- 听众
- 收听
- 积分
- 6534
- 主题
- 回帖
- 0
- 精华
注册时间2008-1-10
最后登录1970-1-1
发表于 2009-8-16 20:31:42
请附带对应的源码sma文件,谢谢
幻梦浮云 发表于 2009-8-16 16:16
MultiPlayer Bunny Hops v1.2
Copyright (C) 2007 Ian (Juan) Cammarata
This program is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License as published by the Free Software
Foundation; either version 2 of the License, or (at your option) any later
version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with
this program; go to http://www.opensource.org/licenses/gpl-license.php
http://ian.cammarata.us/projects/mpbhops
Sep 23 14:06
Description:
This plugin allows clients to jump across sections of bhops without the blocks being triggered. The blocks stay in place all the time making it much more suitable for multiplayer. It is also semiclip safe.
See it in Action:
1337bunnies server: 66.55.131.63:27015
Commands:
Not Applicable.
Cvars:
mpbhops <0|1> Disables/enables bhop handling.
Requirements:
Engine module
Notes:
This is a stand alone version of the code from my climb plugin, for those who don't want all the features it offers.
http://ian.cammarata.us/projects/climb
Credits:
Thanks to Lola for letting me use her awesome server for testing purposes.
http://1337bunnies.com
66.55.131.63:27015
Thanks to r33d and Woofie for testing.
Supported Languages:
Not Applicable.
Change Log:
Key (+ added | - removed | c changed | f fixed)
v1.2 (SEPT 23, 2007)
+: Semiclip support for BCM plugins by Emp` and Necro.
v1.1 (SEPT 23, 2007)
c: Increased fail check time from 0.1 seconds to 0.2 seconds. Should fix some people getting fail when doing a standupbhop.
f: Teleporting to world origin rarely when hopping back and forth between func_door and world brush.
f: Touch is detected even when clients aren't solid. (No more semiclip exploit)
v1.0 (SEPT 21, 2007)
!: Initial release
#include <amxmodx>
#include <engine>
#include <fakemeta>
#define VERSION "1.2"
#define MAX_DOORS 500
#define TSK_BHOP 50
#define TSK_CLEAR_FAIL 100
//func_doors[x]{ id, speed, angles }
new door_count = 0, func_doors[MAX_DOORS][3], Float:door_tp_pos[MAX_DOORS][3]
new bhop_failid[32], bool:bhop_fail[32]
new p_enabled
new MAXPLAYERS
public plugin_init( )
MAXPLAYERS = get_maxplayers( )
register_plugin( "MP Bhops", VERSION, "Ian Cammarata" )
register_cvar( "mpbhops_version", VERSION, FCVAR_SERVER )
p_enabled = register_cvar( "mpbhops", "0", FCVAR_SERVER )
public pfn_keyvalue( ent )
static last_ent
new class[31], key[31], val[31]
copy_keyvalue( class, 30, key, 30, val, 30 )
if( ent != last_ent && func_doors[door_count][0] && door_count < MAX_DOORS )
door_count++
if( equal( class, "func_door" ) )
if( ent != last_ent ) func_doors[door_count][0] = ent
if( equal( key, "speed" ) )
func_doors[door_count][1] = str_to_num(val)
if( equal( key, "dmg" ) )
func_doors[door_count][0] = 0
if( equal( key, "angles" ) )
new angles[5]
parse( val, angles, 4 )
func_doors[door_count][2] = str_to_num( angles )
last_ent = ent
return PLUGIN_CONTINUE
public plugin_cfg( )
if( func_doors[door_count][0] && door_count < MAX_DOORS )
door_count++
new ent, ent2, tmpstr[33]
new Float:dmins[3], Float:dmaxs[3]
//Find tp spots for doors, in case they're used for bhop
for( new i = 0; i < door_count; i++ )
