查看: 1533|回复: 20
[求助]米总的视频`!
发表于 2008-2-9 20:48:50 | 显示全部楼层 |阅读模式
我用快车下米总的东西怎么是这样的?
<!DOCTYPE html
                PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
                "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
        <title>提取文件: Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?- QQ邮箱</title>
        <meta http-equiv="Content-Type" c />
        <link rel="stylesheet" type="text/css" href="http://res_css.mail.qq.com/zh_CN/htmledition20080131/style/qqmail.css" />
                        <link rel="stylesheet" type="text/css" href="http://res_css.mail.qq.com/zh_CN/htmledition20080131/style/skin0.css"/>
                <link rel="stylesheet" type="text/css" href="http://res_css.mail.qq.com/zh_CN/htmledition20080131/style/filetrans.css"/>
        <script type="text/javascript" src="http://res_js.mail.qq.com/zh_CN/htmledition20080131/js/all.js"></script>
        <script type="text/javascript" src="http://res_js.mail.qq.com/zh_CN/htmledition20080131/js/filetransporter.js"></script>
                        <script type="text/javascript">
                    //need Prototype:bind Method
                        try{window.document.domain ="qq.com";}catch(e){}
                        var Ui = new function(){
                                        this.alert = function( msg )
        alert( msg );
                        var Agent = function( url, fileName, description, referUrl, cookie )
                                this.url                        = url ? url : "";
                                this.fileName                = fileName ? fileName : "";
                                this.description        = description ? description : "";
                                this.referUrl                = referUrl ? referUrl : "";
                                this.cookie                        = cookie ? cookie : "";
                                this.fileSize                = "";
                                this.expiredDate    = "";
                                this.linkContainer  = "";
                                this.enabled        = false;
                                this.objectName     = "";
                                this.objectCLSID    = false;
                                this.activeClassName= "txt_title";
                                this.templateDesc = "%_fileName_% \r\n\r\n文件大小:%_fileSize_% \r\n\r\n过期时间:%_expiredDate_% \r\n\r\n下载地址:%_referUrl_%\r\n\r\nQQ邮箱文件中转站";
                                this.msg = {
                                        oldVersion: ""
                                this.state = {
                                        create                : false,
                                        addLink                : false,
                                        launch                : false
                        Agent.prototype.checkAvailable = function()
                                                var _objectId = this.objectCLSID.split("|");
                                                for( var j = 0 ; j < _objectId.length ; j++ )
                                                        try{
        var _tmpObject = new ActiveXObject( _objectId[j] );
        this.enabled = _objectId[j] ;
        delete _tmpObject;
        break;
                                                        catch(e)
        continue;
                        Agent.prototype.activate = function()
                                this.checkAvailable();
                                if( this.enabled )
                                        this.parseDescription();
                                        S( this.linkContainer ).className = S( this.linkContainer ).className + " " + this.activeClassName;
                                        S( this.linkContainer ).title = this.msg.enabledTitle;
                                        S( this.linkContainer ).onclick = this.start.bind(this);
                                        Show( this.linkContainer , true );
                                        Show( "containerDownloadAgents" , true );
                                        Show( "containerDownloadSuggestion" , false );
                                else
                                        S( this.linkContainer ).title = this.msg.disabledTitle;
                                        Show( this.linkContainer , false );
                        Agent.prototype.parseDescription = function()
                                var _desc = this.templateDesc;
                                        _desc = _desc.replace( /%_fileName_%/ig, this.fileName );
                                        _desc = _desc.replace( /%_fileSize_%/ig, this.fileSize );
                                        _desc = _desc.replace( /%_expiredDate_%/ig, this.expiredDate );
                                        _desc = _desc.replace( /%_referUrl_%/ig, this.referUrl );
                                this.description = _desc;
                        var Thunder = function()
                                Agent.apply( this, arguments );
                                this.msg.oldVersion = "您的迅雷版本过低,请下载最新版本。";
                                this.msg.enabledTitle = "使用迅雷下载本文件。";
                                this.msg.disabledTitle = "您还未安装迅雷。";
                                this.objectName     = "Thunder";
                                this.objectCLSID    = "ThunderAgent.Agent|ThunderAgent.Agent.1|ThunderServer.WebThunder.1";
