查看: 863|回复: 4
请问Source有没有跳跃插件
发表于 2008-3-19 05:52:38 | 显示全部楼层 |阅读模式
Counter-Strike Source 有没有跳跃插件
怎么没人在玩Source ..画面很好阿~又逼真~
为什么没人讨论呢
发表于 2008-3-19 09:41:14 | 显示全部楼层
我不喜欢~~~~~~~~~~~~
发表于 2008-3-19 10:06:53 | 显示全部楼层
http://forums.mattie.info/cs/forums/viewtopic.php?t=7482
找到一个eventscripts下运行的
 楼主| 发表于 2008-3-19 19:13:31 | 显示全部楼层
cp_allowmenu 1 //If set to 1-players can use !cp to open the checkpoint menu popup (thx GodJones for the popup script)
cp_allowghostcommands 1 //If set to 1 players can use !ghost and !unghost to enable or disable ghost individually
cp_forceunghost 1 // If set to 1 players will be unghosted when they spawn and the script is unloaded
cp_ghosts 1 //If set to 1 script will make players appear like ghosts and pass through each other
cp_alpha 100 //This is the alpha level of players if cp_ghost is set to 1 (0 = completely invisible, 255 = completely visible)
cp_removeweapons 1 //If set to 1 script will remove weapons from players (players will keep their knife)
cp_sethealth 99999 //Set players health to this. '0' -disables
cp_limit 20 // number of server_var(cp_keygroup) players can have
cp_savecheckpoints 1
// 1-Save checkpoints for each map. Checkpoints are not deleted when players leave the game
// 0-Dont save and delete players checkpoints whenever they leave and join the server
//Map Settings//
//map types to enable cp_checkpoint mod
es_keycreate cp_maptypes kz
es_keycreate cp_maptypes de
   //example: es_keycreate cp_maptypes surf
//maps to force on
es_keycreate cp_force_on blizzard2
es_keycreate cp_force_on scoutzknivez
   //example: es_keycreate cp_force_on de_lahlah
//maps to force off
es_keycreate cp_force_off surf_egypt
   //example: es_keycreate cp_force_off surf_dontcheckpoint
Simen.newbie請教您..這各部份如何安裝呢
发表于 2008-3-19 19:24:51 | 显示全部楼层
不知道
没用过eventscripts
