查看: 626|回复: 4
【已解决】求助!!!!!!!
发表于 2008-9-20 09:03:00 | 显示全部楼层 |阅读模式
我过的254demo  由于看不懂英文..也从没发过demo上XJ 的经验..  谁能帮我一下...
                                          QQ 517988793... :'( :'( :'( :'( :'( :'(
发表于 2008-9-20 09:32:24 | 显示全部楼层
我靠hel又发飙了brickvalley, extremeblock
先去XJ注册个会员,然后到这儿:
http://xtreme-jumps.eu/submitdemos.php
以下内容注册会员才能看到,大概意思嘛。。。
0/20 demos have been uploaded so far.
Your Demo:
Upload Rules:上传要求:
  • Archives which don't contain Maprecord, Procallenge or LJ demos will be deleted.
  • 没有把刷图纪录、职业挑战赛纪录或者LJ纪录demo放在压缩包里的一律删除。
  • Only "*.rar" files are accepted.
  • 只允许(上传)"*.rar格式"文件。
  • The biggest filesize which is allowed is 8 MiB. Files which are bigger wont be uploaded.
    -> If your demo is bigger than 8 MiB please contact one of our demo admins via IRC or split your archive via RAR.
  • 文件最大不要超过8M。再大的话就不用上传了。
    ->如果你的demo超过了8M请通过IRC(什么东西?)跟我们的demo管理员之一联系,要不干脆用winrar分卷压缩你的demo好了。
  • The uploaded file must match our rules.
    -> If you dont know the rules make sure you read them before you start uploading your demos.
  • 所有上传的demo务必符合我们的规则。
    -> 如果你还不了解具体规则的话请千万在上传demo前弄清楚。
  • Files which do not follow our rules will be deleted immediately.
  • 与我们的规则不符合的文件立即删除。
  • Our upload form will log all of your activities, user's IP address and UserID will be logged for security measures. In case of abusing (uploading archives without demo records or illegal content or viruses)
    very hard measures will be taken.
  • 我们的上传表格(?)将会记下你的所有操作行为,我们会将你的IP地址以及用户ID加以保密。为防有人胡乱瞎传文件(比如没有KZ纪录demo的、含非法内容的、含病毒的),我们将毫不留情地给予严厉地惩罚。(这段我不会翻55)
还有具体的demo规则,好多:
http://xtreme-jumps.eu/page.php?10#Demo
发表于 2008-9-20 10:35:50 | 显示全部楼层
一大早起来没事就玩这个了。。。打到手酸
Demo rules录像规则
  • You may not use methods which shows the velocity (eg. /speed). Being able to see your velocity gives you an advantage on running parts.
  • 不可以设法显示你的速度(比如用/speed命令)。显示速度的同时可以使你跑得更快。(really?)
  • Demo must be complete. Which means you have to start the demo before pressing the startbutton and end the demo after you have pressed the stopbutton (and killed yourself).
  • 要完整的demo.也就是说开始录时要按下起点处计时器,跳完后要按下终点处计时器(还要自杀才行)。(不过LZ的LJdemo恐怕捞不到计时器按^o^)
  • Knife & USP are the only weapons allowed.
  • 只允许拿刀或USP跳。
  • Demo must be compressed with WinRAR and named like "mapname_author_time.rar", for example "kz_man_bighardclimb_Ad9r_1337.rar"
  • 一定要用WinRAR来压缩demo,并将之命名为类似“地图名_跳跃者_时间.rar”,比如“kz_man_bighardclimb_Ad9r_1337.rar”
  • The name of the demo file (inside the rar file) has to be like this: "mapname_author_time.dem", for example "kz_man_bighardclimb_Ad9r_1337.dem"
  • demo文件(即压缩包里的文件)的命名规则也要像这样:“地图名_跳跃者_时间.dem”,比如“kz_man_bighardclimb_Ad9r_1337.rar”
  • Submit the demo to an admin via IRC. Our channel is #Xtreme-Jumps and is located at Quakenet.
  • 通过IRC(不懂表问我)上传给某位管理员。我们的频道位于Quakenet,频道名叫#Xtreme-Jumps
  • Average fps must be at least 85 fps.
  • fps的平均值不得小于85
  • Kill yourself at the end of the demo. At the time you kill yourself, you must have a nickname which is the same as the nick you submit the demo with.
  • 跳图结束之后请自杀(注意是游戏中的人物自杀^^)。当你自杀的时候,确保屏幕右上角的ID与你上传demo时用的ID一致。
  • The demo must be recorded in-eye.
  • 必须用第一视角录demo。(这句没看懂,瞎翻的)
  • You may not use methods to gain a higher fps rate before you have pushed the start button, and after you have pushed the end button.
  • 在你按起点计时器之前和按终点计时器之后都不能设法提高自己的fps(以便使自己的平均fps达到85或更高)。
  • If a demo contains a timerbug, it will not be accepted. To prevent timerbugs please restart your server every 60 minutes. The probability that a timerbug will occur if your server is running for more than 60 minutes is about 90%. (FAQ: What is a timerbug?)
