查看: 1667|回复: 8
[求助]跪求几大高手的KZ config !帮帮忙哈!
发表于 2007-2-14 00:06:00 | 显示全部楼层 |阅读模式
<>求 zhady ,ndr,simen007,iin,simenwy,faker,这几个人的config参考!</P>
<>能帮忙的谢谢了!</P>[em07][em07][em07]
发表于 2007-2-14 00:20:00 | 显示全部楼层
<>我只知道ndR的,保存在记事本改名为config.cfg就可以了.</P>
<>// This file is overwritten whenever you change your user settings in the game.<BR>// Add custom configurations to the file "userconfig.cfg".</P>
<>unbindall<BR>bind "TAB" "+showscores"<BR>bind "ENTER" "+speed"<BR>bind "ESCAPE" "cancelselect"<BR>bind "'" "+moveup"<BR>bind "+" "sizeup"<BR>bind "," "buyammo1"<BR>bind "-" "sizedown"<BR>bind "." "buyammo2"<BR>bind "/" "+movedown"<BR>bind "0" "slot10"<BR>bind "1" "slot1"<BR>bind "2" "slot2"<BR>bind "3" "slot3"<BR>bind "4" "slot4"<BR>bind "5" "slot5"<BR>bind "6" "slot6"<BR>bind "7" "slot7"<BR>bind "8" "slot8"<BR>bind "9" "slot9"<BR>bind ";" "+mlook"<BR>bind "=" "sizeup"<BR>bind "[" "invprev"<BR>bind "]" "invnext"<BR>bind "`" "toggleconsole"<BR>bind "a" "+moveleft"<BR>bind "b" "buy"<BR>bind "c" "stopsound"<BR>bind "d" "sv_gravity 2"<BR>bind "e" "+use"<BR>bind "f" "impulse 100"<BR>bind "g" "drop"<BR>bind "h" "+commandmenu"<BR>bind "i" "say /use"<BR>bind "j" "sv_gravity 800"<BR>bind "k" "+voicerecord"<BR>bind "m" "chooseteam"<BR>bind "n" "say loty Perfo donakos jef Jle Himuraken scary faker rayla caps Bhaal DHT Niko zhady!"<BR>bind "o" "say /admincup"<BR>bind "p" "amxmodmenu"<BR>bind "q" "lastinv"<BR>bind "r" "+reload"<BR>bind "s" "say /start"<BR>bind "t" "impulse 201"<BR>bind "u" "messagemode2"<BR>bind "w" "sv_restartround 1 ; stop ; record cater"<BR>bind "x" "stop ; record sc_cater ; say /gocheck"<BR>bind "y" "messagemode"<BR>bind "z" "+hook"<BR>bind "~" "toggleconsole"<BR>bind "UPARROW" "+forward"<BR>bind "DOWNARROW" "+back"<BR>bind "LEFTARROW" "+moveleft"<BR>bind "RIGHTARROW" "+moveright"<BR>bind "ALT" "+strafe"<BR>bind "CTRL" "+jump"<BR>bind "SHIFT" "+duck"<BR>bind "F1" "autobuy"<BR>bind "F2" "rebuy"<BR>bind "F5" "snapshot"<BR>bind "F6" "save quick"<BR>bind "F7" "load quick"<BR>bind "F10" "quit prompt"<BR>bind "INS" "+klook"<BR>bind "PGDN" "+lookdown"<BR>bind "PGUP" "+lookup"<BR>bind "END" "centerview"<BR>bind "KP_END" "lastinv"<BR>bind "KP_DOWNARROW" "+attack2"<BR>bind "KP_INS" "+reload"<BR>bind "MWHEELDOWN" "+duck"<BR>bind "MWHEELUP" "+jump"<BR>bind "MOUSE1" "+attack"<BR>bind "MOUSE2" "+use"<BR>bind "MOUSE3" "+hook"<BR>bind "PAUSE" "pause"<BR>_cl_autowepswitch "1"<BR>_snd_mixahead "0.1"<BR>ati_npatch "1.0"<BR>ati_subdiv "2.0"<BR>bgmvolume "1.000000"<BR>bottomcolor "6"<BR>brightness "1"<BR>cl_allowdownload "1"<BR>cl_allowupload "1"<BR>cl_backspeed "400"<BR>cl_cmdbackup "2"<BR>cl_cmdrate "101"<BR>cl_corpsestay "600.000000"<BR>cl_crosshair_color "250 250 50"<BR>cl_crosshair_size "small"<BR>cl_crosshair_translucent "1"<BR>cl_dlmax "128"<BR>cl_download_ingame "1"<BR>cl_dynamiccrosshair "0"<BR>cl_forwardspeed "400"<BR>cl_himodels "0"<BR>cl_idealpitchscale "0.8"<BR>cl_lc "1"<BR>cl_logocolor "#Valve_Orange"<BR>cl_logofile "devl1"<BR>cl_lw "1"<BR>cl_minmodels "0"<BR>cl_radartype "0"<BR>cl_righthand "1"<BR>cl_shadows "1"<BR>cl_timeout "35"<BR>cl_updaterate "101"<BR>cl_vsmoothing "0.05"<BR>cl_weather "1"<BR>con_color "255 180 30"<BR>console "1.000000"<BR>crosshair "1.000000"<BR>fastsprites "0"<BR>fps_max "101"<BR>fps_modem "0"<BR>gamma "3"<BR>gl_dither "1"<BR>gl_flipmatrix "0"<BR>gl_fog "1"<BR>gl_monolights "0"<BR>gl_overbright "0"<BR>gl_polyoffset "0.1"<BR>hisound "1"<BR>hpk_maxsize "4"<BR>hud_capturemouse "1"<BR>hud_centerid "1"<BR>hud_draw "1"<BR>hud_fastswitch "0"<BR>hud_saytext_internal "1"<BR>hud_takesshots "0"<BR>joystick "0"<BR>lookspring "0.000000"<BR>lookstrafe "0.000000"<BR>m_filter "0"<BR>m_forward "1"<BR>m_pitch "0.022"<BR>m_side "0.8"<BR>m_yaw "0.022"<BR>model "gordon"<BR>MP3FadeTime "2.0"<BR>MP3Volume "1"<BR>mp_decals "999.000000"<BR>name "ndR"<BR>net_graph "3"<BR>net_graphpos "1"<BR>net_scale "5"<BR>r_bmodelhighfrac "5.0"<BR>r_detailtextures "0"<BR>s_a3d "0.0"<BR>s_automax_distance "30"<BR>s_automin_distance "2"<BR>s_bloat "2.0"<BR>s_distance "60"<BR>s_doppler "0.0"<BR>s_eax "0.0"<BR>s_leafnum "0"<BR>s_max_distance "1000"<BR>s_min_distance "5"<BR>s_numpolys "200"<BR>s_polykeep "1000000000"<BR>s_polysize "10000000"<BR>s_refdelay "4"<BR>s_refgain "0.4"<BR>s_rolloff "1.0"<BR>s_verbwet "0.25"<BR>sensitivity "7.500000"<BR>skin ""<BR>spec_autodirector_internal "1"<BR>spec_drawcone_internal "1"<BR>spec_drawnames_internal "1"<BR>spec_drawstatus_internal "1"<BR>spec_mode_internal "2"<BR>spec_pip "0"<BR>suitvolume "0.250000"<BR>sv_aim "0"<BR>sv_voiceenable "1"<BR>team ""<BR>topcolor "30"<BR>viewsize "120.000000"<BR>voice_enable "1"<BR>voice_forcemicrecord "1"<BR>voice_modenable "1"<BR>voice_scale "2"<BR>volume "1.850000"<BR>setinfo "_vgui_menus" "1"<BR>setinfo "_ah" "0"<BR>+mlook<BR>+jlook<BR>exec userconfig.cfg</P>
发表于 2007-2-14 10:06:00 | 显示全部楼层
真的吗?[em13]
发表于 2007-2-14 18:57:00 | 显示全部楼层
<>我不是高手,谢谢。</P>
<>// This file is overwritten whenever you change your user settings in the game.<br>// Add custom configurations to the file "userconfig.cfg".</P>