                        Thunder.prototype = new Agent();
                        Thunder.prototype.start = function( )
                                if( !this.enabled )
                                        return false;
                                this.agent = new ActiveXObject( this.enabled );
                                this.state[ "create" ] = true;
                                var tryAddTask = [
                                        function(a) { a.agent.AddTask5(  a.url, a.fileName, "", a.description, a.referUrl, 1, 0, -1, a.cookie, "", "",  1, "", -1 ) },
                                        function(a) { a.agent.AddTask4(  a.url, a.fileName, "", a.description, a.referUrl, 1, 0, -1, a.cookie, "" ) },
                                        function(a) { a.agent.AddTask3(  a.url, a.fileName, "", a.description, a.referUrl, 1, 0, -1, a.cookie ) },
                                        function(a) { a.agent.CallAddTask2( a.url, a.description, a.referUrl, 1, 0, -1, a.cookie); }
                                var tryCommitTasks = [
                                function(a) {a.agent.CommitTasks2(1) },
                                function(a) {a.agent.CommitTasks(1) }
                                for ( var i = 0 ; i < tryAddTask.length ; i ++ )
                                        try {
                                                tryAddTask(this);
                                                this.state[ "addLink" ] = true;
                                                break;
                                        catch(e)
                                if( !this.state[ "addLink" ] )
                                        Ui.alert( this.msg.oldVersion );
                                        return false;
                                for ( var i = 0 ; i < tryCommitTasks.length ; i ++ )
                                        if( this.enabled == "ThunderServer.WebThunder.1" )
                                                this.state[ "launch" ] = true;
                                                Show( "container_descStart" , true );
                                                break;
                                        else
                                                try {
                                                        tryCommitTasks(this);
                                                        break;
                                                catch(e)
                                                        continue;
                        var FlashGet = function()
                                this.msg.oldVersion = "您的快车版本过低,请下载最新版本。";
                                this.msg.enabledTitle = "使用快车下载本文件。";
                                this.msg.disabledTitle = "您还未安装快车。";
                                this.objectName     = "FlashGet";
                                this.objectCLSID    = "FG2CatchUrl.Netscape|JetCar.Netscape";
                        FlashGet.prototype = new Agent();
                        FlashGet.prototype.start = function()
                                if( !this.enabled )
                                        return false;
                                this.agent.AddUrl( this.url, this.description, this.referUrl );
                        var QQDownload = function()
                                this.msg.oldVersion = "您的旋风版本过低,请下载最新版本。";
                                this.msg.enabledTitle = "使用QQ超级旋风下载本文件。";
                                this.msg.disabledTitle = "您还未安装QQ超级旋风。";
                                this.objectName     = "QQDownload";
                                this.objectCLSID    = "QQIEHelper.QQRightClick.2";
                                this.templateDesc = "%_fileName_%";
                        QQDownload.prototype = new Agent();
                        QQDownload.prototype.start = function()
                                if( !this.enabled )
                                        return false;
                                                var ver = this.agent.GetVersion().split(".");
                                                if(parseInt(ver[3]) >= 127)
                                                this.agent.SendUrl2(this.url,this.referUrl,this.description, this.cookie, 0, 10001);
                                                else if(parseInt(ver[3]) > 65)
                                                 this.agent.SendUrl(this.url,this.referUrl,this.description, this.cookie);
                                                else
                        function createDownloadAgents( url, fileName, referUrl, cookie, fileSize, expiredDate )
                                if( !gIsIE )
                                        return false;
                                var _agents = {
                                        //thunder     : new Thunder(),
                                        qqDownload  : new QQDownload()
                                        //flashGet    : new FlashGet()
                                for( var i in _agents )
                                        _agents.url = url;
                                        _agents.fileName = fileName;
                                        _agents.referUrl = referUrl;
                                        _agents.cookie = cookie;
                                        _agents.fileSize = fileSize;
                                        _agents.expiredDate = expiredDate;
