查看: 2269|回复: 10
[转帖]适合新手的------小跳(转自XJ)
发表于 2006-2-9 04:47:00 | 显示全部楼层 |阅读模式
<p align="left">小跳教程</p><p align="left">2005年10月7日 星期5 <br/>作者:FikoN</p><p align="left"><br/>什么地方?</p><p align="left">小跳常用于登上32单位高低的台阶(CS里一个人站着是72单位,蹲着是36单位)</p><p align="left">为什么?</p><p align="left">原因是它很简单,很容易掌握。当你完成一个普通跳跃后,你的速度会减慢。当你小跳时,你不会减速,我不知道为什么是这样,但是我想可能和“跳跃”命令有关。</p><p align="left">如何实现?</p><p align="left">实现小跳是很容易的,但还需多练习使其能更好的掌握。只要向你所需要登上的物体助跑,到边缘时按两次“蹲”就可以了。但你必须很快的按两次,这就是你为什么要多练习的原因。</p><p align="left">要点!</p><p align="left">如果你的滑轮没有绑定任何东西,我强烈建议你把“上滑轮”或“下滑轮”设置为“蹲”,那样你想登上低物体的时候只需按滑轮就可以了。实际上要比按两次蹲容易的多。练习小跳最好的地图是Long Jump地图,在跑过每一个石头的时候可以练习一次。</p><p align="left">原文如下:</p><p align="left">Doubleduck guide&nbsp; <br/>&nbsp;<br/>FikoN Friday 07 October 2005</p><p align="left">&nbsp;<br/>Where? </p><p align="left">Doubleducking is used to get up edges that are 32 units high or less. </p><p align="left"><br/>Why? </p><p align="left">The reason why it's used is simple, you make time on it. When you land from a regular jump you slow down. When you doubleduck, you don't slow down. I don't really know why it's like that but I assume it has something to do with the "+jump"-cmd being used. </p><p align="left"><br/>How? </p><p align="left">To perform a doubleduck is easy, though it can take some practice to learn doing it fast. Just run against the edge you want to get up and press duck twice. But you have to do it quite fast and that's why you should practice it some. </p><p align="left"><br/>Tips </p><p align="left">If your scroll buttons aren't bound to anything, I strongly recommend that you bind either mwheelup or mwheeldown to "+duck". That way you just have to scroll down or up to get up the edge. Which actually is a lot easier (and less work&nbsp; ) than pressing duck twice. </p><p align="left">The best place to practice is in longjump maps. Run across the longjump blocks and perform a doubleduck on each one of them.&nbsp;<br/>&nbsp;</p><p align="left">本人水平有限,如有错误之处敬请原谅!<br/></p>
[此贴子已经被作者于2006-2-9 5:55:20编辑过]
发表于 2006-2-9 14:55:00 | 显示全部楼层
<p><font face="楷体_GB2312" color="#ff0000" size="7">好东西要顶</font></p>
发表于 2006-2-9 15:12:00 | 显示全部楼层
<p>Doubleduck</p><p>说简单点 就是滚轮蹲一下 再ctrl蹲住 HOHO</p>
发表于 2006-2-11 16:47:00 | 显示全部楼层
是的哇 支持!
 楼主| 发表于 2006-2-12 13:34:00 | 显示全部楼层
<p>大家觉得小跳在KZ里实用还是在CS里更实用呢?</p>
发表于 2006-2-12 13:52:00 | 显示全部楼层
学习学习...谢谢楼主
 楼主| 发表于 2006-2-12 13:58:00 | 显示全部楼层
哈哈,不谢不谢。
发表于 2006-2-12 17:48:00 | 显示全部楼层
cs里更实用。。尤其是摸死角的时候 人家看到你小跳 准备抬枪口 结果一个滑步 蹲下了。。饶乱别人的预瞄点。。
发表于 2006-2-16 12:20:00 | 显示全部楼层
<p>小跳走路比赛中好象是犯规的吧!</p><p>侦察还可以!</p>
发表于 2006-2-16 13:31:00 | 显示全部楼层
<div class="quote"><b>以下是引用<i>jitadashi</i>在2006-2-16 12:20:58的发言:</b><br/><p>小跳走路比赛中好象是犯规的吧!</p><p>侦察还可以!</p></div><p>娱乐比赛随便用 哈哈 不过 只要不要一直那样跑 就不算犯规的。。</p>
