查看: 3433|回复: 27
[注意]最新消息!LJ作弊器!
发表于 2006-11-15 20:11:00 | 显示全部楼层 |阅读模式
<TABLE >
<TR>
<TD class=fcaption style="WIDTH: 20%; TEXT-ALIGN: center"></TD>
<TD class=fcaption style="WIDTH: 80%; TEXT-ALIGN: center"></TD></TR>
<TR>
<TD class=forumheader style="VERTICAL-ALIGN: middle"><B></B></TD>
<TABLE  cellSpacing=0 cellPadding=0>
<TR>
<TD class=smallblacktext><A><IMG src="http://xtreme-jumps.xandor.de/e107_images/forum/post.png"></A> Wed Nov 15 2006, 07:52AM </TD>
<TD ><a href="http://xtreme-jumps.xandor.de/forum_post.php?quote.60.25918" target="_blank" ><IMG src="http://xtreme-jumps.xandor.de/e107_images/forum/quote.png"></A> </TD></TR></TABLE></TD></TR>
<TR>
<TD class=forumheader3 style="VERTICAL-ALIGN: top">
<DIV class=spacer> <BR></DIV></TD>
<>I have heard that there are some LJ scri<I></I>pts. I dont even think its posible, but some say thath there are, to think of it how is that posible ? </P>
<TABLE >
<TR>
<TR>
<TD class=smallblacktext></TD>
<TD ><a href="http://xtreme-jumps.xandor.de/forum_post.php?quote.60.25937" target="_blank" ><IMG src="http://xtreme-jumps.xandor.de/e107_images/forum/quote.png"></A> </TD></TR></TABLE></TD></TR>
<TR>
<DIV class=spacer><BR> </DIV></TD>
<>It is as hard as do them with real skill imo <IMG src="http://xtreme-jumps.xandor.de/e107_images/emoticons/smilie8.gif"> <BR><BR>The record longjump done by a scri<I></I>pt is 244... <BR><BR>Ill upload the demo and tell you the name of the scri<I></I>pter later when im back @ home <IMG src="http://xtreme-jumps.xandor.de/e107_images/emoticons/smilie8.gif"> </P>
</TD></TR></TABLE></P></TD></TR></TABLE>
 楼主| 发表于 2006-11-15 20:13:00 | 显示全部楼层
<>底下的回复是faker说的。</P>
<>作弊器最远可以跳到244。(那还叫作弊器吗?)</P>
<>其它内容会及时发布的。</P>
发表于 2006-11-15 20:14:00 | 显示全部楼层
我不用都能过,看来我超过作弊器啦,哈哈!
 楼主| 发表于 2006-11-15 20:32:00 | 显示全部楼层
我还以为可以过255呢,哈哈。
  • 签到天数: 8 天
    [LV.3]偶尔看看II
    发表于 2006-11-15 20:41:00 | 显示全部楼层
    <>LJ scri<I></I>pts</P>
    <>晕。。。</P>
    发表于 2006-11-15 20:48:00 | 显示全部楼层
    长跳脚本长啥样?
    <>BS用作弊器的人</P>[em03][em03][em03][em03]
    郁闷
    2024-2-29 19:16
    发表于 2006-11-15 20:49:00 | 显示全部楼层
    还好只能过244
     楼主| 发表于 2006-11-15 20:52:00 | 显示全部楼层
    <>- -!!</P>
    <>虽说只能过244,但是,如果只要使用,就能过244的话,那就不会出现失误之类的东西。</P>
    <>还是比较........</P>
    郁闷
    2024-2-29 19:16
    发表于 2006-11-15 20:54:00 | 显示全部楼层
    <DIV class=quote><B>以下是引用<I>iiN[KzcN]</I>在2006-11-15 20:52:00的发言:</B><BR>
    <>- -!!</P>
    <>还是比较........</P></DIV>
    <p>iin 说的有道理~
