查看: 1565|回复: 2
007来,看看这是什么错误
发表于 2007-7-22 16:42:00 | 显示全部楼层 |阅读模式
MakeScales:
Error: Memory allocation failure
Description: The program failled to allocate a block of memory.
Howto Fix: Likely causes are (in order of likeliness) : the partition holding the swapfile is full; swapfile size is smaller than required; memory fragmentation; heap corruption
没见过这种错误
发表于 2007-7-24 17:31:00 | 显示全部楼层
回复:007来,看看这是什么错误
内存太少    +内存吧   或者把虚拟内存调得大点   起码调到1G以上
发表于 2007-7-25 18:16:00 | 显示全部楼层
回复:007来,看看这是什么错误
382夠了...