ent = func_doors[0]
if( !is_valid_ent( ent ) ) func_doors[0] = 0
else
entity_get_vector( ent, EV_VEC_mins, dmins )
entity_get_vector( ent, EV_VEC_maxs, dmaxs )
new dwid = floatround( dmaxs[0] - dmins[0] )
new dlen = floatround( dmaxs[1] - dmins[1] )
//If the door moves up, or is thin, remove it's id from the array
if( func_doors[2] < 0 || dwid < 24 || dlen < 24 )
func_doors[0] = 0
//Otherwise find a safe tp spot in case it's a bhop door
else
//If it has a targetname, change the id in array to targeter
entity_get_string( ent, EV_SZ_targetname, tmpstr, 32 )
if( strlen( tmpstr ) )
ent2 = find_ent_by_target( -1, tmpstr )
if( ent2 )
func_doors[0] = ent2
//If targeter is a button, remove it's id from the array
entity_get_string( ent2, EV_SZ_classname, tmpstr, 32 )
if( equal( tmpstr, "func_button" ) )
func_doors[0] = 0
new Float:tmpvec[3], Float:tmpvec2[3]
new Float:dr_tc[3]
dr_tc[0] = ( dmaxs[0] + dmins[0] ) / 2
dr_tc[1] = ( dmaxs[1] + dmins[1] ) / 2
dr_tc[2] = dmaxs[2]
tmpvec[0] = ( dmaxs[0] + dmins[0] ) / 2
tmpvec[1] = dmaxs[1] + 20
tmpvec[2] = dmaxs[2] + 20
trace_line( ent, dr_tc, tmpvec, tmpvec2 )
if( !trace_hull( tmpvec, HULL_HUMAN ) && tmpvec2[2] == tmpvec[2] )
door_tp_pos = tmpvec
else
tmpvec[1] = dmins[1] - 20
else
tmpvec[0] = dmaxs[0] + 20
tmpvec[1] = ( dmaxs[1] + dmins[1] ) / 2
else
tmpvec[0] = dmins[0] - 20
//This is a semiclip fix
public client_PreThink( id )
//If they're on the ground and not solid...
if( ( pev( id, pev_flags ) & FL_ONGROUND ) && !pev( id, pev_solid ) )
new Float rig[3]
entity_get_vector( id, EV_VEC_origin, orig )
//do a hull trace 1 unit below their origin
orig[2] -= 1
engfunc( EngFunc_TraceHull, orig, orig, DONT_IGNORE_MONSTERS, HULL_HUMAN, id, 0 )
new ent = get_tr2( 0, TR_pHit )
//if all we hit is world or another player, who cares, exit
if( ent <= MAXPLAYERS ) return PLUGIN_CONTINUE
//if we hit a door in the array, send it to the handler then exit
new dpos = door_in_array( ent )
if( dpos > -1 )
bhop_check_fail( id, ent, dpos )
//if we hit a BCM entity, force touch so the BCM plugin can handle it
new class[32]
entity_get_string( ent, EV_SZ_classname, class, 31 )
if( equal( class, "bcm" ) || equal( class, "bm_block" ) )
fake_touch( ent, id )
public pfn_touch( ent, id )
if( !get_pcvar_num( p_enabled ) || !ent || !id )
//Make sure id is player and ent is object
if( 0 < ent <= MAXPLAYERS )
new tmp = id
id = ent
ent = tmp
else if( !( 0 < id <= MAXPLAYERS ) )
//Bhop stuff
if( dpos > -1 )
return PLUGIN_HANDLED
public bhop_check_fail( id, ent, dpos )
if( bhop_failid[id-1] != ent )
bhop_failid[id-1] = ent
bhop_fail[id-1] = false
new tskid = TSK_BHOP + id
if( task_exists( tskid ) )
remove_task( tskid )
set_task( 0.2, "bhop_set_fail", tskid )
tskid = TSK_CLEAR_FAIL + id
set_task( 0.7, "bhop_clear_fail", tskid )
else if( bhop_fail[id-1] )
//Teleport to fail position
entity_set_vector( id, EV_VEC_velocity, Float:{0.0, 0.0, 0.0} )
entity_set_vector( id, EV_VEC_origin, door_tp_pos[dpos] )
//Reset fail vars
bhop_failid[id-1] = 0
public door_in_array( door )
if( func_doors[0] == door )
return i
return -1
public bhop_set_fail( tskid )
bhop_fail[ tskid - TSK_BHOP - 1 ] = true
public bhop_clear_fail( tskid )
new id = tskid - TSK_CLEAR_FAIL
