查看: 10819|回复: 57
推荐] STEAM 正版config 下载!
    郁闷
    2024-2-29 19:16
    发表于 2007-1-24 01:37:00 | 显示全部楼层 |阅读模式
    今天重起了下电脑,突然发现steam连上去了,我把自己的config 文件和 userconfig文件删除,启动了下cs,生成了steam默认的config。
    1. // This file is overwritten whenever you change your user settings in the game.
    2. // Add custom configurations to the file "userconfig.cfg".
    3. unbindall
    4. bind "TAB" "+showscores"
    5. bind "ENTER" "+attack"
    6. bind "ESCAPE" "escape"
    7. bind "SPACE" "+jump"                     //绑定空格为跳--  我们把他更改为 bind "MWHEELDOWN" "+jump"
    8. bind "'" "+moveup"
    9. bind "+" "sizeup"
    10. bind "," "buyammo1"
    11. bind "-" "sizedown"
    12. bind "." "buyammo2"
    13. bind "/" "+movedown"
    14. bind "0" "slot10"
    15. bind "1" "slot1"
    16. bind "2" "slot2"
    17. bind "3" "slot3"
    18. bind "4" "slot4"
    19. bind "5" "slot5"
    20. bind "6" "slot6"
    21. bind "7" "slot7"
    22. bind "8" "slot8"
    23. bind "9" "slot9"
    24. bind ";" "+mlook"
    25. bind "=" "sizeup"
    26. bind "a" "+moveleft"
    27. bind "b" "buy"
    28. bind "c" "radio3"
    29. bind "d" "+moveright"
    30. bind "e" "+use"
    31. bind "f" "impulse 100"
    32. bind "g" "drop"
    33. bind "h" "+commandmenu"
    34. bind "i" "showbriefing"
    35. bind "j" "cheer"
    36. bind "k" "+voicerecord"
    37. bind "m" "chooseteam"
    38. bind "n" "nightvision"
    39. bind "o" "buyequip"
    40. bind "q" "lastinv"
    41. bind "r" "+reload"
    42. bind "s" "+back"
    43. bind "t" "impulse 201"
    44. bind "u" "messagemode2"
    45. bind "w" "+forward"
    46. bind "x" "radio2"
    47. bind "y" "messagemode"
    48. bind "z" "radio1"
    49. bind "[" "invprev"
    50. bind "]" "invnext"
    51. bind "`" "toggleconsole"
    52. bind "~" "toggleconsole"
    53. bind "UPARROW" "+forward"
    54. bind "DOWNARROW" "+back"
    55. bind "LEFTARROW" "+left"
    56. bind "RIGHTARROW" "+right"
    57. bind "ALT" "+strafe"
    58. bind "CTRL" "+duck"                                                         //绑定ctrl蹲为跳
    59. bind "SHIFT" "+speed"
    60. bind "F1" "autobuy"
    61. bind "F2" "rebuy"
    62. bind "F5" "snapshot"
    63. bind "F6" "save quick"
    64. bind "F7" "load quick"
    65. bind "F10" "quit prompt"
    66. bind "INS" "+klook"
    67. bind "PGDN" "+lookdown"
    68. bind "PGUP" "+lookup"
    69. bind "END" "centerview"
    70. bind "MWHEELDOWN" "invnext"
    71. bind "MWHEELUP" "invprev"
    72. bind "MOUSE1" "+attack"
    73. bind "MOUSE2" "+attack2"
    74. bind "PAUSE" "pause"
    75. voice_modenable "1.000000"
    76. voice_scale "0.750000"
