楼主: Simen.6k
Brian与Bibo轮番口舌争执后,Bibo宣布离开XJ
  • 签到天数: 2 天
    发表于 2008-9-10 22:44:52 | 显示全部楼层
    这很难说~~alex和brian很熟~~估计也只能听到brian那一面的情况。。。
    很难把事情了解清楚- - #
    发表于 2008-9-10 22:57:00 | 显示全部楼层
    偶像走了 怎么办!!
    发表于 2008-9-11 07:21:47 | 显示全部楼层
    再找个偶像。。。。。。。。
    3 小时前
  • 签到天数: 541 天
    [LV.9]以坛为家II
    发表于 2008-9-11 23:00:04 | 显示全部楼层
    2个牛人哎...
    发表于 2008-9-12 03:17:09 | 显示全部楼层
    回复 14# 的帖子
    OLAY,你跟我在同一个网吧?
    发表于 2008-9-12 09:20:50 | 显示全部楼层
    我喜欢BIBO
    他 的视频是最好看的 ``
    发表于 2008-9-12 13:18:22 | 显示全部楼层
    Brian:
    bibo, are you serious? why are you lying? i never said anything that would make me seem like i'm king, i didn't even say more than 10 words to you. you keep putting words in my mouth making me seem like the bad guy. "brian called me a nub", "you just wanted to be the king and you had to blow me down".. NEVER HAPPENED.
    it was all just a misunderstanding. i just heard that you were talking trash about me.. so if it's not true, then it's not true. THE END. there's no need to let everyone know about it. please stop making it a bigger deal than it is.
    BRIAN:
    BIBO,你有病吗?为什么你要说谎?我从没说过任何话来表明我像是王者,我甚至没有和你说话超过10个字.你把那些话说成是我说的,就像一个恶毒的人."你说我是XX(屏蔽)","你只想成为王所以就把我弄下去".这些事我从来都没有说过.
    这一切都只是误会.我只是听说你说我是XX(屏蔽),如果那不是真的,真的不是真的.那么,这件事就这样吧.没有必要让每个人都知道这个事情.请停止然后好好商量
    发表于 2008-9-12 19:25:40 | 显示全部楼层
    uber是unbeliver的意思把..
    发表于 2008-9-12 19:26:24 | 显示全部楼层
    bibo和brian都是我偶像..- -..
    发表于 2008-9-12 23:07:47 | 显示全部楼层
    挖哈哈。
    玩自己的就完了。
    跟白吃没什么好说的么。