                                        _agents.linkC + i;
                                        _agents.activate();
                                //Show( "containerDownloadAgents" , true );
                </script>
        var fileServerUrl = "t.exs.mail.qq.com";
        var formActi;
        Global.serverTime = 1202561214;
        location.getParams();
        window.onload = function(){ try{S("fc").focus();}catch(e){} };
        </script>
    <style type="text/css">
        .infobar { margin-right:10px; }
        .content { padding-right:0; }
        .txt_title { cursor:pointer; text-decoration:underline;padding-left:16px;background:url() no-repeat 0 0; };
        .agentLink { font-size:12px;display:block;float:left;font-size:12px;margin-right:20px;line-height:120%; }
        </style>
</head>
<body>
        <div class="container">
                <div class="header">
                                                        <a href="http://mail.qq.com"><img src="http://res_css.mail.qq.com/zh_CN/htmledition20080131/images/spacer.gif" class="logo" alt="" /></a>
                        <div class="topNavigation readmailinfo" style="border-bottom:0px solid #fff;">
                                <h1 style="display:block;">提取文件</h1>
                                <div class="naviBar">
                                        <!--<a href="/cgi-bin/loginpage">进入邮箱</a>-->
                                </div>
                        </div>
                        <hr />
                </div>
                <div class="content">
                         <div class="downloadFileContainer" style="display:block;" id="getFileInfo">
                                <div id="msgError" class="infobar infobarProcess" style="">
                                正在获取文件信息……
                                </div>
                        </div>
                         <div class="downloadFileContainer" style="display:none;" id="msgExpired2">
                                您提取的文件已过期。
                                </div>
                        </div>
                         <div class="downloadFileContainer" style="display:none;" id="fileDeleted">
                                您提取的文件不存在或已被删除。
                                </div>
                        </div>
            <div class="downloadFileContainer" style="display:none;" id="downloadFileContainer">
                <h1>提取文件</h1>
                <hr />
                <p class="addrtitle">您要提取的文件:</p>
                <h2 style="float:none;font-size:16px;width:100%;white-space:nowrap;overflow:hidden;text-overflow:ellipsis;" title="Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?>Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?/h2>
                <p><span class="" style="font-size:12px;">文件大小:490.43MB</span></p>
                                <p><span class="" style="font-size:12px;">有效时间:<span id="atime" ><span  class="addrtitle">正在获取…</span></span></span></p>
                <div id="msgExpired" class="infobar infobarProcess" style="display:none;">
                    您提取的文件已过期。
                </div>
                <div style="margin-top:6px;">
        </div>
                <div class="downloadContainer" id="downloadContainer" style="word-wrap:break-word;word-break:break-all;white-space:normal;line-height:160%;">
                    <div class="" style="display:none;margin-right:16px;">
                        <span class="addrtitle">点击以下链接开始下载:</span><br/>
                        var _url = "";
                            if( !gIsIE ) _url += "<div style='padding:10px;border:1px solid #ccc;background:#fff;overflow:auto;overflow-y:none;'>";
                            _url += "<a href='http://t.exs.mail.qq.com/cgi-bin/downloadfilepart/svrid31/Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?svrid=31&fid=ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47&&txf_fid=&&txf_sid=164af36c56acd9a4581bcc77da5313b29d431e29&fn=Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT? style='word-wrap:break-word;word-break:break-all;white-space:normal;line-height:160%;width:100%;display:block;'  >http://t.exs.mail.qq.com/cgi-bin ... svrid31/Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?svrid=31&fid=ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47&&txf_fid=&&txf_sid=164af36c56acd9a4581bcc77da5313b29d431e29&fn=Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?/a>";
                            if( !gIsIE ) _url += "</div>";
        </script>
                                                <div style="margin:20px 0 0 0;display:none;" id="containerDownloadAgents">
                                                        <p class="addrtitle" style="clear:both;margin-bottom:6px;"> </p>
                                                        <span id="container_qQDownload" class="addrtitle agentLink" style="" title="">用QQ超级旋风下载本文件</span>
                                                        <!-- <span id="container_thunder" class="addrtitle agentLink" title="">用迅雷下载</span> -->
                                                        <!--<span id="container_flashGet" class="addrtitle agentLink" title="" >用快车下载</span>-->
                                                        <p id="container_descStart" class="addrtitle" style="display:none;clear:both;"></p>
                                                        <p class="addrtitle"  style="clear:both;">如使用其他软件下载,请使用较新版本以防止出现无法正确下载的情况。</p>
                                                </div>
