查看: 2206|回复: 27
菜鸟用苹果鼠标跳的KZ数据
发表于 2013-7-31 13:27:10 | 显示全部楼层 |阅读模式
Distance: 243.384506 Maxspeed: 314.715026 (43.160) Prestrafe: 271.554321 Strafes: 4 Sync: 90
  1 16.544 0.000 28.5 100
  2 12.578 1.245 25.0  85
  3 6.875 1.052 21.4  90
  4 7.162 0.044 24.9  86
Block -- 235! Jumpoff -- 7.237518! Landing -- 0.87896
Distance: 243.567184 Maxspeed: 309.786926 (36.786) Prestrafe: 273.000152 Strafes: 4 Sync: 74
  1 11.704 0.000 25.0  83
  2 11.396 0.719 23.1  84
  3 6.999 0.114 21.4  72
  4 6.686 0.000 30.4  61
Block -- 235! Jumpoff -- 4.921936! Landing -- 3.68029
Distance: 242.099273 Maxspeed: 304.079223 (29.855) Prestrafe: 274.223693 Strafes: 2 Sync: 78
  1 15.465 0.000 26.8  80
  2 14.389 0.552 73.1  78
Block -- 230! Jumpoff -- 11.814300! Landing -- 0.244155(bg)!
[SiMen] 5 A is now 1 in map top with 242.099 type
Distance: 243.533874 Maxspeed: 311.408508 (41.073) Prestrafe: 270.335418 Strafes: 3 Sync: 76
  1 14.628 0.000 21.4 100
  2 14.107 0.663 33.9  73
  3 12.337 0.000 44.6  69
Block -- 235! Jumpoff -- 2.731323! Landing -- 5.269752(bg)!
[SiMen] 5 A is now 1 in map top with 243.533 type
Distance: 243.116134 Maxspeed: 306.102691 (33.421) Prestrafe: 272.681091 Strafes: 3 Sync: 72
  1 13.278 0.000 28.6  84
  2 11.890 0.000 24.9  85
  3 8.253 0.488 46.4  59
Block -- 235! Jumpoff -- 6.622894! Landing -- 1.447906(bg)!
[SiMen] 5 A is now 1 in map top with 243.116 type
Distance: 242.123092 Maxspeed: 306.574310 (33.935) Prestrafe: 272.639221 Strafes: 3 Sync: 75
  1 11.312 0.000 26.8  66
  2 14.768 0.000 26.7  93
  3 7.854 0.001 46.4  70
Block -- 235! Jumpoff -- 0.671325! Landing -- 6.133811(
Distance: 245.352416 Maxspeed: 320.868011 (48.996) Prestrafe: 271.871826 Strafes: 4 Sync: 76
  1 16.454 0.000 26.4  88
  2 9.893 0.773 20.8  80
  3 11.019 0.404 20.8  73
  4 11.629 0.047 31.9  66
[SiMen] 5A is now 1 in map top with 245.352 type
Distance: 246.108200 Maxspeed: 317.308898 (45.194) Prestrafe: 272.114471 Strafes: 4 Sync: 77
  1 14.209 0.000 23.7  93
  2 11.831 1.158 20.7  93
  3 9.369 0.845 20.7  73
  4 9.783 0.304 34.6
Distance: 246.011688 Maxspeed: 313.954223 (41.241) Prestrafe: 272.712921 Strafes: 4 Sync: 72
  1 11.485 0.000 22.2  75
  2 10.187 0.546 22.2  68
  3 11.882 0.000 22.2  87
  4 7.686 0.559 33.
Distance: 246.188796 Maxspeed: 319.956054 (47.217) Prestrafe: 272.738800 Strafes: 4 Sync: 71
  1 16.262 0.000 27.2  87
  2 10.956 0.396 20.5  73
  3 9.314 0.335 20.5  60
  4 10.682 0.000 31.5
Distance: 240.590148 Maxspeed: 301.344451 (27.772) Prestrafe: 273.571929 Strafes: 2 Sync: 69
  1 14.869 0.000 33.3  68
  2 12.903 0.648 66.6  69
[SiMen] 5A is now 1 in map top with 240.590 type l
Distance: 248.098556 Maxspeed: 321.582183 (49.484) Prestrafe: 272.097473 Strafes: 4 Sync: 86
  1 16.911 0.000 23.6  88
  2 12.180 1.268 22.1  87
  3 11.802 0.703 22.1  81
  4 8.590 0.653 31.9  87
[SiMen] 5A is now 1 in map top with 248.098 type lj !
