查看: 2878|回复: 39
晴天霹雳!Steam升级 正版与盗版将可能彻底隔绝!
发表于 2008-10-23 10:57:41 | 显示全部楼层 |阅读模式
引用www.hltv.org的消息
原文地址: http://www.hltv.org/?pageid=35&newsid=1779
CS 1.6 update coming soon
By: Nomad
Time: 2008-10-22 02:11
New CS 1.6 update with consequences for your demo collection.
As some of you might have noticed Valve has been running a beta for an update version of CS 1.6, what exactly the new features will be we are not yet aware of, we however do believe it includes more community features, and an attempt to eliminate silent running using duck jump, but the most notable change, and the reason for this heads up is that the protocol of CS will be changed from 47 to 48.
Most of you probably have no idea why this protocol change matters, but it means that ALL old demos will stop working, yes that is right, all 4500 demos in the HLTV.org demosection, all the demos you have saved over the past years, they will not play. So make sure to get those movies made as soon as possible, rumors has it the update will be released sometime this week.
We have been trying to find a way to make old demos work in the new version, but until now we have not been able to get anywhere. We will keep at it, but it is doubtful they will ever work in the new version.
The good news are that we have been working closely with Valve to make sure HLTV smoothly made the transition to the new version, and from our last tests HLTV should work just as before when the new update goes live.
正版Steam的CS1.6协议版本由原来的47升级到48
由此带来的后果便是更新前录制的所有DEMO将在更新后的正版CS1.6里无法播放
还有正版的CS1.6将会无法进入所有的协议版本为47的服务器 也就是无法进入No Steam的盗版服务器
将会出现以下错误
如果服务器使用的正版CS1.6 升级后也将会彻底将盗版的拒之门外
(引用SiMen.alex的图片)
在控制台输入version 即可查看CS的版本及协议版本
如:
] version
Protocol version 47
Exe version 1.1.2.5 (cstrike)
Exe build: 10:56:59 Oct  3 2005 (3266)
----------------------------------猜想内容------------------------------------
这就意味着以后WR的DEMO如果是用的正版CS1.6录制的话 我们使用No Steam的也将无法欣赏精彩DEMO了
看来这是逼着我们买正版啊....
经过SiMen.alex和Simen.newbie的证实 盗版的可以看升级后正版的DEMO
以上两行属于之前的猜想 请见谅...
再加个刚发现的问题
使用盗版CS1.6的可能会发现在互联网里刷服务器可能没以前那么多了
而且主要都是象dokee 175pt的服务器了
剩下的应该都是使用No Steam架设的服务器 正版的根本刷不到了
所以这次升级真的是太绝了 直接把正版从盗版里过滤掉了
用盗版可以看正版的demo哦,大色魔骗人
[ 本帖最后由 dsm635625 于 2008-10-23 21:08 编辑 ]
参与人数 1金币 +2 +2 收起 理由
kuangdian + 2 + 2 什么意思1
发表于 2008-10-23 11:00:47 | 显示全部楼层
啊啊啊。 那不是完蛋了····
发表于 2008-10-23 11:01:07 | 显示全部楼层
拒绝盗版
发表于 2008-10-23 11:01:58 | 显示全部楼层
沙·发,真是令人振奋的消息啊!!!!
发表于 2008-10-23 11:06:09 | 显示全部楼层
好!
发表于 2008-10-23 11:06:26 | 显示全部楼层
用viewdemo
发表于 2008-10-23 11:07:07 | 显示全部楼层
也许可以转换
但是
谁给我个steam号测试捏
发表于 2008-10-23 11:10:02 | 显示全部楼层
LS好阴险。。。。。。
 楼主| 发表于 2008-10-23 11:11:12 | 显示全部楼层
原帖由 Simen.newbie 于 2008-10-23 11:06 发表
用viewdemo
协议版本升级了不知道还有用没
貌似Steam上也没想出办法来
  • 签到天数: 2 天
    发表于 2008-10-23 11:12:34 | 显示全部楼层
    **~~啊~~~~
    吗了个B啊~~~怎么办啊~~~
