查看: 1971|回复: 14
WR Release #611 - 15 New Demos
发表于 2012-7-7 19:47:54 | 显示全部楼层 |阅读模式
DeeDFTW
kz_adv_underground done in 06:45.76 ( 06:56.78 puppetz )
Toffifee
kz_boulder_b01 done in 04:52.80 ( 05:06.62 Messing )
chinakungfu
kz_canyon done in 06:25.44 ( 06:38.66 rad )
Nukk
kz_cg_pianoclimb done in 02:10.19 ( 02:10.91 koukouz )
kzlt_village done in 01:58.07 ( 02:03.85 Nukk )
JrG
kz_construction done in 03:51.14 ( 03:54.38 rEs0LuTe )
kzsca_highblocks done in 13:57.50 ( 14:10.89 JrG )
KeltA
kz_j2s_summercliff_h done in 02:14.94 ( 02:16.70 KeltA )
Chasquido
kz_kzfr_alexandrie done in 04:44.09 ( 04:51.18 Bibika )
round
kz_kzlt_dementia[-tranquillity] done in [url=http://xtreme-jumps.eu/check.php?filename=KZ_kzlt_dementia[-tranquillity]_round_0219.86.rar]02:19.86[/url] ( 02:20.94 KeltA )
akkord
kz_kzlv_wanderer done in 03:08.48 ( 03:13.65 NAPZ )
CaBeZa
kz_memphisblock done in 05:05.39 ( 05:11.44 ShoCk )
wlvz
kz_midnight done in 01:02.65 ( 01:02.76 koukouz )
Juice
kz_space2 done in 01:05.48 ( 01:06.57 SAMNY )
Gene
kzno_xtremeblock done in 01:55.46 ( 01:55.67 koukouz )
Read the extended news post for demos that were improved or didn't quite make it.
kz_adv_underground_DeeDFTW_0653.27.rar - Demo improved.
kz_adv_underground_sh_0653.59.rar - Demo improved.
kz_waterplant_Toffifee_0447.58.rar - Demo improved.
kzlt_village_Chasquido_0200.10.rar - Demo improved.
kzlt_village_Nukk_0159.38.rar - Demo improved.
发表于 2012-7-7 19:56:06 | 显示全部楼层
bkz_gb uptime = 8:55-,-
发表于 2012-7-7 20:28:43 | 显示全部楼层
自定義模組... 會rollback?
发表于 2012-7-7 20:28:50 | 显示全部楼层
shNz的圖我全看了...
bkz_goldbhop這張 其他我不敢說
我覺得他跳得沒以前好看...
我以前崇拜他的一個原因就是,看他跳幾乎看不到畫面移動時有停頓的狀況
本來感覺他靈敏度應該調蠻高,結果看了他的手部動作才知道他靈敏度也算低
所以我好奇還有崇拜他的視角移動... 怎麼都不會頓...(看他"1:29.45"在看KeltA的"1:29.20"2個BKZ_GOLDBHOP的demo 就知道我在說啥了)
還有他拍的某部片(the legendary) 的第1個跳點,我去試過啊...
跳完一圈,滑鼠也轉了快180度,難道他是為了那跳點去練高靈敏度嗎...
好啦.. 沒差 就算這樣,我還是繼續崇拜他...
他一次跳那麼多圖,說真的,我看得也看得很爽...
PS: kz_kzus_mountaincrest這張圖,第一次看到他跳圖有失敗的狀況,還3次左右,感覺有些狼狽-.-  我記得他不是都挑不太會失敗的圖在JUMP嗎?? 這似乎例外哦...??
怎麼會與180度有關  详情 回复 发表于 2012-7-8 21:40
他專挑速度圖刷當然不能有失誤 那張屬於中大圖 有一些失誤的話刷掉不傳白不傳  详情 回复 发表于 2012-7-8 09:41
发表于 2012-7-7 22:20:53 | 显示全部楼层
underground应该极佳
发表于 2012-7-8 09:38:12 | 显示全部楼层
刚想点下载链接时,突然想起电脑根本没装CS,不由无语凝噎
参与人数 1金币 +1 收起 理由
liangyun211 + 1 很给力!
发表于 2012-7-8 09:41:10 | 显示全部楼层
VoZA 发表于 2012-7-7 20:28
shNz的圖我全看了...
他專挑速度圖刷當然不能有失誤
至於加速不會頓完全是個人風格
kunqui和chasquido就屬於頓的很強烈那種 我就特喜歡這種風格
哦~... 那我就是喜歡她的風格了= = 他給我印象就是跳圖幾乎沒失敗,應該說他不會去跳那種容易失敗的圖 這在我印象中是第1個跳失敗3次的圖  详情 回复 发表于 2012-7-8 14:51
发表于 2012-7-8 14:51:46 | 显示全部楼层
haye 发表于 2012-7-8 09:41
他專挑速度圖刷當然不能有失誤
這在我印象中是第1個跳失敗3次的圖
发表于 2012-7-8 16:03:49 | 显示全部楼层
shNz啊,终于按耐不住了吧,bkz_goldbhop始终就是他的图了
发表于 2012-7-8 21:40:34 | 显示全部楼层
shNz的圖我全看了...
怎麼會與180度有關
那個跳點是在轉箱子... 他是繞2圈,我繞1圈時(同時也是我技術極限= =) 我的滑鼠差不多轉了180度 就是移動半圈,我手的極限差不多也就半圈(誰手可以轉一圈?-.-) 所以我才講180度  详情 回复 发表于 2012-7-8 21:52
