查看: 2128|回复: 16
教你如何用同一键录DEMO和停止录DEMO
发表于 2007-4-18 19:26:00 | 显示全部楼层 |阅读模式
很多人都不会录制DEMO,今天我就教大家一种一键录制和停止的录DEMO方法
首先,找到你的CS安装文件夹.寻找 cstrike_schinese(有些版本 cstrike) 文件夹 ,找到后再寻找 config.cfg 文件,用记事本打开.再
在里面添加以下内容:   bind "录demo的键" "demo"  并保存.添加后就会实现你希望的键按下就录DEMO了,再按一次就会停止录制.
完成了上一步之后,还不行.还要输入脚本数据,再在 cstrike_schinese(有些版本 cstrike) 文件夹里寻找 userconfig.cfg(又2个文件
很象的不要搞错) 也是用记事本打开添加以下内容:
alias demo "demo1"
alias demo1 "alias demo demo2; record demo1; developer 1; echo --- Recording demo #1 ---; developer 0"
alias demo2 "alias demo demo3; stop; developer 1; echo --- Stopped demo #1 ---; developer 0"
alias demo3 "alias demo demo4; record demo2; developer 1; echo --- Recording demo #2 ---; developer 0"
alias demo4 "alias demo demo5; stop; developer 1; echo --- Stopped demo #2 ---; developer 0"
alias demo5 "alias demo demo6; record demo3; developer 1; echo --- Recording demo #3 ---; developer 0"
alias demo6 "alias demo demo7; stop; developer 1; echo --- Stopped demo #3 ---; developer 0"
alias demo7 "alias demo demo8; record demo4; developer 1; echo --- Recording demo #4 ---; developer 0"
alias demo8 "alias demo demo9; stop; developer 1; echo --- Stopped demo #4 ---; developer 0"
alias demo9 "alias demo demo10; record demo5; developer 1; echo --- Recording demo #5 ---; developer 0"
alias demo10 "alias demo demo11; stop; developer 1; echo --- Stopped demo #5 ---; developer 0"
alias demo11 "alias demo demo12; record demo6; developer 1; echo --- Recording demo #6 ---; developer 0"
alias demo12 "alias demo demo13; stop; developer 1; echo --- Stopped demo #6 ---; developer 0"
alias demo13 "alias demo demo14; record demo7; developer 1; echo --- Recording demo #7 ---; developer 0"
alias demo14 "alias demo demo15; stop; developer 1; echo --- Stopped demo #7 ---; developer 0"
alias demo15 "alias demo demo16; record demo8; developer 1; echo --- Recording demo #8 ---; developer 0"
alias demo16 "alias demo demo1; stop; developer 1; echo --- Stopped demo #8 ---; developer 0"
以上的脚本设置了自动生成8个DEMO.具体操作:进入CS后,当你要录DEMO的时候.按一下你设置的按键(我设置为  F1  .但是这些按键不要和其他的脚本按键相同,不言其他的按键就失效了) 开始录制.当你想停止录DEMO的时候你再按一下你设置的按键.屏幕上就会显示:你已经有一个了! 你录制的DEMO就在 cstrike_schinese(有些版本 cstrike) 文件夹里 DEMO的名称分别为:demo1.dem----demo8.dem
好了不说了希望大家能录出世界记录的DEMO吧为中国的KZ增光。
发表于 2007-4-18 20:28:00 | 显示全部楼层
回复:教你如何用同一键录DEMO和停止录DEMO
先顶,太复杂
发表于 2007-4-18 20:30:00 | 显示全部楼层
恩,有的人喜欢这样,可以做参考
发表于 2007-4-18 20:31:00 | 显示全部楼层
顶一下  虽然偶现在不怎么玩 KZ了`
 楼主| 发表于 2007-4-18 21:30:00 | 显示全部楼层
LJ记录就是这么刷出来的
一点都不复杂
发表于 2007-4-18 21:49:00 | 显示全部楼层
日 你转同盟的东西...
发表于 2007-4-19 02:43:00 | 显示全部楼层
看不懂
发表于 2007-4-19 10:54:00 | 显示全部楼层
说一个比较方便的方法:
在建好游戏之后打开控制台输入:
bind F1 "stop; record demo_name; sv_restart 1;"回车
bind F2 "stop;"回车
就是说你按F1就可以开始重新录DEMO了,如果录制结束的话按F2,不过在按F2前别忘记自杀!
发表于 2007-4-19 11:07:00 | 显示全部楼层
还是5J厉害!偶像!我亲你一下!
 楼主| 发表于 2007-4-19 12:21:00 | 显示全部楼层
哪有5J?