    77. MP3Volume "0.800000"
    78. name "Player"
    79. bottomcolor "6"
    80. topcolor "30"
    81. model "gordon"
    82. rate "2500.000000"
    83. s_eax "0.000000"
    84. s_a3d "0.000000"
    85. volume "0.800000"
    86. hisound "1.000000"
    87. suitvolume "0.250000"
    88. bgmvolume "1.000000"
    89. gamma "2.500000"
    90. brightness "1.000000"
    91. viewsize "120.000000"
    92. sensitivity "3.000000"
    93. d_spriteskip "0.000000"
    94. cl_himodels "0.000000"
    95. console "1.000000"
    96. sv_aim "1.000000"
    97. joystick "0.000000"
    98. m_filter "0.000000"
    99. _windowed_mouse "0.000000"
    100. crosshair "1.000000"
    101. lookspring "0.000000"
    102. m_pitch "0.022000"
    103. lookstrafe "0.000000"
    104. +jlook
    105. +mlook
    106. cl_timeout 300
    107. exec userconfig.cfg  //执行用户配置文件,对config不了解的朋友请删除这行。
    复制代码
     注解:红色表注的是cstrike文件下另外一个用户自行配置文件userconfig.cfg,当cs读取config时,如果有config里有exec userconfig.cfg 这条命令,那么userconfig.cfg里的命令都会加载,如果你的userconfig.cfg带有非法参数就会被执行。如果你对cs参数不了解,那么请删除这行。
      安装方法:改好文件覆盖 x盘:/CS 中文版/cstrike 和 cstrike_schinese 两个目录下的同名
    config.cfg文件。
       根据目前国内的cs版本情况,强烈建议非正版玩家不要到cs的按键选项里更改设置。如果要改设置,请直接在我发的config里修改好了设置再去覆盖原文件。
    config文件下载附件: 5905.rar (2007-1-24 1:35:00, 1.02 K)
    该附件被下载次数 264
    如何录一个标准的demo    ---------   by [email=R@y]R@y[/email]
    要是破国内记录或者世界记录的话
    应该这样做
    在控制台输入 "record 123"
    (123是demo的名字,你可以自己随便起)
    然后输入 "sv_restart 1"
    也就是刷新
    确保图的完整性
    好多国内demo都没这样做
    其实是错误的
    然后开始按计时器
    到终点按计时器
    然后在控制台将你的名字改成自己的名字
    (好多人玩游戏瞎起名字,要改成和你cs id一样的,要是只用一个名字就不用改了)
    然后输入kill
    自杀,以确保跳的人和你的id是一个人
    防止代替
    然后输入stop
    停止录demo
    最后在cs里找到你的demo
    将它改名字
    比如说 我跳了 sandblock 这个图,用了6分钟
    我就应该写
    KZ_sandblock_R@Y_0600
    地图名,我的名,时间
    最后压缩,上传
    ok啦
    5905.rar
    1.02 KB, 下载次数: 309
    [推荐]
    4.58 KB, 下载次数: 10
    发表于 2007-1-24 01:49:00 | 显示全部楼层
    好东西好东西好东西!好东西好东西好东西![em01][em01][em01][em01][em01][em01]
    发表于 2007-1-24 01:50:00 | 显示全部楼层
    着下就好了!
    发表于 2007-1-24 01:53:00 | 显示全部楼层
    呵呵~顶`
    发表于 2007-1-24 01:55:00 | 显示全部楼层
    请问怎么装,装哪里,怎么用,3D可以告诉我吗,因为我还搞懂什么是CONFIG,呵呵.
    发表于 2007-1-24 02:13:00 | 显示全部楼层
    <>   我的蹲一直用鼠标右键~~这个属于作弊吗?</P>
    郁闷
    2024-2-29 19:16
     楼主| 发表于 2007-1-24 02:22:00 | 显示全部楼层
    <DIV class=quote><B>以下是引用<I>[MR]zoro</I>在2007-1-24 2:13:00的发言:</B><BR>
    <>   我的蹲一直用鼠标右键~~这个属于作弊吗?</P><BR></DIV>
    <>不属于作弊</P>
    发表于 2007-1-24 02:25:00 | 显示全部楼层
    谢谢领导指示~
    发表于 2007-1-24 02:31:00 | 显示全部楼层
    <>不要绑定在作弊软件上面的键位OK!</P>
    <>意思就是不要作弊!</P>
    发表于 2007-1-24 02:33:00 | 显示全部楼层
    我至今不知道那里可以搞到作弊软件~~~也不会用~~~~(因为我英文差~)