                                                <div style="margin:20px 0 0 0;display:none;" id="containerDownloadSuggestion">
                                                        <p class="addrtitle" style="clear:both;margin-bottom:6px;"><img src="http://res_css.mail.qq.com/zh_CN/htmledition20080131/images/spacer.gif" style="background:url(/zh_CN/htmledition/images/ico.gif) -40px -227px no-repeat;width:15px;height:14px;border:none;margin:0 4px 0 0;vertical-align:middle;" />推荐您安装 <a href="http://im.qq.com/cyclone/download.shtml" title="超级旋风是一款下载软件,支持多个任务同时进行,每个任务使用多地址下载、多线程、断点续传、线程连续调度优化,下载速度快,无广告,无流氓插件,完全免费。 " target="_blank" >超级旋风</a> 高速稳定地进行下载本文件。</p>
                                                        <p class="addrtitle">如使用其他软件下载,请使用较新版本以防止出现无法正确下载的情况。</p>
                                                </div>
                    </div>
                    <div style="display:block;" >
                        <form id="getFile" name="getFile" method="post" action="/cgi-bin/exs_download"  >
                            <label for="fc" class="addrtitle">请填写文件的提取码获取下载地址:</label><br/>
                            <input type="text" autocomplete="off" name="code" id="fc" cols="45" rows="5" /> <input type="hidden" name="flag" value="1" /><input type="submit" name="btn_submit" id="btn_submit"  class="btn" value=" 确定 "  style="line-height:120%!important;" />
                            <input type="hidden" name="fid" value="ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47" />
                            <input type="hidden" name="uin" value="455633986" />
                            <input type="hidden" name="svrid" value="31" />
                        </form>
                    </div>
                </div>
            </div>
                        <div class="downloadAdContainer">
                    <div style="padding:0 10px 0 20px;">
                <p style="font-size:12px;margin-top:0px;">此文件来自QQ邮箱“文件中转站”。</p>
                <p class="addrtitle">几百M的照片包、设计图,用QQ邮箱也可以发了。<a href="http://service.mail.qq.com/cgi-bin/help?subtype=1&&id=35&&no=243" target="_blank">了解“超大附件”</a></p>
                <p class="addrtitle">拥有G级存储空间,能上传1G的文件。<a href="http://service.mail.qq.com/cgi-bin/help?subtype=1&&id=35&&no=244" target="_blank">了解“文件中转站”</a></p>
                </div>
            </div>
            <div class="downloadFileContainer" style="display: none">
                您提取的文件不存在或已被删除。
                </div>
            </div>
                    try{
                S("fc").value = ( "" != "" ? "" : "" );
                checkExpiredDate( "1202510124", "7"  );
                                catch(e){}
                                var fileName = "Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?;
                                var url = "http://t.exs.mail.qq.com/cgi-bin/downloadfilepart/svrid31/Bigrice.wmv|{-z7ab30?jmj3;;h448煘藵aT?svrid=31&fid=ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47&&txf_fid=&&txf_sid=164af36c56acd9a4581bcc77da5313b29d431e29";
                                var fileSize = "490.43MB";
                                var uin = "455633986";
                                var referUrl = location.href + "?uin=455633986&svrid=31&fid=ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47";
                                var expiredDate = 1202510124;
                                if( gIsIE )
                                        Show( "containerDownloadSuggestion" , true );
        </script>
                </div>
                <div class="footer">
                        <hr />
                        <span>
                                &copy; 1998 - 2008 Tencent Inc. All Rights Reserved
                        </span>
                </div>
        </div>
function updateFileDate()
                var _target = S( "getFileData" ).contentWindow;
        var _uploadCompleteData =_target.uploadCompleteDate;
        var _fileExpriedDays = _target.fileExpriedDays;
        if(  _uploadCompleteData && _fileExpriedDays  )
                if( _uploadCompleteData != -1 )
                        S( "atime" ).innerHTML = getAvailableTime( _uploadCompleteData, _fileExpriedDays );
                        Show( "getFileInfo" , false );
                        Show( "downloadFileContainer" , true );
                else if( _uploadCompleteData != -2 )
                else
                        Show( "msgExpired2" , true );
</script>
<div id="ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47_dl" style="display:none;">0</div>
<iframe id="static" src="" width="1" height="1" frameborder="0" scrolling="no"></iframe>
<iframe id="getFileData" src="http://t.exs.mail.qq.com/cgi-bin/downloadfilepart?svrid=31&fun=getinfo&fid=ab303faf805f99523f0476a7de72606b4be5f2b1dd825c47" width="1" height="1" frameborder="0" scrolling="no"  style="display:none;"></iframe>
<!--t.exs.mail.qq.com-->
</body>
</html>
发表于 2008-2-9 20:50:07 | 显示全部楼层
把你邮箱告诉我
我发给你
五分钟之内查收
谢谢合作
顺便说
谁下不了的把邮箱留下
我都发
等小巍传完ftp你们就下ftp的
感谢合作
 楼主| 发表于 2008-2-9 20:50:54 | 显示全部楼层
谢谢哦~~我没邮箱杂办?
发表于 2008-2-9 20:50:59 | 显示全部楼层
网际快车是垃圾!
没别的!
 楼主| 发表于 2008-2-9 20:55:05 | 显示全部楼层
我觉的快车比迅雷好啊,我原来用迅雷的/但是速度很糟糕,所以我伤心了。`!
发表于 2008-2-9 20:55:56 | 显示全部楼层
我用的超级旋风,,1个字.爽...!!
发表于 2008-2-9 20:57:37 | 显示全部楼层
我用迅雷,不过qq中转站是目标另存为的,速度一样快
 楼主| 发表于 2008-2-9 20:57:43 | 显示全部楼层
我听你们的。。那什么最好用呢?推荐下
发表于 2008-2-9 20:57:48 | 显示全部楼层
395274783@qq.com
谢谢拉
 楼主| 发表于 2008-2-9 21:00:28 | 显示全部楼层
QQ邮箱也行啊。那谢谢勒`251075078@qq.com
