查看: 1911|回复: 4
我是新手,遇到问题啦
发表于 2007-7-29 10:45:00 | 显示全部楼层 |阅读模式
我的vhe3.5设置是照论坛上那样设置的,但是编译地图的时候出来这个
然后点击是之后,出来这个
** Executing...
** Command: Change Directory
** Parameters: D:\游戏\Cs1.6中文版
** Executing...
** Command: Copy File
** Parameters: "D:\应用软件\Valve Hammer Editor 3.map" "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3.map"
The command failed. Windows reported the error:
  "系统找不到指定的文件。"
** Executing...
** Command: D:\应用软件\VALVEH~1.5_C\tools\hlcsg.exe
** Parameters: "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3"
hlcsg v2.5.3 rel (May  2 2001)
Based on Valve's version, modified with permission.
Submit detailed bug reports to (zoner@gearboxsoftware.com)
-----  BEGIN  hlcsg -----
Command line: D:\应用软件\VALVEH~1.5_C\tools\hlcsg.exe "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3"
-= Current hlcsg Settings =-
Name                 |  Setting  |  Default
threads               [       1 ] [  Varies ]
verbose               [     off ] [     off ]
log                   [      on ] [      on ]
developer             [       0 ] [       0 ]
chart                 [     off ] [     off ]
estimate              [     off ] [     off ]
max texture memory    [ 4194304 ] [ 4194304 ]
priority              [  Normal ] [  Normal ]
noclip                [     off ] [     off ]
onlyents              [     off ] [     off ]
wadtextures           [      on ] [      on ]
skyclip               [      on ] [      on ]
hullfile              [    None ] [    None ]
min surface area      [   0.500 ] [   0.500 ]
brush union threshold [   0.000 ] [   0.000 ]
Wadinclude list :
[zhlt.wad]
Error: Error opening D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3.map: No such file or directory
-----   END   hlcsg -----
** Executing...
** Command: D:\应用软件\VALVEH~1.5_C\tools\hlbsp.exe
hlbsp v2.5.3 rel (May  2 2001)
-----  BEGIN  hlbsp -----
Command line: D:\应用软件\VALVEH~1.5_C\tools\hlbsp.exe "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3"
>> There was a problem compiling the map.
>> Check the file D:\应用软件\Valve Hammer Editor 3.log for the cause.
-----   END   hlbsp -----
** Executing...
** Command: D:\应用软件\VALVEH~1.5_C\tools\hlvis.exe
hlvis v2.5.3 rel (May  2 2001)
-----  BEGIN  hlvis -----
Command line: D:\应用软件\VALVEH~1.5_C\tools\hlvis.exe "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3"
-----   END   hlvis -----
** Executing...
** Command: D:\应用软件\VALVEH~1.5_C\tools\hlrad.exe
** Parameters: -extra "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3"
hlrad v2.5.3 rel (May  2 2001)
-----  BEGIN  hlrad -----
Command line: D:\应用软件\VALVEH~1.5_C\tools\hlrad.exe -extra "D:\应用软件\Valve Hammer Editor 3.5[CS地图制作软件]\maps\Valve Hammer Editor 3"
-----   END   hlrad -----
编译出来的地图文件,后缀文件名字都没有,不知道是啥问题
 楼主| 发表于 2007-7-29 10:52:00 | 显示全部楼层
回复: 我是新手,遇到问题啦
CS1.6目录
 楼主| 发表于 2007-7-29 10:55:00 | 显示全部楼层
回复: 我是新手,遇到问题啦
发表于 2009-3-4 13:55:47 | 显示全部楼层
lx解答 我没见过这事 我做了好几个图乐
发表于 2009-3-11 23:33:22 | 显示全部楼层
路径最好不要有中文 这样很容易出错 编译的程序最好和CS放同一个盘符下