  • 内含计时器bug的demo我们不要。你若不想出现计时器bug的话就要每60分钟重启下游戏。超过60分钟你的机器出现计时器bug的可能性大概是90%。(常见疑问: 何谓计时器bug?
  • Demo must be done with these settings:录demo时请用以下设置:
    Server:
    edgefriction "2"
    mp_footsteps "1"
    sv_cheats "0"
    sv_gravity "800"
    sv_airaccelerate "10"
    sv_maxspeed "320"
    sv_stepsize "18"
    sv_maxvelocity "2000"
    Player:
    developer "0"
    fps_max "101"
    You are not allowed to use any cvar or setting that might give you an unfair advantage compared to the default counter-strike settings (just as cl_sidespeed and so on). Keep it default!录demo时别用任何cvar(这是啥?)或者不良(相对于CS的默认设置来说,如cl_sidespeed等等)设置。切莫更改默认设置!
  • The demo must be recorded at your own LAN server (aka listen server aka not dedicated). Demos which are recorded at dedicated servers will NOT be accepted.
  • 请务必在单机上录像(括号里的不懂)。在dedicated服上录的demo不要。
  • Any kinds of jumpscripts (bhopscript, doubleduckscript, duckscripts etc) are strictly forbidden! The only command that your jump or duck key is allowed to be bound to is "+jump" or "+duck", and u must not install plugins that effects the jump cmd.
  • 一律禁止任何形容的KZ脚本(连跳脚本、狗跳脚本、duckscript等等duckscripts是啥?蹲也有脚本啊?)!跳和蹲键的绑定命令只能是 "+jump" 和 "+duck",不能有任何影响到你的“跳”命令的插件安装在你机子里。
  • You may not destroy breakable objects (like bridges for example) or push buttons (with an exception for HP boosters), or push movable objects, before you have pushed the start button.
  • 在你按起点计时器按钮之前,不能损坏可以被打掉的东西(比如说像桥什么的)、不能按别的按钮(除非是加血)、不能移动物体。
  • You are not allowed to use any metamod-plugins that would give you an advantage to other jumpers. You may not either use any other timer than the original one.
  • 前半句不懂。不要使用任何非传统的计时器。
  • Demos that require any sprites, models, sounds or gfx not coming with the downloadable .rar/.zip file in the download section are not allowed. Those custom files often come from using AMXX plugins. If you want to avoid this, you should record your demo at a server not using metamod or POD bots (or any kind of plugin at all).
  • 需要有任何.spr文件、.mdl文件、声音文件或是.gfx文件才能看的demo,而上述文件又没跟demo一块儿上传(是不是这个意思我看不懂),不要放在下载专区里。那些非官方的文件通常与你录demo使用了AMXX插件有关。如果你不想这样,建议你在一个没有用到metamod或者POD bots(或是纯无插件的干净的)的服里录demo。
  • Do not ask when your demo will be uploaded.
  • 别问我们什么时候放上你的demo。
  • Check your demo(s) with fps-Death and make sure all settings are correct and that your average fps is higher than 85 before you submit the demo(s).
  • 在你上传一个或多个demo之前请用fps-Death 检测你的demo,以确保所有参数设置均符合要求,而且平均fps也超过85。
  • If the admin thinks that the demo is breaking against any rules, he can choose to not put it on the demo-page. If you do not agree with the admin, you can, of course, tell him what you think about it. But in a polite way.
  • 如何demo管理员认为某demo违反了我们的规则,他有权将之枪毙。如果你有异议,你完全可以与他讨论,不过要注意下讲话的方式。
  • Using Godmode isn't allowed - use the health button!
  • 不能用无敌模式——要用就用加血器!
  • If you want to use HLTV models, use the non-bugged XJ HLTV models. You can get them in the download section. Other HLTV models aren't allowed.
  • 啥?用HLTV录像?不是吧?看不懂。他说要用就用XJ的,其它的免了。
  • adjust_crosshair scripts (changing the color of the crosshair) aren't allowed.
  • 也不要用adjust_crosshair命令(更改准心颜色或模样的命令)。
  • Fakedemos are strictly forbidden. Nobody is allowed to record any demos (for the record or the LJ record section) with a friends nickname or another username. In case of any abuse both involved player will get a 6 month ban from the whole XJ community (Website, IRC, Servers).
  • 严禁代考。不要用你的朋友或者其它人的ID代考(无论是跳图还是LJ的)。一旦发生此类情况,XJ将对所有涉案人员给给予ban6个月的惩罚(包括XJ网站,XJ的IRC,XJ的KZ服)。
发表于 2008-9-20 11:13:45 | 显示全部楼层
就是要先注册,你注册用的ID需要和你demo里的ID一致。
然后左侧那点submit demos里LongJump一项就可以了
 楼主| 发表于 2008-9-24 09:11:51 | 显示全部楼层
谢谢你们的好心拉  我问了人的   那demo是不合格的...
       因为我没在单机录的  不能传   .....
                           谢谢咯..- -!#
