查看: 3029|回复: 22
【8月2日更新】Edge Distances 显示你和板子边的距离
发表于 2009-7-24 04:10:41 | 显示全部楼层 |阅读模式
Xj看到的,这里没人发?
我转转,翻译一下,作者是SchlumPF
Edge Distances
描述:
这个插件可以显示跳板子时 起跳 和 落下 时离板子边的距离。
能巩固你的LJ技巧(对板子党来说)。
能显示你跳板子的距离。 (可以算一个新的top15,板子>距离)
比如大家都跳距离都是250。
一个在230板子上过的,另一个在240板子上过的。
那么240板子的排名就靠前。
其他信息
因为Lt.RAT不更新他的Edge Distances版本而Exolentince目前也没有做这个,
所以作者SchlumPF做了他自己的版本。
不是LJ板子上跳的这个插件不显示,但能显示大部分技术。
(lj,hj,cj,bhop lj,wj都可以显示,但这些在bhop的板子上则不会显示)
不支持ladderjump的板子。
作者不想在这个插件上花太多时间,因为也许Exolent在他的JumpStats会包括这个功能
命令
按y输入 /ed, 或者 /edge, 或者/edgedistance - 可以开启/关闭这个插件
(就打/ed就好啦)
CVars
ed_hud_color "0 255 0" -         成功跳跃信息颜色
ed_hud_failcolor "255 0 127" -  失败跳跃信息颜色
ed_hud_coords "-1.0 -0.125" - 屏幕信息的位置
ed_hud_holdtime "1.6" - 信息显示的时间
ed_hud_channel "4" - channel of the hudmessage (这是啥我不知道)
更新日志
07/21/09 - v0.1
!: initial release
07/22/09 - v0.2
+: added jumpoff edge distance on failing a jump
f: fixed a few bugs where stats appeared although they shouldn't
07/23/09 - v0.21
f: fixed a bug in the landing origin calculation which caused wrong distances sometimes
c: changed parts of the code so only jumps on blocks will show stats now (there shouldn't be any cases where wrong stats were shown anymore)
c: added a few defines and marked a few defines as settings in the sourcecode (min and max distance)
07/23/09 - v0.22
+: added cvars to adjust the hudmessage
+: added chatcommands to enable/disable the stats
c: changed the chatmessage to a hudmessage
f: fixed a bug because of which failed stats didn't appear sometimes
-: removed unnecessary code
更新:
07/25/09 - v0.23
f: fixed using ladder to get better stats
f: fixed a bug because of which stats appeared on jumping to a wall
f: fixed a bug because of which failed stats didn't appear on non-ducked jumps
Credits
Lt.RAT - First one to create such a plugin
Exolent - Used parts of the code he made for JumpStats
Have fun geeking!
Lt.RAT wrote ...
SchlumPF wrote ...
and is as accurate as Lt.RAT's plugin
no, yours more accurate
my plugin was only fast creation, and it was created not in perfect way, to support all things
其他懒得翻译了,下吧!
这个是更新过的版本:
Edge Distances
插件怎么装,菜鸟也许不知道,我再多嘴一下
amxx文件放到 1.6\cstrike\addons\amxmodx\plugins
sma  文件放到 1.6\cstrike\addons\amxmodx\scripting
最后记事本打开 1.6\cstrike\addons\amxmodx\configs\plugins.ini
最后一行加入:edgedistances.amxx
其他插件也是这么个装法。
发表于 2009-7-24 08:34:23 | 显示全部楼层
太专业了...
发表于 2009-7-24 08:38:29 | 显示全部楼层
bb我崇拜你!帮忙打个包吧!
发表于 2009-7-24 08:40:08 | 显示全部楼层
好东西啊  没人顶呢怎么
发表于 2009-7-24 09:26:01 | 显示全部楼层
SchlumPF说他不准备非常用心地做这个插件,因为将来是要整合进jumpstats的,于是没发了
不过他还是挺努力的,两天功夫就更新到0.22了
数据比Lt.RAT一直在测试状态的插件要精确,推荐使用
发表于 2009-7-24 09:50:53 | 显示全部楼层
板子党的赶紧了
发表于 2009-7-24 10:02:33 | 显示全部楼层
BB 有没有LJ BJ CJ HJ JB EB的数据显示的插件。。。。我要
发表于 2009-7-24 10:40:57 | 显示全部楼层
板子党的福音啊
发表于 2009-7-24 10:53:48 | 显示全部楼层
哦,板子专用
退散鸟……
发表于 2009-7-24 12:50:23 | 显示全部楼层
..顶顶,,专给我设计的吧。
