查看: 928|回复: 1
[求助]这是怎么搞的啊?
发表于 2006-2-13 16:39:00 | 显示全部楼层 |阅读模式
我进跳跃F,总显示这个 Connecting to 222.242.129.122:27019... Connection accepted by 222.242.129.122:27019 ===-- Server is running at 167 fps with Booster. * Privileges set  BUILD 2834 SERVER (0 CRC) Server # 4 Could not read BSP header for map [maps/KZ_fairy_island.bsp]. Host_Error: Dis 然后我就进不去了!~~ 求高手解答一下,小弟新人
 楼主| 发表于 2006-2-13 17:22:00 | 显示全部楼层
Connecting to 222.242.129.122:27019 ... Connection accepted by 222.242.129.122:27019 ===-- Server is running at 151 fps with Booster. * Privileges set  BUILD 2834 SERVER (0 CRC) Server # 5 Could not read BSP header for map [maps/kz_man_riverside.bsp]. Host_Error: Dis
