查看: 2969|回复: 7
公布我做视频用的cfg
发表于 2008-10-2 00:40:13 | 显示全部楼层 |阅读模式
可以根据个人喜好而更改一些内容,把它保存到userconfig.cfg
alias "+1up" "+left;+moveup"
alias "-1up" "-left;-moveup"
alias "+2up" "+right;+moveup"
alias "-2up" "-right;-moveup"
alias "+1down" "+left;+movedown"
alias "-1down" "-left;-movedown"
alias "+2down" "+right;+movedown"
alias "-2down" "-right;-movedown"   alias "+1a" "+moveleft"
alias "-1a" "-moveleft"
alias "+1d" "+moveright"
alias "-1d" "-moveright"   //旋转升降
bind "w" "+forward"   //前进
bind "s" "+back"  //后退
bind "LEFTARROW" "+left"   //视角向左
bind "RIGHTARROW" "+right"   //视角向右
bind "q" "+1up"   //上移并视角向左
bind "e" "+2up"   //上移并视角向右
bind "z" "+1down"   //下移并视角向左
bind "c" "+2down"   //下移并视角向右
bind "f" "+1a"  //左平移并视角向右
bind "g" "+1d"  //右平移并视角向左
bind "UPARROW" "+moveup"   //向上移动
bind "DOWNARROW" "+movedown"   //向下移动
bind "a" "+moveleft"   //左平移
bind "d" "+moveright"   //右平移
bind "F1" "dem_speed 0.25"  //dem播放速度为1/4倍
bind "F2" "dem_speed 0.5"   //dem 播放速度为1/2倍
bind "F3" "dem_speed 1"    //dem播放速度为正常
bind "MWHEELDOWN" "dem_pause 0"   //dem播放暂停
bind "MWHEELUP" "dem_pause 1"   //dem播放继续
cl_forwardspeed "150"    //前进速度
cl_backspeed "150"   //后退速度
cl_upspeed "150"   //上下平移速度
cl_sidespeed "150"  //左右平移速度
cl_yawspeed "30"   //左右转身的速度
cl_gaitestimation "1"   //画面优化
cl_himodels "1"  //画面优化
cl_observercrosshair "0"  //画面优化
cl_righthand "1"   //右手持枪
gl_clear "1"   //画面优化
gl_polyoffset "4"  //画面优化
gl_wateramp "1"  //画面优化
r_detailtextures "1"  //画面优化
r_dynamic "1"  //画面优化
hud_draw "0"   //清除屏幕信息
brightness "3"   //亮度
gamma "3"   //对比度
voice_enable "0"   //语音喇叭关闭
[ 本帖最后由 reflex 于 2008-10-2 01:46 编辑 ]
发表于 2008-10-2 00:59:08 | 显示全部楼层
好东西。有机会自己也弄个玩
 楼主| 发表于 2008-10-2 01:05:15 | 显示全部楼层
如果平时用的CS和做视频用的CS是一个的话.
用前请备份原有的config.cfg
发表于 2008-10-2 01:05:25 | 显示全部楼层
做比赛视频的cfg
视频制作
hideradar 雷达开
drawradar 雷达关
hud_draw 0 空屏
hud_saytext 字幕
bind "F4" "pauser" 暂停
bind "F5" "snapshot"
bind "F6" "fw2"  4倍速度
bind "F8" "startmovie a 90"
bind "F9" "startmovie b 90"
bind "F10" "startmovie c 90"
bind "F11" "startmovie d 90"
cl_forwardspeed "X" = 前进速度
cl_backspeed "X" = 后退速度
cl_sidespeed "X" = 平移速度
cl_upspeed "X" = 上下移动速度
cl_yawspeed "X" = 转身速度
bind "TAB" "+showscores;timeleft;cl_righthand 0" 最重要的一条 参数 因为我想视频上的都是左撇子!!
[ 本帖最后由 摇头万岁 于 2008-10-2 03:35 编辑 ]
发表于 2008-10-2 02:46:20 | 显示全部楼层
[quote]原帖由 摇头万岁 于 2008-10-2 01:05 发表
做比赛视频的cfg
发表于 2008-10-2 06:34:21 | 显示全部楼层
不会用!
发表于 2009-7-3 23:26:48 | 显示全部楼层
这个hud_draw "0" 命令输入的话,连打的FRAG都看不到了,怎么做CS视频呢。高手?
发表于 2009-8-16 01:16:45 | 显示全部楼层
2倍速4倍速那个属于浪费键位吧?
VEGAS里面就可以随便改
