查看: 2170|回复: 10
surf_olympics.amxx 望达人指点一二
发表于 2008-2-20 09:44:30 | 显示全部楼层 |阅读模式
surf_olympics.rar (82.28 KB, 下载次数: 168)
今天突然想玩Surf地图了 然后下了
SiMen_CS1.6_KZ_1.0
LJ插件中文版_2.2B7
SiMen跳跃脚本安装程序 圣诞完美版
SiMen_Surf_allinone_surfmappack_v11
然后到Goolge上搜了下Surf 居然找到了一个Surf的插件surf_olympics
下载安装完毕 在plugins.ini里添加了surf_olympics.amxx
又找了些相关的命令说明
*   ----SURF_OLYMPICS-v1.5.1----作者: OneEyed----
*   ----衝浪運動-v1.5.1----中文化作者: h266579110(Generals_Zero Hour)---
*  需要的AMXX版本:
*  AMXX 1.70或是1.71限定
*  需要的MODULES:
*   CSTRIKE
*   ENGINE
*   FAKEMETA
*   NVAULT
*  指令:
*   surf_flyspeed <#>       - Changes flying speed of surf_endzone tool
*   surf_teamstack < 0 | 1 | 2 >  - Forces players to be in a certain team.
*   surf_godmode < 0 | 1 >     - 開啟/關閉無敵模式在玩家身上
*   surf_semiclip < 0 | 1 >    - Enables/Disables semi-clip on players.
*  命令:
*   surf_endzone        - 開啟衝浪運動結束區設置
*   surf_delete         - 開啟衝浪運動刪除紀錄設置
*   surf_on  < 0 | 1 >    - 開啟/關閉模組 99%.
*  說的指令:
*   /spec           - 讓你到旁觀者
*   /respawn        - 讓你復活.
*   /top3           - 開啟地圖前三名紀錄
*   /help           - 開啟幫助選單
限定於Surf開頭的地圖使用
对于右边的一些命令详解还有望达人帮帮忙~~
这是里面的readmy文件
*   -------------SURF_OLYMPICS-v1.5.2--------www.cs-trickz.com---------------
* COMMENTS:
*  Install the plugin normally, and get ready to beat some freagin records!
* REQUIRED:
*  AMXX 1.70
* MODULES:
*  CSTRIKE
*  ENGINE
*  FAKEMETA
*  NVAULT
* CVARS:
*  surf_godmode < 0 | 1 >   - Enables/Disables godmode on players.
* COMMANDS:
*  surf_endzone     - Enables Surf EndZone Creation Tool
*  surf_delete      - Enables Map Record Catagory Deletion menu.
*  surf_on < 0 | 1 >    - Enables/Disables plugin 99%.
* CHAT COMMANDS:
*  /spec       - Makes you a spectator.
*  /respawn      - Respawns you.
*  /top3       - Opens Map Top Records list.
*  /help       - Opens help menu.
* PLUGIN DETAILS:
*  When you spawn in, your in standby mode.  As soon as you jump, your game is activated and your
*  records get recorded.  Current records are Map Completion, Speed, Hang Time, Distance, and
*  Height.  The plugin automatically respawns users when you die or fall down.  Players also have
*  a simulated Semi-clip, so they don't get stuck inside each other, but still allow to block
*  each other.  To complete the map, touch the designated EndZone lightning bolt.
* CREDITS:
*  - Rukia found how to know if your on ladder. (drove me nuts yet it was so easy)
*  - teame06/VEN for HLTV event.
*  - teame06 help with new menu system, and Team_Select menu, and some inspiration =).
*  - Xtrem3 found a major hang time exploit.
*  - iron helix found a major height exploit.
*  - XAD - used the same font color from his statsx motd.
*  - door for helping me test some features.
*  - Gorlag/Batman for his Flying code.
*  - BASIC-MASTER, I copied his Special Effect. (not the code, just effect)
*  - BAILOPAN for some of the weapon removal code from CSDM v1.
*  - BAILOPAN, for his information on code optimization. (READ IT)
*   -- http://www.sourcemod.net/devlog/?p=62 ====================================================================================================
Infos:
ChangeLog:
v1.5.2:
- Fixed crashing in surf_xss and surf_maya.
v1.5.1:
- Fixed a bug with the semi-clip cvar.
- Fixed a entity leak error with weapon removal.
v1.5:
- Commentator can be turned on/off through a #define.
- New CVARs:
- surf_godmode < 0 | 1 > (Turns God Mode OFF/ON, for everyone.)
- surf_semiclip < 0 | 1 > (Turns Semi-Clip OFF/ON, for everyone.)
- New COMMANDs:
- surf_delete (Opens menu to delete records of current map.)
- surf_on < 0 | 1 > (Turns plugin OFF/ON completely.)
- New Top Record System:
- One person can't dominate an entire record, there will always be three
- different players for every record catagory. Saved by STEAMID not name.
- Weapons from game_player_equip entity are removed upon death, to prevent spam.
- Players can now easily jump on top of users in Semi-Clip mode.
v1.1:
- Changed the HUD system a little bit, to be less laggy.
- Fixed an accidental logical error with clearing airtype records.
- Blocked trigger_hurts that heal from teleporting.
- Added Personal Statistics to /top3 window.
[ 本帖最后由 dsm635625 于 2008-2-20 09:57 编辑 ]
 楼主| 发表于 2008-2-20 09:58:46 | 显示全部楼层
Surf里的EB好容易 经常能碰见
注意:插件开启状态中,录制的demo为合格demo! 插件开启状态中,录制的demo为合格demo!
[XJ] XXX now is 1 in Edge Bug top 10 with 2353 units Edge Bug!
[KZRU] XXX had done 6th Edge Bug [Distance: 2353]!
发表于 2008-2-20 10:16:33 | 显示全部楼层
要汉化中文版本的
 楼主| 发表于 2008-2-20 10:22:50 | 显示全部楼层
汉化的只能找到说明文件
源文件下不了。。。
    奋斗
    2024-12-15 16:25
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2008-2-20 10:39:33 | 显示全部楼层
    一点都不好用。。。。
    还要打什么Surf。。。。
    发表于 2008-2-20 10:47:18 | 显示全部楼层
    右边?
    发表于 2008-2-20 10:59:47 | 显示全部楼层
    尿布果然来了.........................
  • 签到天数: 2 天
    发表于 2008-2-20 13:45:06 | 显示全部楼层
    这个。。。滑坡的插件有什么功能?!
    我觉得玩滑坡没什么要插件的~~可能是我不懂吧~~
     楼主| 发表于 2008-2-20 14:14:19 | 显示全部楼层
    就是不知道那后面的单位是什么意思 如果知道了也许对SURF有帮助
    发表于 2008-2-20 18:56:05 | 显示全部楼层
    我进过个Z版F..里面的SURF插件有存点,测速,空中痕迹等...非常完美...