<>unbindall<br>bind "TAB" "+showscores"<br>bind "ENTER" "amxmodmenu"<br>bind "ESCAPE" "cancelselect"<br>bind "SPACE" "+jump"<br>bind "0" "slot10"<br>bind "1" "slot1"<br>bind "2" "slot2"<br>bind "3" "slot3"<br>bind "4" "slot4"<br>bind "5" "slot5"<br>bind "6" "slot6"<br>bind "7" "slot7"<br>bind "8" "slot8"<br>bind "9" "slot9"<br>bind "`" "toggleconsole"<br>bind "a" "+moveleft"<br>bind "d" "+moveright"<br>bind "e" "+use"<br>bind "f" "+hook"<br>bind "g" "drop"<br>bind "h" "+commandmenu"<br>bind "i" "say &lt;3 (-_-)X-R@y"<br>bind "k" "kill"<br>bind "n" "nightvision"<br>bind "q" "lastinv"<br>bind "r" "+reload"<br>bind "s" "+back"<br>bind "t" "impulse 201"<br>bind "u" "messagemode2"<br>bind "v" "+duck"<br>bind "w" "+forward"<br>bind "y" "messagemode"<br>bind "~" "toggleconsole"<br>bind "DOWNARROW" "stop"<br>bind "LEFTARROW" "record 1"<br>bind "RIGHTARROW" "sv_restartround 1"<br>bind "CTRL" "+duck"<br>bind "CAPSLOCK" "+voicerecord"<br>bind "MWHEELDOWN" "+jump"<br>bind "MWHEELUP" "+duck"<br>bind "MOUSE1" "+attack"<br>bind "MOUSE2" "+attack2"<br>_cl_autowepswitch "1"<br>_snd_mixahead "0.1"<br>ati_npatch "1.0"<br>ati_subdiv "2.0"<br>bgmvolume "1.000000"<br>bottomcolor "6"<br>brightness "3"<br>cl_allowdownload "1"<br>cl_allowupload "1"<br>cl_backspeed "400"<br>cl_career_difficulty "0"<br>cl_cmdbackup "2"<br>cl_cmdrate "101"<br>cl_corpsestay "0.000000"<br>cl_dlmax "128"<br>cl_download_ingame "1"<br>cl_dynamiccrosshair "1"<br>cl_forwardspeed "400"<br>cl_himodels "0"<br>cl_idealpitchscale "0.8"<br>cl_lc "1"<br>cl_logocolor "#Valve_Blue"<br>cl_logofile "andre"<br>cl_lw "1"<br>cl_minmodels "1"<br>cl_radartype "1"<br>cl_righthand "1"<br>cl_shadows "0"<br>cl_timeout "200"<br>cl_updaterate "101"<br>cl_vsmoothing "0.05"<br>cl_weather "0"<br>con_color "255 180 30"<br>console "1"<br>crosshair "1"<br>fastsprites "2"<br>fps_max "101"<br>fps_modem "0"<br>gamma "3"<br>gl_dither "1"<br>gl_flipmatrix "0"<br>gl_monolights "0"<br>gl_overbright "0"<br>gl_polyoffset "0.1"<br>hisound "0"<br>hpk_maxsize "0"<br>hud_capturemouse "1"<br>hud_centerid "0"<br>hud_draw "0"<br>hud_fastswitch "1"<br>hud_saytext_internal "1"<br>hud_takesshots "0"<br>joystick "0"<br>lookspring "0.000000"<br>lookstrafe "0.000000"<br>m_filter "1"<br>m_forward "1"<br>m_pitch "0.022000"<br>m_side "0.8"<br>m_yaw "0.022"<br>model "gordon"<br>MP3FadeTime "1.0"<br>MP3Volume "1"<br>mp_decals "0.000000"<br>name "iiN[KzcN]"<br>net_graph "0"<br>net_graphpos "3"<br>net_scale "5"<br>r_bmodelhighfrac "5.0"<br>s_a3d "0"<br>s_automax_distance "30"<br>s_automin_distance "2"<br>s_bloat "2.0"<br>s_distance "60"<br>s_doppler "0.0"<br>s_eax "0"<br>s_leafnum "0"<br>s_max_distance "1000"<br>s_min_distance "5"<br>s_numpolys "200"<br>s_polykeep "1000000000"<br>s_polysize "10000000"<br>s_refdelay "4"<br>s_refgain "0.4"<br>s_rolloff "1.0"<br>s_verbwet "0.25"<br>sensitivity "5.00000"<br>skin ""<br>spec_autodirector_internal "0"<br>spec_drawcone_internal "1"<br>spec_drawnames_internal "1"<br>spec_drawstatus_internal "1"<br>spec_mode_internal "3"<br>spec_pip "0"<br>suitvolume "1.390000"<br>sv_aim "0"<br>sv_voiceenable "1"<br>team ""<br>topcolor "30"<br>viewsize "120.000000"<br>voice_enable "1"<br>voice_forcemicrecord "1"<br>voice_modenable "1"<br>voice_scale "2"<br>volume "1"<br>setinfo "_vgui_menus" "0"<br>setinfo "_ah" "0"<br>+mlook<br>exec userconfig.cfg<br></P>
[此贴子已经被作者于2007-2-14 19:02:41编辑过]
发表于 2007-2-14 18:59:00 | 显示全部楼层
CONFIG有啥用吗?<BR>
 楼主| 发表于 2007-2-14 19:49:00 | 显示全部楼层
<>我只是看看高手的键盘是怎么设置的</P>
<>因为我是打枪出生的,跳跃的时候不方便,想看看有什么可以借鉴的东西而已</P>
<>我是右键蹲。。。其余都差不多!</P>
发表于 2007-2-14 20:01:00 | 显示全部楼层
<>我发下哈[em02]</P>
<>unbindall<BR>bind "TAB" "+showscores"<BR>bind "ENTER" "+attack"<BR>bind "ESCAPE" "cancelselect"<BR>bind "SPACE" "+jump"<BR>bind "'" "+moveup"<BR>bind "," "buyammo1"<BR>bind "-" "+rope"<BR>bind "." "buyammo2"<BR>bind "/" "+movedown"<BR>bind "0" "slot10"<BR>bind "1" "slot1"<BR>bind "2" "slot2"<BR>bind "3" "slot3"<BR>bind "4" "slot4"<BR>bind "5" "slot5"<BR>bind "6" "slot6"<BR>bind "7" "slot7"<BR>bind "8" "slot8"<BR>bind "9" "slot9"<BR>bind ";" "+mlook"<BR>bind "=" "+hook"<BR>bind "[" "invprev"<BR>bind "]" "invnext"<BR>bind "`" "toggleconsole"<BR>bind "a" "+moveleft"<BR>bind "b" "buy"<BR>bind "c" "radio3"<BR>bind "d" "+moveright"<BR>bind "e" "+use"<BR>bind "f" "impulse 100"<BR>bind "g" "drop"<BR>bind "h" "+commandmenu"<BR>bind "j" "say menu"<BR>bind "k" "+voicerecord"<BR>bind "l" "showbriefing"<BR>bind "m" "chooseteam"<BR>bind "n" "nightvision"<BR>bind "o" "buyequip"<BR>bind "p" "stopsound"<BR>bind "q" "lastinv"<BR>bind "r" "+reload"<BR>bind "s" "+back"<BR>bind "t" "impulse 201"<BR>bind "u" "messagemode2"<BR>bind "v" "+voicerecord"<BR>bind "w" "+forward"<BR>bind "x" "+grab"<BR>bind "y" "messagemode"<BR>bind "z" "+hook"<BR>bind "~" "toggleconsole"<BR>bind "BACKSPACE" "snapshot"<BR>bind "UPARROW" "+forward"<BR>bind "DOWNARROW" "+back"<BR>bind "LEFTARROW" "+left"<BR>bind "RIGHTARROW" "+right"<BR>bind "ALT" "+strafe"<BR>bind "CTRL" "+speed"<BR>bind "SHIFT" "+duck"<BR>bind "F1" "say menu;cl_minmodels 0"<BR>bind "F2" "stop;record jump;say RECORD"<BR>bind "F3" "say /top15"<BR>bind "F4" "say /checkpoint"<BR>bind "F5" "say /gocheck"<BR>bind "F6" "amx_view"<BR>bind "F7" "say /music"<BR>bind "F8" "say /stuck"<BR>bind "F9" "say /keyhelp"<BR>bind "F10" "fw2"<BR>bind "F11" "startmovie bhop 60"<BR>bind "F12" "endmovie"<BR>bind "INS" "+klook"<BR>bind "PGDN" "+lookdown"<BR>bind "PGUP" "+lookup"<BR>bind "END" "centerview"<BR>bind "MWHEELDOWN" "+jump"<BR>bind "MWHEELUP" "+duck"<BR>bind "MOUSE1" "+attack"<BR>bind "MOUSE2" "+attack2"<BR>_cl_autowepswitch "1"<BR>_snd_mixahead "0.1"<BR>ati_npatch "1.0"<BR>ati_subdiv "2.0"<BR>bgmvolume "1"<BR>bottomcolor "0"<BR>brightness "1"<BR>cl_allowdownload "1"<BR>cl_allowupload "1"<BR>cl_backspeed "400"<BR>cl_cmdbackup "100"<BR>cl_cmdrate "101"<BR>cl_corpsestay "0.000000"<BR>cl_crosshair_color "250 250 50"<BR>cl_crosshair_size "small"<BR>cl_crosshair_translucent "0"<BR>cl_dlmax "80"<BR>cl_download_ingame "1"<BR>cl_dynamiccrosshair "0"<BR>cl_forwardspeed "400"<BR>cl_himodels "0"<BR>cl_idealpitchscale "0.8"<BR>cl_lc "1"<BR>cl_logocolor "#Valve_Orange"<BR>cl_logofile "lambda"<BR>cl_lw "1"<BR>cl_minmodels "0"<BR>cl_radartype "1"<BR>cl_righthand "1"<BR>cl_shadows "1"<BR>cl_timeout "35"<BR>cl_updaterate "101"<BR>cl_vsmoothing "0.05"<BR>cl_weather "0"<BR>con_color "255 180 30"<BR>console "0.0"<BR>crosshair "1"<BR>fastsprites "0"<BR>fps_max "101"<BR>fps_modem "0"<BR>gamma "3"<BR>gl_dither "1"<BR>gl_flipmatrix "0"<BR>gl_fog "1"<BR>gl_monolights "0"<BR>gl_overbright "0"<BR>gl_polyoffset "4"<BR>hisound "1"<BR>hpk_maxsize "4"<BR>hud_capturemouse "1"<BR>hud_centerid "0"<BR>hud_draw "1"<BR>hud_fastswitch "1"<BR>hud_saytext_internal "1"<BR>hud_takesshots "0"<BR>joystick "0"<BR>lookspring "0"<BR>lookstrafe "0"<BR>m_filter "1"<BR>m_forward "1"<BR>m_pitch "0.022"<BR>m_side "0.8"<BR>m_yaw "0.022"<BR>model "arctic"<BR>MP3FadeTime "2.0"<BR>MP3Volume "0.8"<BR>mp_decals "0.000000"<BR>name "SiMen.007&lt;MAP&gt;"<BR>net_graph "1"<BR>net_graphpos "1"<BR>net_scale "5"<BR>r_bmodelhighfrac "5.0"<BR>r_detailtextures "0"<BR>s_a3d "0.0"<BR>s_automax_distance "30"<BR>s_automin_distance "2"<BR>s_bloat "2.0"<BR>s_distance "60"<BR>s_doppler "0.0"<BR>s_eax "1"<BR>s_leafnum "0"<BR>s_max_distance "1000"<BR>s_min_distance "5"<BR>s_numpolys "200"<BR>s_polykeep "1000000000"<BR>s_polysize "10000000"<BR>s_refdelay "4"<BR>s_refgain "0.4"<BR>s_rolloff "1.0"<BR>s_verbwet "0.25"<BR>sensitivity "6"<BR>skin ""<BR>spec_autodirector_internal "0"<BR>spec_drawcone_internal "1"<BR>spec_drawnames_internal "1"<BR>spec_drawstatus_internal "1"<BR>spec_mode_internal "2"<BR>spec_pip "0"<BR>suitvolume "0.25"<BR>sv_aim "0"<BR>sv_voiceenable "1"<BR>team ""<BR>topcolor "0"<BR>viewsize "120"<BR>voice_enable "1"<BR>voice_forcemicrecord "1"<BR>voice_modenable "1"<BR>voice_scale "1"<BR>volume "0.6"<BR>setinfo "friends_lastsound" "0"<BR>setinfo "lang" "cn"<BR>setinfo "_vgui_menus" "1"<BR>setinfo "_ah" "0"<BR>+mlook<BR>exec userconfig.cfg<BR></P>
发表于 2007-2-14 21:19:00 | 显示全部楼层
我的怎么不要呢```[em04][em04][em04][em30][em25]
发表于 2007-2-15 08:26:00 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>liaoyixun</I>在2007-2-14 19:49:00的发言:</B><BR>
<>我是右键蹲。。。其余都差不多!</P></DIV>
<P>偶也是打枪出身滴 我刚才看了NBR的 知道为啥不会连蹲跳了</P>[em02]