[SiMen] 5A jumped 248.098 units with LongJ
Distance: 247.154418 Maxspeed: 317.662139 (44.503) Prestrafe: 273.158660 Strafes: 4 Sync: 77
  1 14.974 0.000 23.6  86
  2 9.473 1.291 20.8  73
  3 10.644 0.000 22.2  81
  4 9.411 0.425 33.3  72
[SiMen] 5A is now 1 in map top with 247.154 type
Distance: 245.236679 Maxspeed: 306.434173 (34.594) Prestrafe: 271.840026 Strafes: 3 Sync: 78
  1 14.272 0.000 22.2  92
  2 10.082 0.785 20.8  80
  3 10.239 0.000 56.9  73
[SiMen] 5A jumped 245.236 units with LongJump
Distance: 247.934661 Maxspeed: 315.337310 (41.006) Prestrafe: 274.330505 Strafes: 5 Sync: 80
  1 14.055 0.000 22.2  92
  2 10.939 1.118 23.6  82
  3 8.415 0.000 15.2 100
  4 2.482 1.424 13.8  77
Distance: 247.117080 Maxspeed: 316.236022 (42.423) Prestrafe: 273.812744 Strafes: 5 Sync: 83
  1 18.802 0.000 27.7  94
  2 12.046 1.364 20.8  93
  3 4.800 0.991 16.6  83
  4 4.713 1.187 22.2  75
  5 2.060 0.585 12
  5 5.113 0.536 24.
顺便问下各位大神  你们5次加速感觉费力吗  我这么5次加速感觉按不过来 难道撸少了 每天要多鲁鲁   还有各位大神 我还有哪里要提高的  谢谢指点
发表于 2013-8-3 22:30:57 | 显示全部楼层
用我的眼光来看 只是在炫耀 得瑟
这是得瑟吗 空速多没分配好 要得瑟也是上255以后的事  详情 回复 发表于 2013-8-4 12:58
回复 鲜花 1 鸡蛋 0
发表于 2013-7-31 14:47:25 | 显示全部楼层
爪子按的还不够快.
你们一般能几次加速啊  详情 回复 发表于 2013-7-31 14:51
 楼主| 发表于 2013-7-31 14:51:17 | 显示全部楼层
SiMen.Apple 发表于 2013-7-31 14:47
爪子按的还不够快.
你们一般能几次加速啊
1-8  详情 回复 发表于 2013-7-31 14:55
发表于 2013-7-31 14:55:20 | 显示全部楼层
二人四土 发表于 2013-7-31 14:51
你们一般能几次加速啊
1-8
晕 我5次就不行了 老了吗 又什么好诀窍没 大神  详情 回复 发表于 2013-7-31 15:09
 楼主| 发表于 2013-7-31 15:09:11 | 显示全部楼层
SiMen.Apple 发表于 2013-7-31 14:55
1-8
没秘诀。爪子按快点就行了  详情 回复 发表于 2013-7-31 15:37
发表于 2013-7-31 15:11:40 | 显示全部楼层
同步空速。
我的同步和空速还要提高是不是 大神 感谢啊  详情 回复 发表于 2013-7-31 21:50
发表于 2013-7-31 15:37:16 | 显示全部楼层
没秘诀。爪子按快点就行了
你的爪子真好啊。可以吃的吗?  详情 回复 发表于 2013-7-31 17:27
发表于 2013-7-31 17:27:59 | 显示全部楼层
SiMen.Apple 发表于 2013-7-31 15:37
没秘诀。爪子按快点就行了
你的爪子真好啊。可以吃的吗?
 楼主| 发表于 2013-7-31 21:49:39 | 显示全部楼层
哈哈哈
 楼主| 发表于 2013-7-31 21:50:21 | 显示全部楼层
风过泪无痕丶 发表于 2013-7-31 15:11
同步空速。
谢谢指点  详情 回复 发表于 2013-7-31 22:03
参与人数 1金币 +2 收起 理由
风过泪无痕丶 + 2 全部都提高吧。
