楼主: gyssi
转载XJ网部分WR视频在线看
发表于 2010-6-26 10:41:35 | 显示全部楼层
  不说全部上传过来
还是传1-2个中可以了吧~~
发表于 2010-6-26 10:48:50 | 显示全部楼层
原来大家都那么关注WR的丫
发表于 2010-6-26 13:19:04 | 显示全部楼层
YOUTU上不去
发表于 2010-6-26 13:20:23 | 显示全部楼层
找了一圈,就只有26一个国人的,哎呀
发表于 2010-6-26 17:21:39 | 显示全部楼层
我在校内上看到的上youtube方法,不过没试过额
用记事本复制下面的这一段话,格式改成所有格式来着,不是txt~~
然后保存名为hosts到C:/Windows/System32/drivers/etc
覆盖一下就好了的。不过我没敢用,怕系统受影响。觉得好的话就试试吧~~
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
127.0.0.1       localhost
203.208.33.100 www.youtube.com
203.208.33.100 gdata.youtube.com
发表于 2010-6-29 15:59:37 | 显示全部楼层
翻不了墙。。。。。。。。。
发表于 2010-7-18 13:28:13 | 显示全部楼层
好贴
发表于 2010-7-18 13:31:16 | 显示全部楼层
别说大不分啊,我看基本都是啊。。。我们不会翻墙的怎麽办啊
发表于 2010-7-19 13:34:42 | 显示全部楼层
不好意思,本人随便翻,很简单。。。用个软件一下就好了。。。
发表于 2010-7-19 13:35:23 | 显示全部楼层
freegate知道么。。
