查看: 2028|回复: 4
【已解决】求hlae 下载地址,
发表于 2012-7-19 00:16:18 | 显示全部楼层 |阅读模式
  你们懂的,
发表于 2012-7-19 00:48:16 | 显示全部楼层
[size=+2]advancedfx.org
Home                                                 |  Download                                                 |  Forum                                                 |  Manual                                                 |  Media                                                 |  Contact
On this page:
Half-Life Advanced Effects
HLAE 2.2.21.9 (2012-07-04T16:44Z)
The HLAE tool is technically a hack, therefore you should use it for   making movies / watching demos only.
Epilepsy warning:   This software will cause fast changing images and colors on your   screen.
About: HLAEwiki
Documentation: HLAEwiki
System requirements:
- Microsoft Windows XP / Vista / 7 or similar
- Microsoft .NET Framework 4.0 or newer
- Genuine Steam version
- OpenGL 1.1 or newer
- a lot of patience
Tip:
Using Steam's   offline mode you can avoid retriving  updates that break HLAE during  movie production.
Changelog:
U Included AfxHookSource 0.0.3.27 (2012-07-04T16:43Z).
U Adjusted to 03 Jul 2012 CSS update.
Thanks and greetings to how-hiGh!
Author: HLAE Team
Tools - HLAE Camera Motion Data
These plugins / scripts assist you with importing HLAE camera motion data in various 3D applications or exporting to HLAE again.
3DsMax Import Plugin HLAE Cam Importer 1.0.4
3DsMax Export Plugin HLAE Cam Exporter 1.0.0
System requirements: HLAE 2.2.5.14 or newer, 3dsMax 5.x(?7.x / 2008?) or newer.
Author: msthavoc
After Effects Import Script: hlaebvh2AECam1.5
After Effects
Export Script: AECam2hlaebvh1.0
Documentation: video tutorials
Author: msthavoc
Blender 2.49b Import plugin: HLAE Camera Motion Import 0.0.2.2 (2010-01-23T17:50Z)
Blender 2.49b Export plugin: HLAE Camera Motion Export 0.0.2.2 (2010-01-23T17:50Z)
System requirements: HLAE 2.2.5.14 or newer, Blender 2.46 - Blender 2.49b
Author: ripieces
Cinema 4D Import Plugin: hlcam2c4d 1.3
Cinema 4D Export Plugin: c4d2hlcam 1.0
Documentation: HLAEwiki, video tutorials
System requirements: HLAE 2.2.5.14 or newer, Cinema 4D R9.5 or newer
Author: msthavoc
Writing your own plugin:
The HLAE .bvh format is very similar to but currenlty not compatbile with the BioVision (BVH) format: The only difference is that HLAE rotation order is XYZ while BVH would require ZXY.
Tools - Other
Other plugins / scripts to make your life easier.
Cinema 4D Script: Crafty Material Fix 0.1
About: Automates fixing material / texture links for maps exported by Crafty.
Author: msthavoc
谢谢噢 , ,, ,  详情 回复 发表于 2012-7-20 22:52
发表于 2012-7-19 01:20:31 | 显示全部楼层
表示看不懂。。
发表于 2012-7-19 20:11:04 | 显示全部楼层
K发的应该能用。记得下载上Microsoft .NET Framework 4.0
 楼主| 发表于 2012-7-20 22:52:53 | 显示全部楼层
SiMen.K. 发表于 2012-7-19 00:48
On this page:
  • Half-Life Advanced Effects
  • 谢谢噢 , ,,  ,
