查看: 1255|回复: 12
[求助]地图达人都来帮忙看看~
发表于 2008-9-8 14:36:42 | 显示全部楼层 |阅读模式
这几天都在忙着下载Surf地图和测试
看看少不少文件
当换到surf_l33tchris这张图时
地图加载到快满的时候
出现这个问题  AllocBlock:full
我通过百度看了下
大意为地图固体碎块太多 分配固体已满  CS承受不了
解决办法说是删掉部分固体文件就可以了
所以我在这里把地图下载链接发上来
请各位地图达人们帮忙看看
能不能重新编译下?
我在此谢谢你们了呵~
地图下载链接 http://rc-norway.com/fpsb/maps/24/surf_l33tchris.zip
还有个是下载的地图压缩包里的 .log文件
hlcsg v3.4 Final (Feb 25 2006)
Zoner's Half-Life Compilation Tools -- Custom Build
Based on code modifications by Sean 'Zoner' Cavanaugh
Based on Valve's version, modified with permission.
Submit detailed bug reports to (amckern@yahoo.com)
-----  BEGIN  hlcsg -----
Command line: C:\PROGRA~1\Valve\fgd\zoners\hlcsg.exe "C:\Program Files\Valve\Steam\SteamApps\cwunsch\condition zero\czero\maps\surf_l33tchris"
Entering C:\Program Files\Valve\Steam\SteamApps\cwunsch\condition zero\czero\maps\surf_l33tchris.map
Current hlcsg Settings
Name                 |  Setting  |  Default
threads               [       1 ] [  Varies ]
verbose               [     off ] [     off ]
log                   [      on ] [      on ]
developer             [       0 ] [       0 ]
chart                 [     off ] [     off ]
estimate              [     off ] [     off ]
max texture memory    [ 4194304 ] [ 4194304 ]
max lighting memory   [ 6291456 ] [ 6291456 ]
priority              [  Normal ] [  Normal ]
noclip                [     off ] [     off ]
null texture stripping[      on ] [      on ]
clipnode economy mode [      on ] [      on ]
clip hull type        [  legacy ] [  legacy ]
onlyents              [     off ] [     off ]
wadtextures           [      on ] [      on ]
skyclip               [      on ] [      on ]
hullfile              [    None ] [    None ]
nullfile              [    None ] [    None ]
min surface area      [   0.500 ] [   0.500 ]
brush union threshold [   0.000 ] [   0.000 ]
Using mapfile wad configuration
Wadinclude list :
[zhlt.wad]
0 brushes (totalling 0 sides) discarded from clipping hulls
CreateBrush:
(2.06 seconds)
SetModelCenters:
(0.00 seconds)
CSGBrush:
(0.75 seconds)
Using Wadfile: \program files\valve\steam\steamapps\cwunsch\dedicated server\halflife.wad
- Contains 37 used textures, 97.37 percent of map (3116 textures in wad)
added 10 additional animating textures.
Warning: ::FindTexture() texture C~PACK2 not found!
Warning: ::LoadLump() texture C~PACK2 not found!
Texture usage is at 0.56 mb (of 4.00 mb MAX)
3.06 seconds elapsed
-----   END   hlcsg -----
hlbsp v3.4 Final (Feb 25 2006)
-----  BEGIN  hlbsp -----
Command line: C:\PROGRA~1\Valve\fgd\zoners\hlbsp.exe "C:\Program Files\Valve\Steam\SteamApps\cwunsch\condition zero\czero\maps\surf_l33tchris"
Current hlbsp Settings
log                 [      on ] [      on ]
nofill              [     off ] [     off ]
noopt               [     off ] [     off ]
null tex. stripping [      on ] [      on ]
notjunc             [     off ] [     off ]
subdivide size      [     240 ] [     240 ] (Min 64) (Max 512)
max node size       [    1024 ] [    1024 ] (Min 64) (Max 8192)
SolidBSP [hull 0] 500...1000...1500...2000...2158 (0.14 seconds)
BSP generation successful, writing portal file 'C:\Program Files\Valve\Steam\SteamApps\cwunsch\condition zero\czero\maps\surf_l33tchris.prt'
SolidBSP [hull 1] 500...1000...1500...2000...2500...2740 (0.39 seconds)
SolidBSP [hull 2] 500...1000...1500...2000...2500...2798 (0.44 seconds)
SolidBSP [hull 3] 500...1000...1500...2000...2500...2814 (0.47 seconds)
4.09 seconds elapsed
-----   END   hlbsp -----
[ 本帖最后由 dsm635625 于 2008-9-8 17:57 编辑 ]
参与人数 1金币 +3 +3 收起 理由
阿喾 + 3 + 3 测试辛苦!
发表于 2008-9-8 17:58:44 | 显示全部楼层
谁懂的来说下  反正我不懂
发表于 2008-9-8 17:59:17 | 显示全部楼层
太专业!!!!!
发表于 2008-9-8 18:38:27 | 显示全部楼层
等的啊  我学会了就告诉你
  • 签到天数: 2 天
    发表于 2008-9-8 18:52:26 | 显示全部楼层
    哇~~都看不懂- - #
    是什么东西?
    发表于 2008-9-8 19:05:41 | 显示全部楼层
    哦这个啊,搞定!
     楼主| 发表于 2008-9-8 19:37:19 | 显示全部楼层
    原帖由 SiMen.NaMe 于 2008-9-8 19:05 发表
    哦这个啊,搞定!
    怎么弄的?
    发表于 2008-9-8 23:42:06 | 显示全部楼层
    找所长007谁的
    发表于 2008-9-10 12:39:59 | 显示全部楼层
    把你的cs启动参数贴上来
     楼主| 发表于 2008-9-10 13:34:53 | 显示全部楼层
    原帖由 Simen.newbie 于 2008-9-10 12:39 发表
    把你的cs启动参数贴上来
    。。。怎么贴。。。?
    啥子是启动参数?
    第一次遇到 不知哦
