查看: 771|回复: 1
CS自动根据MAC地址分配CDKEY,修改显示设置的批处理
发表于 2007-9-7 08:51:00 | 显示全部楼层 |阅读模式
@ECHO OFF
@CLS
@ECHO [COMPUTERNAME] [MACADDRESS] [IPADDRESS] [CS-CDKEY] >CONFIG.CFG
@ECHO X01 00-E0-4C-C7-B3-88 192.168.0.11 3005789616110 >>CONFIG.CFG
@ECHO X02 00-E0-4C-80-5D-14 192.168.0.12 3005789616110 >>CONFIG.CFG
@ECHO X03 00-C0-26-AB-0A-E6 192.168.0.13 3005789616110 >>CONFIG.CFG
@ECHO X04 00-E0-4C-B6-32-EB 192.168.0.14 3005789616110 >>CONFIG.CFG
@ECHO X05 00-E0-4C-A0-41-11 192.168.0.15 3005789616110 >>CONFIG.CFG
@ECHO X06 00-E0-4C-21-7D-68 192.168.0.16 2498521763020 >>CONFIG.CFG
@ECHO X07 00-E0-4C-81-C0-44 192.168.0.17 2498521763020 >>CONFIG.CFG
@ECHO X08 00-E0-4C-21-7D-7B 192.168.0.18 2498521763020 >>CONFIG.CFG
@ECHO X09 00-E0-4C-C1-7F-BF 192.168.0.19 2498521763020 >>CONFIG.CFG
@ECHO X10 00-E0-4C-A0-F8-6C 192.168.0.20 2498521763020 >>CONFIG.CFG
::获取机器的TCP/IP配置
IF EXIST IPCONFIG.TXT DEL IPCONFIG.TXT
IPCONFIG /ALL >IPCONFIG.TXT
::分离出机器的物理地址,并保存到(PHYADDR.TXT)文件中
IF EXIST PHYADDR.TXT DEL PHYADDR.TXT
FIND &quothysical Address" IPCONFIG.TXT &gtHYADDR.TXT
::从(PHYADDR.TXT)文件中取得物理地址字符串,并赋给变量"MacAddress"
FOR /F "SKIP=2 TOKENS=12" %%M IN (PHYADDR.TXT) DO SET STRMAC=%%M
::显示物理地址字符串
@ECHO %STRMAC%
::以变量"strMac"为关键字搜索(Config.cfg)中相同的字符串行,并保存到(ComputerCfg.txt)
FIND "%STRMAC%" CONFIG.CFG >COMPUTERCFG.TXT
::显示机器名. (从"ComputerCfg.txt"中分离出 机器名字段,并赋给变量"ComputerName")
FOR /F "SKIP=2 TOKENS=1" %%N IN (COMPUTERCFG.TXT) DO SET COMPUTERNAME=%%N
@ECHO %COMPUTERNAME%
::显示IP地址. (从"ComputerCfg.txt"中分离出 IP地址字段,并赋给变量"IPAddress")
FOR /F "SKIP=2 TOKENS=3" %%I IN (COMPUTERCFG.TXT) DO SET IPADDRESS=%%I
@ECHO %IPADDRESS%
::显示网卡MAC地址.(从"ComputerCfg.txt"中分离出 MAC地址字段,并赋给变量"MacAddress")
FOR /F "SKIP=2 TOKENS=2" %%M IN (COMPUTERCFG.TXT) DO SET MACADDRESS=%%M
@ECHO %MACADDRESS%
FOR /F "SKIP=2 TOKENS=4" %%C IN (COMPUTERCFG.TXT) DO SET STRCDKEY=%%C
@ECHO %STRCDKEY%
::写入注册表
IF EXIST INSTALL.REG DEL INSTALL.REG
@ECHO Windows Registry Editor Version 5.00 >>INSTALL.REG
@ECHO [HKEY_CURRENT_USER\Software\Valve] >>INSTALL.REG
@ECHO [HKEY_CURRENT_USER\Software\Valve\CounterStrike] >>INSTALL.REG
@ECHO "InstallPath"="D:\\GAMES\\CS反恐精英1.5" >>INSTALL.REG
@ECHO "Full Name"="Half-Life: Counter-Strike" >>INSTALL.REG
@ECHO [HKEY_CURRENT_USER\Software\Valve\CounterStrike\Recent File List] >>INSTALL.REG
@ECHO [HKEY_CURRENT_USER\Software\Valve\CounterStrike\Settings] >>INSTALL.REG
@ECHO "key"="%STRCDKEY%" >>INSTALL.REG
@ECHO "Version"=dword:00000001 >>INSTALL.REG
@ECHO "LauncherBPP"=dword:00000010 >>INSTALL.REG
@ECHO "LauncherWidth"=dword:00000280 >>INSTALL.REG
@ECHO "LauncherHeight"=dword:000001e0 >>INSTALL.REG
@ECHO "EngineGLDriver"="Default" >>INSTALL.REG
@ECHO "EngineD3DDevice"="Default" >>INSTALL.REG
@ECHO "EngineType"=dword:00000002 >>INSTALL.REG
@ECHO "EngineModeW"=dword:00000320 >>INSTALL.REG
@ECHO "EngineModeH"=dword:00000258 >>INSTALL.REG
@ECHO "EngineModeBPP"=dword:00000010 >>INSTALL.REG
@ECHO "EngineModeCaptured"=dword:00000001 >>INSTALL.REG
@ECHO "A3D Support"=dword:00000000 >>INSTALL.REG
@ECHO "EngineModeWindowed"=dword:00000000 >>INSTALL.REG
@ECHO "CPUMHZ"=dword:00000000 >>INSTALL.REG
@ECHO "EngineMode"=dword:00000007 >>INSTALL.REG
@ECHO "3DWarning"=dword:00000001 >>INSTALL.REG
@ECHO "Logo"="8ball1.bmp" >>INSTALL.REG
@ECHO "Logo Color"="Orange" >>INSTALL.REG
::导入注册表
REGEDIT /S INSTALL.REG
D:\GAMES\CS反恐精英1.5\CSTRIKE.EXE -console -numericping
调用批处理不显示窗口的VBS脚本
DIM objShell
set objShell=wscript.createObject("wscript.shell")
iReturn=objShell.Run("cmd.exe /C D:\GAMES\CS反恐精英1.5\RUN.BAT", 0, TRUE)
发表于 2007-9-7 21:54:00 | 显示全部楼层
回复:CS自动根据MAC地址分配CDKEY,修改显示设置的批处理
这个太NB了  还是根据注册表读取CS目录的
