查看: 599|回复: 3
kz_kzfr_bhopwaterrace<--- 誰知怎麼跳?????
发表于 2007-10-6 22:56:00 | 显示全部楼层 |阅读模式
发表于 2007-10-6 23:04:00 | 显示全部楼层
回复:kz_kzfr_bhopwaterrace<--- 誰知怎麼跳?????
没跳过,这个还是多跳就知道拉
发表于 2007-10-6 23:10:00 | 显示全部楼层
AXN
A metamod-plugin (Ask on #kzmaps or our forums if you are unsure how to use this) which makes it possible to bhop (Bunnyhop) without slowing the speed down when hitting ground after jumping and gives extra speed while jumping. This plugin is used only in specific bhop-maps and not in ordinary jumping maps. This cannot be used when recording demos for publishing.
got it?
发表于 2007-10-6 23:23:00 | 显示全部楼层
回复: kz_kzfr_bhopwaterrace<--- 誰知怎麼跳?????
我加得不好,应该可以到五六百甚至更高的...
