查看: 609|回复: 0
[国际新闻] 40 New Demos - Release #641
发表于 2015-10-16 23:10:03 | 显示全部楼层 |阅读模式
betty_k
gbc_towers done in 00:54.18 ( **:** n/a ) (+1 KZ point)
hb_Zzz done in 10:09.61 ( **:** n/a ) (+1 KZ point)
colcol`
bhop_ctm_color done in 01:00.96 ( 01:01.30 Gorbachev_x ) (+2 KZ points)
bhop_miniscule done in 00:02.12 ( 00:07.48 prize ) (+241 KZ points)
hb_s^Lo done in 00:40.92 ( 01:11.40 Yamangel ) (+44 KZ points)
jiu_stairs_slope done in 00:13.40 ( **:** n/a ) (+1 KZ point)
kzla_LyNnblock done in 00:16.57 ( 00:17.79 prize ) (+57 KZ points)
kzlv_axn_sandyblocks done in 00:42.20 ( 01:30.54 Yamangel ) (+55 KZ points)
kzy_lost done in 01:54.84 ( 01:55.62 Dolphin ) (+6 KZ points)
pprn_40unitsclimb done in 00:14.92 ( 00:15.74 hfour ) (+7 KZ points)
pprn_40unitsclimb_v2 done in 00:19.89 ( 00:28.61 Yamangel ) (+32 KZ points)
stairs_relativity done in 00:36.66 ( 00:36.86 colcol` ) (+11 KZ points)
Dolphin
bhop_rock_darhz done in 00:42.54 ( 00:44.61 colcol` ) (+14 KZ points)
daza_junglebhop done in 01:21.82 ( 01:22.25 DizZy ) (+3 KZ points)
deathrun_ng_oui_final done in 01:56.82 ( 01:59.05 colcol` ) (+6 KZ points)
jiu_weirdrun done in 00:13.77 ( 00:14.23 throttle ) (+29 KZ points)
kzge_bridge done in 01:11.76 ( 01:12.58 Dolphin ) (+2 KZ points)
kzy_axn_snow done in 00:10.31 ( 00:10.68 Yamangel ) (+29 KZ points)
kzy_fastclimb done in 00:13.12 ( 00:14.30 Yamangel ) (+14 KZ points)
rch_4fix done in 00:24.03 ( 00:24.08 Rachel ) (+9 KZ points)
speed_ytt_egypt done in 00:56.07 ( 00:56.55 sick_ ) (+8 KZ points)
tmakerz_tinyclimb done in 00:29.09 ( 00:30.14 zink ) (+14 KZ points)
zink_eli_bhop done in 00:09.53 ( 00:10.31 Yamangel ) (+10 KZ points)
Evil
fat done in 02:24.71 ( 02:42.84 bowaaaNs ) (+12 KZ points)
Gorbachev_x
kz-endo_slide_svn_steep_e done in 04:24.56 ( 05:25.37 Aguslash ) (+19 KZ points)
guss
ce_colors_silde done in 00:09.94 ( 00:10.05 sick_ ) (+80 KZ points)
ph_slide_toon2 done in 00:22.12 ( 00:22.15 regine ) (+46 KZ points)
klinch
ytt_wow_mix done in 03:47.87 ( 04:29.36 klincheR ) (+16 KZ points)
klincher
kzarg_cellhop done in 00:10.24 ( 00:10.29 anker ) (+39 KZ points)
kUZKKK
instant_disconnect done in 00:52.10 ( 00:59.58 sick_ ) (+27 KZ points)
MEfro
mh_bhopljs_ez done in 00:35.00 ( 00:36.14 sDM ) (+17 KZ points)
merc-.-
cobkz_run_hns done in 00:44.65 ( 00:44.94 yashiro ) (+14 KZ points)
speed_ytt_abstract done in 00:49.43 ( 00:52.20 sick_ ) (+18 KZ points)
Mrjuice
kzarg_factory done in 00:49.86 ( 00:49.97 aLeee ) (+7 KZ points)
sick_
kzra_mininight done in 00:27.57 ( 00:28.93 Dolphin ) (+7 KZ points)
slide_vt_fastbest done in 00:22.37 ( 00:24.70 Klefer ) (+25 KZ points)
soni
ce_longjumps_c21 done in 00:08.78 ( 00:08.79 sonii ) (+80 KZ points)
talita
azl_lcyo done in 00:27.39 ( 00:27.88 talita ) (+33 KZ points)
throttle
slide_pre_chasm done in 00:46.76 ( 00:47.51 sick_ ) (+17 KZ points)
slide_pre_skill done in 00:58.79 ( 01:05.01 guss ) (+33 KZ points)
Click here to see which demos were rejected/improved
