查看: 1067|回复: 17
看不懂,感觉像是要出新图了
发表于 2008-2-26 23:19:50 | 显示全部楼层 |阅读模式
Just wanted to post a quick reminder for all the mappers currently working on a longjumpmap for the contest, it's only 4 days left to send in your map.
Deadline: 1'st March, 2008 Rules:
1. You CANT send in a map from the previous contest.
2. You NEED to include 32 player spawns.
3. No timer is required.
4. Guidelines - the map must include theese lengths:
CJ's: ~240-275
LJ's: ~220-265
HJ's: ~220-250
BJ'S: ~220-250
5. We recommend a jumpheight of 24-25 units.
6. Keep in mind that longjumping requires high fps, so make it look good but keep the fps high.
7. Ofcourse you need to make the Countjump blocks wider so you can make a bigger pre.
8. Remember that the map you send in is FINAL, NO updates are possible to make.
9. Name your map KZ_longjumps2_nick/nicks
~ = about
So basicly all you need to do is:
1. Make a map including: CJ's: ~240-275, LJ's: ~220-265, HJ's: ~220-250, BJ'S: ~220-250. Ofcourse with a free design of your choise and any ideas you have in mind, but keep in mind that longjumps require high fps, so dont make too many details.
2. Upload the map, named: kz_longjumps2_nick (ex. -link-) and send the download link to kz`Moxx or radon at Quakenet. So I recommend you hurry up and send in your map, cause the deadline is close.
[ 本帖最后由 fRoGnInja 于 2008-2-26 23:23 编辑 ]
发表于 2008-2-26 23:28:48 | 显示全部楼层
收集LJ新图
LZ会做吗
发表于 2008-2-26 23:29:03 | 显示全部楼层
。。。。看不懂就别发了,以前的新闻,提醒地图作者kz_longjumps2期限要到了
发表于 2008-2-26 23:30:35 | 显示全部楼层
原帖由 SiMen.beambean 于 2008-2-26 23:29 发表
。。。。看不懂就别发了,以前
学习好就是好!
我也看不懂,,,
 楼主| 发表于 2008-2-26 23:31:45 | 显示全部楼层
这不发出来就知道了
发表于 2008-2-26 23:54:20 | 显示全部楼层
我也看不懂。
CJ's: ~240-275
LJ's: ~220-265
HJ's: ~220-250
BJ'S: ~220-250
看到這些我寧願不懂的好/。
发表于 2008-2-27 00:01:48 | 显示全部楼层
英语达人翻译啊
发表于 2008-2-27 00:06:28 | 显示全部楼层
简单扼要的说就是提醒各位参加地图制作比赛的朋友注意截至日期为3月1日
比赛地图是kz_longjumps2
发表于 2008-2-27 00:26:38 | 显示全部楼层
只想邮政快速,提醒所有的绘图工作,目前就longjumpmap为竞赛,它的只有4天送在你的地图。
截止日期: 1'st 3月, 2008年的规则:
1 。你斜面派在地图上,从以前的竞赛。
2 。你需要包括32个球员粒。
3 。没有计时器的需要。
4 。指南-地图上,必须包括这些长:
终审法院首席法官的: 〜 240-275
LJ ,的: 〜 220-265
hj的: 〜 220-250
BJ公司: 〜 220-250
5 。我们建议制定一个jumpheight的24-25个单位。
6 。请记住longjumping要求很高新鲜粮食店,所以它看起来很好,但保持新鲜粮食店高。
7 。 ofcourse你需要使countjump块广泛,所以你可以作出更大的学前教育。
8 。记得在地图上你送的是决赛中,没有更新是不可能的。
9 。名字你的地图kz_longjumps2_nick/nicks
〜 =约
因此,基本上所有你需要做的是:
1 。一个地图,其中包括:终审法院首席法官的: 〜 240-275 , LJ ,的: 〜 220-265 , hj的: 〜 220-250 , BJ公司: 〜 220-250 。 ofcourse在一个自由的设计,以及您选择的任何想法,你还有一点,但请记住, longjumps需要高新鲜粮食店,所以不用作太多的细节。
2 。上传地图,命名为: kz_longjumps2_nick (如链路) ,并把下载链接kz ` moxx或氡在quakenet 。所以我建议你赶快把你在地图上,造成的截止日期是密切。
发表于 2008-2-27 00:30:30 | 显示全部楼层
汗死了 这是什么啊- -|||
