developer 0;stop; record demo_07";
alias rec_08 "alias rec_start rec_09;developer 1;echo Now Recording Demo to demo_08.dem;developer 0;stop; record demo_08";
alias rec_09 "alias rec_start rec_10;developer 1;echo Now Recording Demo to demo_09.dem;developer 0;stop; record demo_09";
alias rec_10 "alias rec_start rec_01;developer 1;echo Now Recording Demo to demo_10.dem;developer 0;stop; record demo_10";
alias rec_stop "developer 1; echo Now Record Demo Stopped; developer 0;stop"
alias host_playdemo host_01
alias host_01 "alias host_playdemo host_02;developer 1;echo Now Recording Demo to demo_01.dem;developer 0;stop; playdemo demo_01";
alias host_02 "alias host_playdemo host_03;developer 1;echo Now Recording Demo to demo_02.dem;developer 0;stop; playdemo demo_02";
alias host_03 "alias host_playdemo host_04;developer 1;echo Now Recording Demo to demo_03.dem;developer 0;stop; playdemo demo_03";
alias host_04 "alias host_playdemo host_05;developer 1;echo Now Recording Demo to demo_04.dem;developer 0;stop; playdemo demo_04";
alias host_05 "alias host_playdemo host_06;developer 1;echo Now Recording Demo to demo_05.dem;developer 0;stop; playdemo demo_05";
alias host_06 "alias host_playdemo host_07;developer 1;echo Now Recording Demo to demo_06.dem;developer 0;stop; playdemo demo_06";
alias host_07 "alias host_playdemo host_08;developer 1;echo Now Recording Demo to demo_07.dem;developer 0;stop; playdemo demo_07";
alias host_08 "alias host_playdemo host_09;developer 1;echo Now Recording Demo to demo_08.dem;developer 0;stop; playdemo demo_08";
alias host_09 "alias host_playdemo host_10;developer 1;echo Now Recording Demo to demo_09.dem;developer 0;stop; playdemo demo_09";
alias host_10 "alias host_playdemo host_01;developer 1;echo Now Recording Demo to demo_10.dem;developer 0;stop; playdemo demo_10";
//武器快速切换
alias go_slot1 "weapon_mp5navy; weapon_m4a1; weapon_m249; weapon_p90; go_slot1b"
alias go_slot1b "weapon_scout; weapon_awp; weapon_g3sg1; weapon_sg550; go_slot1c"
alias go_slot1c "weapon_sg552; weapon_aug; weapon_tmp; weapon_mac10; weapon_ak47; go_slot1d"
alias go_slot1d "weapon_ump45; weapon_xm1014; weapon_m3; weapon_famas; weapon_galil"
alias go_slot2 "weapon_usp; weapon_glock18; weapon_deagle; weapon_p228; weapon_elite; weapon_fiveseven"
