查看: 18809|回复: 101
HNS 4.51 死亡竞赛+高效寒冰雷+同队补血(带有汉化源码)
 火... [复制链接]
发表于 2010-5-3 21:47:27 | 显示全部楼层 |阅读模式
        This program is free software; you can redistribute it and/or modify it
        under the terms of the GNU General Public License as published by the
        Free Software Foundation; either version 2 of the License, or (at
        your option) any later version.
        This program is distributed in the hope that it will be useful, but
        WITHOUT ANY WARRANTY; without even the implied warranty of
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
        General Public License for more details.
        You should have received a copy of the GNU General Public License
        along with this program; if not, write to the Free Software Foundation,
        Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
        In addition, as a special exception, the author gives permission to
        link the code of this program with the Half-Life Game Engine ("HL
        Engine") and Modified Game Libraries ("MODs") developed by Valve,
        L.L.C ("Valve"). You must obey the GNU General Public License in all
        respects for all of the code used other than the HL Engine and MODs
        from Valve. If you modify this file, you may extend this exception
        to your version of the file, but you are not obligated to do so. If
        you do not wish to do so, delete this exception statement from your
        version.
GNU 通用公共授权:http://www.opensource.org/licenses/gpl-license.php
【插件说明】
[HNS主] 插件版本 4.51           (普通模式+死亡模式)
高效冰雷插件版本  2.09             (修复冻结自身 BUG)
同队补血插件版本  1.05            (修复无法加血 BUG)
Get Plugin or Get Source  ( hns_4.51.sma - 24.3 KB )
Get Plugin or Get Source  ( EveryoneIsMedic.sma - 17.7 KB )
Get Plugin or Get Source  ( hns_frostnades.sma - 32.9 KB )
相关说明:
上面的下载地址分为编译好的插件和源码 哈哈 大家尽量下吧  ^_#
参与人数 3金币 +15 +15 收起 理由
yanjunan + 3 + 3 很春很曾哥
kz老菜鸟 + 5 + 5 GJ
XLM.Kz.流星 + 7 + 7 YE!
发表于 2014-4-24 15:49:39 | 显示全部楼层
eim_in_team (default: 0) - which team have medics, 0 - both, 1 - ts only, 2 - cts only  这个是sma文件里面修改的吗?
    发表于 2014-6-27 17:09:20 | 显示全部楼层
    那个死亡模式不能去掉吗?
    发表于 2010-5-3 21:52:15 | 显示全部楼层
    我对你的敬仰犹如滔滔江水连绵不绝,又如黄河泛滥一发不可收拾
    参与人数 1 +4 收起 理由
    czcxw + 4 多隆!你好!
    发表于 2010-5-3 22:05:24 | 显示全部楼层
    支持个,。。。现在下种子 等下再下
    参与人数 1金币 +1 收起 理由
    XLM.Kz.流星 + 1 什么?多隆?你加分加错了把?
    发表于 2010-5-3 22:29:05 | 显示全部楼层
    mylove
     楼主| 发表于 2010-5-3 22:41:28 | 显示全部楼层
    回复 2# XLM.Kz.流星
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2010-5-3 23:20:01 | 显示全部楼层
    回复 2# XLM.Kz.流星
        去看鹿鼎记 多隆对韦小宝说的最多就是这句话
    发表于 2010-5-4 04:12:42 | 显示全部楼层
    纳尼?????
    发表于 2010-5-4 10:02:04 | 显示全部楼层
    兰州又要面临无穷无尽的各种各样的的稀奇古怪的问题了
     楼主| 发表于 2010-5-4 10:06:06 | 显示全部楼层
    回复 8# dsm635625
        哈哈  我一开始也是这样想的,但是毕竟我也调试过一番。把源码发上来给大家共享算了!
    发表于 2010-5-4 15:32:21 | 显示全部楼层
    支持个,。。。现在下种子 等下再下
    czcxw 发表于 2010-5-3 22:05
        什么种子发出来分享
