查看: 2066|回复: 18
EB蹲的技巧
发表于 2007-2-24 08:43:00 | 显示全部楼层 |阅读模式
<>下面这段转自xj,我自己翻的,不知大家是否看的明白:</P>
<>DaMp also found a new way of making edgebug! He explayns how to do it: </P>
<>"Guys, I want to show you how to do a duckbhop. <BR>- First you have to search the right place. The right place is when one not straight wall ends and another wall starts the second wall should be more straight than the first one. <BR>- Than you jump with a normal jump and strafe a bit not much. Only a bit... after the strafe you still have to press the strafe key but now you duck... <BR>- After that you've done an Duck-edgebug... <BR>If you do all right and have the richt place it works... <BR><BR>Sometimes this duckedgebug looks pretty cool. There are places in Maps where you can do it and you'll see a new shortcut. This edgebug is possible when there are two brushes (walls/blocks) with a different form like different angles of the walls. Sometimes you can do it on crazy places in maps... <BR>By building a Map this mistake will be generated. This is the reason of the "wallbug" <BR>too... Don't be annoyed about this things. A small advice from me: Don't jump to close to walls <BR>witch are worked on with the vertex-tool or were cliped... This means if the wall isn't straight <BR>and flat. </P>
<P>I hope i helped you. Greetz DaMp</P>
<P>一个叫DaMp的人发现了一种新的eb方法.他的说明:</P>
<P>首先是寻找可以eb的落点.就是:一面边缘不是直线的墙(不是长方形的那种)和另一面相对边缘是直线的墙.(这里应该是指两个墙面垂直相交)</P>
<P>然后你就用普通的跳再加旋转,旋一点点就可以了.不用很多.就一点...旋完后你仍然要按着旋的方向按钮(a或d),然后按蹲..</P>
<P>你就完成了一个蹲的eb.</P>
<P>这可以用于两个有着各自不同角度的墙的接触的地方(墙/砖块),</P>
<P>随着制图这个错误会被改正.这是由于"wallbug"的原因造成的.</P>
<P>我的一个小意见:不要跳到靠近用"vertex-tool"修改过的墙.这是指表面不平滑和不是直线的墙.</P>
<P>附加作者DaMp的KZ_man_dinocanyon的演示demo:</P>[upload=rar]viewFile.asp?ID=7689[/upload]<BR>
发表于 2007-2-24 10:37:00 | 显示全部楼层
似乎懂了[em06]
发表于 2007-2-24 11:03:00 | 显示全部楼层
我坚决不潜水!我灌!!![em02]
发表于 2007-2-24 11:30:00 | 显示全部楼层
不懂!
发表于 2007-2-24 11:40:00 | 显示全部楼层
简单的说就是在墙里卡一下不费hp,事实上早有人发现了,就是没说
发表于 2007-2-24 12:10:00 | 显示全部楼层
<>[em06]有些地图自己都会帮我EB了...</P>
<>想跳下去死都不让我死..</P>[em02]
发表于 2007-2-24 12:56:00 | 显示全部楼层
看不懂啊
发表于 2007-2-24 14:27:00 | 显示全部楼层
...v.c|bin太那个了~我跳下去,就是想摔死,也得摔死,不想摔死,也得摔死...[em18]
发表于 2007-2-24 14:37:00 | 显示全部楼层
[em06]不会吧.....0.0
发表于 2007-2-24 14:46:00 | 显示全部楼层
嘿嘿~[em04]
