查看: 1387|回复: 13
【分享】给你们一个播放DEMO的脚本(可实现快进,退,暂停)
    奋斗
    2024-3-28 20:13
  • 签到天数: 2 天
    发表于 2008-2-12 20:58:19 | 显示全部楼层 |阅读模式
    鼠标左 显示比分
    F6 相当慢
    F7 比较慢
    F8暂停
    F9比较快
    F10相当快
    // Four-Kings Intel in_eyes demo script for CS
    // If you dont want to use viewdemo
    // or just like to have slowmotion/fastforward
    // binded to a single key.
    // Also very usefull for when people are timing rounds
    // or you want to get rid of those annoying long pauses
    //  Keys being used
    // mouse1 - shows scoreboard
    // f6   - extreme slowmotion
    // f7   - normal slowmotion
    // f8   - pause
    // f9   - normal fastforward
    // f10   - extreme fastforward
    // just press a key twice to go back to normal playback mode
    //  Binds & Aliases
    bind "MOUSE1" "+showscores"
    // The following commands will allow you to fast forward
    // in two differant speeds binded to f9 and f10
    alias fw2on "host_framerate 0.05;alias fw2 fw2off;developer 1;echo Extreme Fastforward;developer 0"
    alias fw2off "host_framerate 0.0;alias fw2 fw2on;developer 1;echo default playback speed;developer 0"
    alias fw2 "fw2on"
    bind "F10" "fw2"
    alias fastforwardon "host_framerate 0.015;alias fastforward fastforwardoff;developer 1;echo Fastforward;developer 0"
    alias fastforwardoff "host_framerate 0.0;alias fastforward fastforwardon;developer 1;echo default playback speed;developer 0"
    alias fastforward "fastforwardon"
    bind "F9" "fastforward"
    // The following command will pause the game and bind it to f8
    alias pauseon "host_framerate 0.0000000001;alias pauser pauseoff;developer 1;echo paused;developer 0"
    alias pauseoff "host_framerate 0.0;alias pauser pauseon;developer 1;echo unpaused;developer 0"
    alias pauser "pauseon"
    bind "F8" "pauser"
    // Two differant speeds for nice slowmotion action shots
    // one is really very slow and the other one is a bit faster
    // binded to f6 & f7
    alias slowmotionon "host_framerate 0.0025;alias slowmotion slowmotionoff;developer 1;echo Slowmotion;developer 0"
    alias slowmotionoff "host_framerate 0.0;alias slowmotion slowmotionon;developer 1;echo default playback speed;developer 0"
    alias slowmotion "slowmotionon"
    bind "F7" "slowmotion"
    alias sw2on "host_framerate 0.0005;alias sw2 sw2off;developer 1;echo Extreme Slowmotion;developer 0"
    alias sw2off "host_framerate 0.0;alias sw2 sw2on;developer 1;echo default playback speed;developer 0"
    alias sw2 "sw2on"
    bind "F6" "sw2"
    echo "mouse1  - shows scoreboard"
    echo "f6   - extreme slowmotion"
    echo "f7   - normal slowmotion"
    echo "f8   - pause"
    echo "f9   - normal fastforward"
    echo "f10   - extreme fastforward"
    echo "just press a key twice to go back to normal playback mode"
    [ 本帖最后由 Simen.Resh@d 于 2008-2-12 22:58 编辑 ]
    发表于 2008-2-12 20:59:18 | 显示全部楼层
    发表于 2008-2-12 21:00:17 | 显示全部楼层
    米总速度快啊
    发表于 2008-2-12 21:06:59 | 显示全部楼层
    这么复杂的
    // 鞍? Binds & Aliases
    // 鞍? -------------------------------------------
    这是什么意思 ?  鞍 ?
    奋斗
    2024-3-28 20:13
  • 签到天数: 2 天
     楼主| 发表于 2008-2-12 21:11:01 | 显示全部楼层
    原帖由 HotmaN 于 2008-2-12 21:06 发表
    这么复杂的
    这是什么意思 ?  鞍 ?
    那是乱码
    不影响使用
    直接全部复制
    或者你下载DEMO.CFG
    发表于 2008-2-12 21:16:52 | 显示全部楼层
    发表于 2008-2-12 21:45:42 | 显示全部楼层
    乱码吖。。。?
    发表于 2008-2-12 21:59:50 | 显示全部楼层
    这个脚本可以自己定义想要的键
    比如 bind "F10" "fw2"
    把里边的F10改成任意键就可以
    发表于 2008-2-12 22:20:18 | 显示全部楼层
    好东西顶!·!!!!!!
    发表于 2008-2-12 22:29:02 | 显示全部楼层
    下了,上厕所 在看
