查看: 1506|回复: 1
[分享]Abstrusity
发表于 2007-3-9 17:11:00 | 显示全部楼层 |阅读模式
<>http://dv.ouou.com/swf/ouou.swf?id=38d7f3fcac9b7</P>
<>点击下载</P>
<>This is my political, spiritual, abstract, satirical, comedic, epic, dramatic machinima...<br>...with frags.</P>
<P>It's called Abstrusity.</P>
<P>See if you can get as much out of it as I did.</P>
<P>The songs are instrumentals played on the piano of Linkin Park's Numb and Crawling.</P>
<P>There's a meaning to everything you see in the movie.  Good luck.</P>
<P>Thanks to cristal for the inspiration and Kindred for understanding.</P>
[此贴子已经被作者于2007-3-9 17:16:25编辑过]
发表于 2007-3-13 11:25:00 | 显示全部楼层
<>狂顶</P>
