查看: 1915|回复: 4
【资源】地图编译工具--高手专用
发表于 2007-12-25 09:31:59 | 显示全部楼层 |阅读模式
zhlt34x64final.zip (357 KB, 下载次数: 19)
zhlt34x86final.zip (714.89 KB, 下载次数: 16)
batchcompiler312.rar (340.3 KB, 下载次数: 25)
If you recive runtime errors, please download the Visual C++ 2005 Runtime Libraries Package:
Source code:
ZHLT 3.4 final source code
About:
Batch Compiler v3.1.2 - Batch Compiler and all the files you need to run it (except the .NET Framework).
Runtimes: (Required)
.NET Framework v1.1 (23,698 KB Executable) - Batch Compiler is written in C# .NET and as such requires the .NET runtime to run. The .NET runtime is also available as a Windows Update. v1.1 is required.
Download:
Half-Life Compiled:
Half-Life Compiled - Batch Compiler and all the files you need to run it (except the .NET Framework). Half-Life Compiled is a third party installer which will automatically set Batch Compiler up for you. Note: Half-Life Compiled comes with other 3rd party utilities (such as Zoners) and uses a customized set of the official Batch Compiler specifications.
Download:
根据自己系统类型来选择不同的程序
32位选择86
64位选择64
[ 本帖最后由 Simen.sllove 于 2007-12-25 09:49 编辑 ]
发表于 2007-12-25 10:13:49 | 显示全部楼层
所长的东西 我看不懂哈
    奋斗
    2024-12-15 16:25
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2007-12-25 11:49:42 | 显示全部楼层
    有些东西能看懂.
      有些不行.
    该怎么解释. 说下。
    发表于 2007-12-25 18:42:15 | 显示全部楼层
    所长 你把我丢掉了
    圣诞快乐`
    发表于 2008-1-1 23:45:46 | 显示全部楼层
    郁闷.. 我又想学做图又想学做视频
