查看: 1293|回复: 3
[转贴]CS声音触发器指导
发表于 2007-1-31 20:47:00 | 显示全部楼层 |阅读模式
<DIV ><BR><FONT color=blue>de_train</FONT><BR><BR><FONT color=red><B>飞机喷射器声音的触发位置</B></FONT><BR><BR><FONT color=green>通常情况下在外场99%会触发这个声音,触发器是一个在一定高度上的大盒子,<BR>高度大约是从火车的顶部到差不多高台中央的位置,覆盖整个层面。下面的截图<BR>说明了音盒的位置和启动条件。<BR><BR>声音第一次启动前隔 4 秒<BR>距离下次启动相隔 180 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/jetsoundtrigger_small2.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/jetsoundtrigger_small1.jpg" border=0><BR><IMG src="http://cs.buto.eu/soundtrigger/img/jetsoundtrigger_small3.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/jetsoundtrigger_small4.jpg" border=0><BR><BR><BR><BR>飞机喷射器声音的扩散范围<BR><BR>喇叭所指的位置,请看截图说明。<BR>范围:每个地方</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_jettrigger_small1.jpg" border=0><BR><BR><BR><BR><BR><BR><BR><FONT color=red><B>op Dog叫声触发器</B></FONT><BR><BR><FONT color=green>有两个触发器分别位于两个pop dog车厢下面。当你走在这两个车厢下面时,<BR>就会引发此声音。看下面的截图。<BR><BR>声音第一次启动前隔 3 秒<BR>距离下次启动相隔 200 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/popdogtriggers_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/popdogtriggers_small2.jpg" border=0><BR><BR>op Dog声音扩散范围<BR>在喇叭的地方,请看截图说明。<BR>范围:小</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_popdogtrigger_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/sounds_popdogtrigger_small2.jpg" border=0><BR><BR><BR><BR><BR><BR><FONT color=red><B>长廊的鸟啼声音触发器</B></FONT><BR><BR><FONT color=green>长廊上只有一个触发器,从墙草开始,高度如图所示。<BR><BR>声音第一次启动前隔 2 秒<BR>距离下次启动相隔 90 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/birdstrigger_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/birdstrigger_small2.jpg" border=0><BR><BR><BR><BR>长廊的鸟啼声音扩散范围<BR>在差不多在走廊上方的半空中。请看截图。<BR>范围:中等</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_birdsalleytrigger_small1.jpg" border=0><BR><BR><BR><BR><BR><BR><BR><BR><BR><FONT color=blue>de_cbble</FONT><BR><BR><FONT color=red><B>绵羊声音触发器</B></FONT><BR><BR><FONT color=green>这个就在右手边的右走廊的中部,当穿过这个盒子时,就会启动。<BR><BR>声音第一次启动前隔 13 秒<BR>距离下次启动相隔 120 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/sheeptrigger_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/sheeptrigger_small3.jpg" border=0><BR><BR><BR><BR>绵羊声音扩散范围<BR>在T出生点的右后方,请看截图。<BR>范围:中等</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_sheeptriggercbble_small1.jpg" border=0><BR><BR><BR><BR><FONT color=red><B>奶牛声音触发器</B></FONT><BR><BR><FONT color=green>位置在CT出生点左边的隧道,看截图。<BR><BR>声音第一次启动前隔 19 秒<BR>距离下次启动相隔 131 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/cowtriggercbble_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/cowtriggercbble_small2.jpg" border=0><BR><BR><BR>奶牛声音扩散范围<BR>这个声音从B区C4点的后面发出,狙击位。<BR>范围:中等</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_cowtriggercbble_small1.jpg" border=0><BR><BR><BR><BR><FONT color=red><B>奶牛声音2触发器</B>[/bolor]<BR><BR><FONT color=green>在B区C4点旁的高台上,请看截图。<BR><BR>声音第一次启动前隔 6 秒<BR>距离下次启动相隔 91 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/crowtriggercbble_small1.jpg" border=0><BR><BR><BR>奶牛声音2扩散范围<BR>看截图,就在另一个触发器的旁边的箱子上。<BR>范围:中等</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_crowtriggercbble_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/sounds_crowtriggercbble_small2.jpg" border=0><BR><BR><BR><BR><BR><BR><FONT color=red><B>麻雀声音触发器</B></FONT><BR><BR><FONT color=green>总共有3个,第1个在T出生点进入城堡的入口出,第2和第3个在中间城堡的两边,<BR>请看截图。<BR><BR>声音第一次启动前隔 121秒<BR>距离下次启动相隔 140 秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/sparrowsoundtriggercbble_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/sparrowsoundtriggercbble_small2.jpg" border=0><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sparrowsoundtriggercbble_small3.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/sparrowsoundtriggercbble_small4.jpg" border=0><BR><BR><BR>麻雀声音扩散范围<BR>就是从触发器的位置发出,看图。<BR>范围:中等</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_sparrowtriggercbble_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/sounds_sparrowtriggercbble_small2.jpg" border=0><BR>                          <IMG src="http://cs.buto.eu/soundtrigger/img/sounds_sparrowtriggercbble_small3.jpg" border=0>        <BR><BR><BR><BR><BR><BR><BR><BR><FONT color=blue>de_aztec</FONT><BR><BR><FONT color=red><B>雷声触发器</B></FONT><BR><BR><FONT color=green>有两个,第1个在桥的中央,第2个在水池边的楼梯处,请看截图。<BR><BR>声音第一次启动前隔 0 秒<BR>距离下次启动相隔 45秒<BR><IMG src="http://cs.buto.eu/soundtrigger/img/thundertriggersaztec_small1.jpg" border=0> <IMG src="http://cs.buto.eu/soundtrigger/img/thundertriggersaztec_small2.jpg" border=0><BR><BR><BR><BR>雷声扩散范围<BR>在A区的C4点旁,这个触发器是多方向的,看图。<BR>范围:每个地方</FONT><BR><IMG src="http://cs.buto.eu/soundtrigger/img/sounds_thunderaztec_small1.jpg" border=0><BR><BR><FONT color=yellow>结束</FONT></DIV></FONT>
发表于 2007-2-1 19:36:00 | 显示全部楼层
<>我靠终于看到专业的了,自己平时没功夫翻地图</P>
<>哈哈谢谢!</P>
 楼主| 发表于 2007-2-2 01:06:00 | 显示全部楼层
[em02][em02][em02][em02][em02][em02]
发表于 2007-2-3 00:43:00 | 显示全部楼层
hao  ~~ n4!!![em01]
