查看: 2251|回复: 9
[求助]编译出错,来个专业的救命
发表于 2007-12-14 21:35:24 | 显示全部楼层 |阅读模式
hlcsg v2.5.3 rel (May  2 2001)
Based on Valve's version, modified with permission.
Submit detailed bug reports to (zoner@gearboxsoftware.com)
-----  BEGIN  hlcsg -----
Command line: E:\create\tools\hlcsg.exe E:\create\maps\KZcn_hp_XiaoLongPrecincts
-= Current hlcsg Settings =-
Name                 |  Setting  |  Default
threads               [       1 ] [  Varies ]
verbose               [     off ] [     off ]
log                   [      on ] [      on ]
developer             [       0 ] [       0 ]
chart                 [     off ] [     off ]
estimate              [     off ] [     off ]
max texture memory    [ 4194304 ] [ 4194304 ]
priority              [  Normal ] [  Normal ]
noclip                [     off ] [     off ]
onlyents              [     off ] [     off ]
wadtextures           [      on ] [      on ]
skyclip               [      on ] [      on ]
hullfile              [    None ] [    None ]
min surface area      [   0.500 ] [   0.500 ]
brush union threshold [   0.000 ] [   0.000 ]
Wadinclude list :
[zhlt.wad]
entering E:\create\maps\kzcn_hp_XiaoLongPrecincts.map
CreateBrush:
Error: Entity 0, Brush 210: outside world(+/-4096): (-4112,-3376,-644)-(1552,-2544,-540)
Error: brush outside world
Description: The map has a problem which must be fixed
Howto Fix: Check the file ZHLTProblems.html for a detailed explanation of this problem
Error: Entity 0, Brush 210: outside world(+/-4096): (-4128,-3392,-640)-(1568,-2528,-544)
Error: Entity 0, Brush 210: outside world(+/-4096): (-4112,-3376,-626)-(1552,-2544,-558)
Error: Entity 0, Brush 212: outside world(+/-4096): (-4112,-3376,-1188)-(-4047,-2544,-572)
Error: Entity 0, Brush 212: outside world(+/-4096): (-4128,-3392,-1184)-(-4031,-2528,-576)
Error: Entity 0, Brush 212: outside world(+/-4096): (-4112,-3376,-1170)-(-4047,-2544,-590)
Error: Entity 0, Brush 213: outside world(+/-4096): (-4112,-3376,-1220)-(1552,-2544,-1116)
Error: Entity 0, Brush 213: outside world(+/-4096): (-4128,-3392,-1216)-(1568,-2528,-1120)
Error: Entity 0, Brush 213: outside world(+/-4096): (-4112,-3376,-1202)-(1552,-2544,-1134)
(0.67 seconds)
-----   END   hlcsg -----
hlbsp v2.5.3 rel (May  2 2001)
-----  BEGIN  hlbsp -----
Command line: E:\create\tools\hlbsp.exe E:\create\maps\kzcn_hp_XiaoLongPrecincts
>> There was a problem compiling the map.
>> Check the file E:\create\maps\kzcn_hp_XiaoLongPrecincts.log for the cause.
-----   END   hlbsp -----
hlrad v2.5.3 rel (May  2 2001)
-----  BEGIN  hlrad -----
Command line: E:\create\tools\hlrad.exe -extra E:\create\maps\kzcn_hp_XiaoLongPrecincts
-----   END   hlrad -----
我不懂英文,也不太会做图,找了半个多小时还是不知道自己错在哪里,来个专业的帮帮我,谢谢!
发表于 2007-12-14 22:00:06 | 显示全部楼层
好复杂的东西!!看的头都晕了!
发表于 2007-12-14 23:08:19 | 显示全部楼层
我还以为是什么语言呢...晕..
发表于 2007-12-15 06:25:13 | 显示全部楼层
麻烦知道怎么解决这个错误的说一下呀
发表于 2007-12-15 10:10:00 | 显示全部楼层
210号固体
212号固体
213号固体
超出范围~
解决方法:
1.确保地图的边界在允许的范围之内
2.重做这三个固体
发表于 2007-12-15 20:14:29 | 显示全部楼层
哈哈,所长说的和我告诉你的一样吧,超出范围。
问题就是怎么找到这3个固体
发表于 2007-12-16 20:10:38 | 显示全部楼层
ctrl+shift+G
发表于 2007-12-17 21:43:33 | 显示全部楼层
原帖由 Simen.sllove 于 2007-12-16 20:10 发表
ctrl+shift+G
这哥们在群里问了半天 早来发帖不就没事了吗
不愧是所长
发表于 2008-1-2 02:40:52 | 显示全部楼层
HP不好,赶快改地图名,现在挂kzcn的名字是先要由赛盟地图小组审核的
发表于 2008-1-2 03:01:23 | 显示全部楼层
还是所长牛X  这是做图我们不专业啊
